Seems so simple I'm missing something ! Using a protoboard with leds on each output then Relay2 doesn't work.
Code:;***************************************************** ; ; Target Controller - PIC12F675 - Linear RF Amplifier Sequencer ; _______ ; VDD +5V |1 8| Vss Ground ; PTT -GP5 |2 7| GP0--Ant Relay ; Standby -GP4 |3 6| GP1--Relay 1 ; -GP3 |4 5| GP2--Relay 2 ; -------- ; ; ***************************************************** Antenna VAR GPIO.0 Relay1 VAR GPIO.1 Relay2 VAR GPIO.2 Standby VAR GPIO.4 ;inhibit ptt swtch PTT VAR GPIO.5 TRISIO = %00110000 ; GPIO 4 & 5 as inputs ADCON0 = 0 ; adc off ANSEL = 0 CMCON=7 ; comparator off Define OSC 4 pause 50 ; Settle time main: IF standby = 0 then main WHILE PTT = 0 HIGH Antenna PAUSE 100 HIGH Relay1 PAUSE 10 HIGH Relay2 WEND LOW Relay2 PAUSE 10 LOW Relay1 PAUSE 100 LOW Antenna GOTO main END
