config
Results 1 to 13 of 13
Thread: config
    Mar 2008
    Default config
    Can anyone tell me why this does not work?
    I started with "@ DEVICE MCLRE_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF" in PBP2.50 and need to know the proper syntax for PBP3?
    #config
    __config _MCLR_OFF & _INTRC_OSC & _PROTECT_ON & _WDT_OFF & _BOD_OFF & _PWRT_OFF
    #endconfig
    Roger
    Default Re: config
    Post all your code and model of PIC.
    What errors do you get? How does it "not work"?
    Mar 2008
    Default Re: config
    I am using a 16f628a. I was unable to compile because of undefined symbol "INTRC_OSC"
    this seems to work
    #config
    __config _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_ON
    #endconfig
    I was having problems with the "INTOSC_OSC_NOCLKOUT" in PBP2.5 this was "INTRC_OSC". I would like to see a list of all of these changes if anyone know where to find them?
    Thank you very much for your reply Robert!
    Roger
    Default Re: config
    Have you read this?
    Did you change to MPASM instead of PM?
    Mar 2008
    Default Re: config
    I just received my new PBP3 and this documents seems to say that the PM assembler is no longer supported?
    http://pbp3.com/downloads/Migrating%...0to%20PBP3.pdf
    Please take a look and tell me I am wrong. I have used PBP for many years and change is not my favorite thing
    Thanks for all of your help!
    Roger
    Default Re: config
    PM is now "extinct".
    You have to download MPLAB X (I think), and then point to MPASM.
    You don't have to use MPLAB, you only need the new assembler.
    Edit:
    http://www.picbasic.co.uk/forum/showthread.php?t=18520
  1. PIC12F675 - config
    By Vezito in forum mel PIC BASIC Pro
    Last Post: - 8th June 2011, 21:29
  2. Config 18F25K22
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 26th April 2011, 20:08
  3. config help please?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 18th June 2008, 00:49
  4. Need help with config
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 07:57
  5. Config 16F873A
    Last Post: - 23rd October 2007, 13:18
