config
Results 1 to 13 of 13
Thread: config
    Mar 2008
    Default config
    Can anyone tell me why this does not work?
    I started with "@ DEVICE MCLRE_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF" in PBP2.50 and need to know the proper syntax for PBP3?
    #config
    __config _MCLR_OFF & _INTRC_OSC & _PROTECT_ON & _WDT_OFF & _BOD_OFF & _PWRT_OFF
    #endconfig
    Roger
    Default Re: config
    Post all your code and model of PIC.
    What errors do you get? How does it "not work"?
    Mar 2008
    Default Re: config
    I am using a 16f628a. I was unable to compile because of undefined symbol "INTRC_OSC"
    this seems to work
    #config
    __config _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_ON
    #endconfig
    I was having problems with the "INTOSC_OSC_NOCLKOUT" in PBP2.5 this was "INTRC_OSC". I would like to see a list of all of these changes if anyone know where to find them?
    Thank you very much for your reply Robert!
    Roger
    Default Re: config
    Have you read this?
    Did you change to MPASM instead of PM?
    Mar 2008
    Default Re: config
    I just received my new PBP3 and this documents seems to say that the PM assembler is no longer supported?
    http://pbp3.com/downloads/Migrating%...0to%20PBP3.pdf
    Please take a look and tell me I am wrong. I have used PBP for many years and change is not my favorite thing
    Thanks for all of your help!
    Roger
    Default Re: config
    PM is now "extinct".
    You have to download MPLAB X (I think), and then point to MPASM.
    You don't have to use MPLAB, you only need the new assembler.
    Edit:
    http://www.picbasic.co.uk/forum/showthread.php?t=18520
    Mar 2008
    Default Re: config
    Now I am really confused! I will sleep maybe it will all make sense in the moring
    Thank You
    Roger
    Default Re: config
    Yeah, I can see why. I think that thread is when you want to use MPLAB.
    Here's what I do for PBP 2.6:
    - install MPLAB.
    - install PBP.
    - install Microcode Studio.
    - in MCS, point to PBP and MPASM.
    Unless v3 has a major change in the way things work, the same should work.
    Hopefully someone with v3 can chime in.
    Default Re: config
    Make a separate directory for pbp3 from earlier versions so you can use both.
    Mar 2008
    Default Re: config
    Thank You to everyone!
    Roger
    Default Re: config
    If you go into the "DEVICE_REFERENCE" folder of your PBP3 install directory you will find a bunch of files *.INFO. Find the file that relates to your PIC and open it to find a complete list of all the config options with descriptions and an example of how to use the settings in PBP3, e.g for PIC16F1509
    ; Available __CONFIG labels for PIC16F1509:
    ;CONFIG1 Options
    ; Oscillator Selection Bits
    ; _FOSC_ECH ;ECH, External Clock, High Power Mode (4-20 MHz): device clock supplied to CLKIN pins
    ; _FOSC_ECM ;ECM, External Clock, Medium Power Mode (0.5-4 MHz): device clock supplied to CLKIN pins
    ; _FOSC_ECL ;ECL, External Clock, Low Power Mode (0-0.5 MHz): device clock supplied to CLKIN pins
    ; _FOSC_INTOSC ;INTOSC oscillator: I/O function on CLKIN pin
    ; _FOSC_EXTRC ;EXTRC oscillator: External RC circuit connected to CLKIN pin
    ; _FOSC_HS ;HS Oscillator, High-speed crystal/resonator connected between OSC1 and OSC2 pins
    ; _FOSC_XT ;XT Oscillator, Crystal/resonator connected between OSC1 and OSC2 pins
    ; _FOSC_LP ;LP Oscillator, Low-power crystal connected between OSC1 and OSC2 pins
    are the config options for the oscillator. When you install PBP3 it has the option of installing the correct assembler if not already installed.
    Mar 2008
    Default Re: config
    That is exactly the file I was trying to find!
    Thank You!
    Roger
    Default Re: config
    Your most welcome!
  1. PIC12F675 - config
    By Vezito in forum mel PIC BASIC Pro
    Last Post: - 8th June 2011, 20:29
  2. Config 18F25K22
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 26th April 2011, 19:08
  3. config help please?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 23:49
  4. Need help with config
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 06:57
  5. Config 16F873A
    Last Post: - 23rd October 2007, 12:18
