RMW Read modify write
Results 1 to 13 of 13
    Feb 2012
    PERTH AUSTRALIA
    Default Re: RMW Read modify write
    glcd_dat	var PORTE	   ' LCD 8 bit data bus
    as this is 8bit data port with the TRIS set at $00 or $FF
     glcd_tris 	var TRISE	   ' Data bus direction
    would PBP uses LAT port registers internally ?
    assuming you have lat registers on your pic chip , porte is not equal to late they are separate registers . check the memory map of your chip.
    pbp has no glcd native functions, whether your "glcd library" uses late is completely dependent on how the library was written .
    if you define your "data bus" as porte I would expect it will not use lat regs (that would probably require two defines , one for each direction)
    and lastly rmw has no impact at all when you are writing to the whole port
  1. PLEASE HELP...read write issues
    By nomad77 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 15:39
  2. Write/Read DS1996
    By Bosse in forum Forum Requests
    Last Post: - 9th September 2008, 01:25
  3. DS1996 Read/Write
    By Bosse in forum Serial
    Last Post: - 30th October 2007, 14:36
  4. Read and write to sd card
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 20:47
  5. Read Modify Write problem?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 18th November 2005, 22:02
