This is simple Led-blink code that does not work.
LED5 flashes normally, and LED 4 stable HIGH.................
Using a 12F1822 (RA4 is not open collector in this PIC).
when LOOPA modified as above works fine and both LEDs blinking.Code:ASM __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_HI & _LVP_OFF ENDASM DEFINE OSC 32 LED5 VAR PORTA.5 LED4 VAR PORTA.4 OSCCON = %01110000 ANSELA = %00000011 ' AN0 = ANALOG PIN , C1IN0- = ANALOG PIN TRISA = %00000000 LOOPA: LED4 = 1 LED5 = 1 PAUSE 100 LED4 = 0 LED5 = 0 PAUSE 100 GOTO LOOPA
EDIT : instead of the 2us pause , i tried another command like modifying a variable , XX = 1 and still works.Code:LOOPA: LED4 = 1 LED5 = 1 PAUSE 100 LED4 = 0 PAUSEUS 2 <--- LED5 = 0 PAUSE 100 GOTO LOOPA
So the conclusion is , two LEDx = 0 commands in the row cannot be processed normally (although LEDx = 1 works) .
The UFO's coming ...
Cheers!
