Richard,
I am amazed that it works using $D0 for read and write control. Simply because this is not how others have coded the I2C instruction for this device in the past and it worked for them. Also the data sheet is very specific on the procedure to use for write and read procedures which obviously PBP3 is not following but still works.
Does this mean that read the manual and the data sheet is no longer good advice?
