DS1307 not running?
Results 1 to 19 of 19
    Default Re: DS1307 not running?
    the ds1307 has 8 registers for the rtc function addressed from 0 to 0x07
    the control reg address is 0x07 bits 7 and 4 control the sqwe , if you only use the time keeping function the control reg can be ignored
    to set the time you start at register address 0 (sec min hours ......)
    to read just minutes start from address 1 etc
    pbp will set bit 0 of the device address ($d0 in this case) as required (at least pbp3 will not sure about pbp2xx)
    the ram goes from 0x08 to 0x3f trying to write or read from regs $d0 or $d1 will not have meaning full results
    Jun 2009
    Sc*nthorpe, UK
    Richard,
    Now I understand the datasheet refers to the control as address, how confusing. I did not realise that the eighth bit is added automatically.
    Thanks for that.
    Jun 2009
    Sc*nthorpe, UK
    Having read the data sheet again I found this near the end
    How confusing that makes us both wrong. I must learn to read the whole data sheet in future.
    Jun 2009
    Sc*nthorpe, UK
    I will say again pbp will set bit 0 of the i2c device address as required
    by running :-
    I2CRead SDA, SCL, $D0, 0, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear]
    it will write 0 to the control address logic of the 1307 and then read 7 bytes
    try it !
    Jun 2009
    Sc*nthorpe, UK
    by running :-
    try it !
    $D0 is write
    I2CRead SDA, SCL, $D1, 0, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear]
    Is read according to the data sheet and the example in #9.
    Interestingly the data sheet extract shown in #8 says to do
    I2CWrite SDA, SCL, $D0, 0
    reset the write pointer then
    I2CRead SDA, SCL, $D1, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear]
    to read the time.
    But the example code in #9 works by using
    So I am curious to find out from Sabahan what works in his case.
  1. Replies: 8
    Last Post: - 28th January 2014, 14:21
  2. using DS1307
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2013, 10:01
  3. 18F4550 not running
    By comwarrior in forum General
    Last Post: - 1st January 2011, 01:07
  4. Cant get my PIC running
    By Viberer in forum Off Topic
    Last Post: - 29th August 2008, 20:07
