DS1307 not running?
Results 1 to 19 of 19
    Jun 2009
    Sc*nthorpe, UK
    Default Re: DS1307 not running?
    Check the data sheet which says -
    The slave address byte contains the 7-bit DS1307 address, which is 1101000, followed by the direction bit (R/W), which for a write is 0.
    so
    I2CRead SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
    should be
    I2CRead SDA, SCL, $D0, $D0, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
    and read
    I2CRead SDA, SCL, $D0, $D1, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
    obviously you need to sort out the control as you are using $D0 for that? Which if you are not using SQWO $00 I think.
  1. Replies: 8
    Last Post: - 28th January 2014, 14:21
  2. using DS1307
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2013, 10:01
  3. 18F4550 not running
    By comwarrior in forum General
    Last Post: - 1st January 2011, 01:07
  4. Cant get my PIC running
    By Viberer in forum Off Topic
    Last Post: - 29th August 2008, 20:07
