Stacker Arcade Game 8*8 LED Matrix
Results 1 to 8 of 8
    May 2014
    Cool Stacker Arcade Game 8*8 LED Matrix
    Just wanted to contribute my code for everyone, this site really helped me finish my final project in electronics and without everyone's examples to this forum I would have been completely lost... As a newbie it took me quite awhile to code this but I got it working with a max7219 and 8x8 LED RGB Matrix and a PIC16F628A... I know I could've cleaned up the code by unfortunately with the amount of time I had I couldn't really dabble into it... Also I was having a problem with the sound hissing since the MAX7219 is so noisy... I used a 1000Uf capacitor to take care of the noise but it still annoys me sometimes...Enjoy the game! If you can find an improvement to the setup for the sound then more power too ya!
    P.S. I'm also looking for a job, I graduated in electronics and was hoping a for a future in my field but, unfortunately I'm not having any luck... If there's any openings or interest in me please PM me or even email me a [email protected] I'll reply back with a resume if anyone's interested...
    'Stacker_Game.BAS
    'SET FUSES WHEN PROGRAMMING TO
    'INTRC_OSC ENABLED
    'CLKOUT & _MCLRE_OFF & _PWRTE_ENABLED
    pause 500 'wait to power on
    include "modedefs.bas" 'Adds this file to program
    TRISB=0 'Sets all portb to outputs
    TRISA=1   'ra.2 = input ra.1 knob led
    cmcon = 7   'porta digital i/o
    TRASH var byte  'needed for button command to store presses
    trash = 0 'Must initialize to 0 prior to use and not used elsewhere
    ADDRESS var byte 'variable address for display
    DATAREG var byte 'variable data register for display
    Y VAR BYTE 'Counter to load ADDRESS and DATAREG
    X var byte 'Amount of Moves
    Block_Lvl var byte 'What Lvl the Blocks are at
    Speed var word 'Speed Variable
    Block_Lives var byte 'Lives
    LastLocation VAR byte[9] 'Last Location of Blocks
    Current_X var byte  'Current Location of BLocks
    Change var byte 'Use this variable to store change in X from LastLocation
    WinOrLose var byte 'Variable used for a win or lost
    MyBit var byte 'Referencing a Byte
    MissBlock var byte  'Current Location of BLocks
    OnRightSide var bit 'Blocks are on right side of LastLocation
    Blink var byte 'When Switching Lives and Lvls uses this to and together two stages last dataregs
    CurrentDATAREG var byte[9] 'Current Datareg Saves for each stage
    Set_Speed var word 'Variable to Set Speed
    Game_Difficulty var byte 'Difficulty
    LED VAR BYTE 'LED Brightness
    Grenade var byte 'For Grenade SOund
    speaker con 0 'Sets Speaker to Portb.0
    pot porta.1,6,LED 'Reads Knob for Brightness
    pot porta.0,90,Game_Difficulty 'Reads Knob for Game Difficulty
    '----- Symbol ------
    SYMBOL CLK = PORTB.3
    SYMBOL DAT = PORTB.1
    SYMBOL LOAD = PORTB.2
    '-----PIN SETUPS-----
    low dat 'data pin for MAX7219 (1)
    low clk 'clock pin for MAX7219 (13)
    low load 'load pin for MAX7219 (12)
    '-----MAX7219 SETUP-----
    ADDRESS = $0C : DATAREG = $01 : gosub MaxWrite ' NO SHUTDOWN MODE, NORMAL OPERATION
    ADDRESS = $09 : DATAREG = $00 : gosub MaxWrite ' COMBINATION BINARY, NO DECODE
    ADDRESS = $0A : DATAREG = LED : gosub MaxWrite ' INTENSITY OF LEDS
    ADDRESS = $0B : DATAREG = $07 : gosub MaxWrite ' SCAN LIMIT DIGIT NUMBERS
    ADDRESS = $0F : DATAREG = $00 : gosub MaxWrite ' NORMAL OPERATION INSTEAD OF TEST
    GOSUB Clean
    WinOrLose = 1 'First turned on will show a smile face before first game initiated
    Main: 'Game Initiate
        if WinOrLose = 1 then
        Gosub GameState_Winning
        gosub GameState_Losing
        button porta.2,0,255,255,Trash,1,Blocks_Moving
        x = 0 'Set X for Datareg
        Block_Lvl = 8
        Speed = 0
        Block_Lives = 3
        gosub Brightness
    goto Main
    BrightNess:
    Blocks_Moving:   'Moving Blocks
        gosub Brightness
        gosub Clean_Lvl
        gosub Game_Speed
        Gosub Blocks_Animation
        If Block_Lvl > 0 then    'Block_Lvl is greater than this amount then Next_Lvl is applicable
            button porta.2,0,255,255,Trash,1,Next_lvl
    goto Blocks_Moving
    '-----Sounds-----
    SoundFx:
        FOR Grenade = $8F TO $20 STEP -3
            SOUND speaker,[Grenade,1]
        NEXT Grenade
    MissedSoundFx:
        SOUND speaker,[14,16,7,16]'missing a block
    WinningSoundFx:
        SOUND speaker,[116,16,119,16,120,16,122,16]
    LosingSoundFx:
        SOUND speaker,[114,16,112,16,116,16,111,16]
    '-----Animations-----
    Blocks_Animation:
    select case Block_Lives
        Case 3
            lookup X,[56,112,224,112,56,28,14,7,14,28],datareg 'Animation for 3 blocks
            lookup X,[3,2,1,2,3,4,5,6,5,4],Current_X 'Current Block Location on Grid
            address = Block_Lvl : datareg = Datareg
            gosub maxwrite
            While Speed <= Set_Speed
            Speed = Speed + 1
            If Speed = Set_Speed then
                X = X + 1
            If X = 10 then
                X = 0
            wend
            Speed = 0
        case 2
            lookup X,[24,48,96,192,96,48,24,12,6,3,6,12],datareg 'Animation for 2 blocks
            lookup X,[4,3,2,1,2,3,4,5,6,7,6,5],Current_X 'Current Block Location on Grid
            gosub maxwrite
            Speed = Speed + 1
                X = X + 1
            If X = 12 then
                X = 0
            wend
            Speed = 0
        Case 1
            lookup X,[8,16,32,64,128,64,32,16,8,4,2,1,2,4],datareg 'Animation for 1 blocks
            lookup X,[5,4,3,2,1,2,3,4,5,6,7,8,7,6],Current_X 'Current Block Location on Grid
            gosub maxwrite
            Speed = Speed + 1
                X = X + 1
            If X = 14 then
                X = 0
            wend
            Speed = 0
        case 0
            gosub LosingSoundFx
            WinOrLose = 0
            goto Main
        end select          'This will end the select case program
    Game_Speed: 'This sets Speed for each Level
    select case Block_Lvl      'This will Set the Speed for each Lvl
        case 8
        Set_Speed = 1563 - (Game_Difficulty * 10) '400 Ms
        Case 7
        Set_Speed = 1563 - (Game_Difficulty * 10)'400 Ms
        Case 6
        Set_Speed = 1367 - (Game_Difficulty * 10)'350 Ms
        Case 5
        Case 4
        Set_Speed = 1269 - (Game_Difficulty * 10)'325 Ms
        Case 3
        Set_Speed = 1172 - (Game_Difficulty * 10)'300 Ms
        Case 2
        Set_Speed = 1074 - (Game_Difficulty * 10)'275 Ms
        Case 1
        Set_Speed = 977 - (Game_Difficulty * 10)'250 Ms
        end select
    Next_Lvl:
    select case Block_Lvl      'This will Select the case for each Lvl
        case 8
            onrightside = 0
            LastLocation[8] = Current_X
            Currentdatareg[8] = datareg
            Block_lvl = Block_lvl - 1
            gosub soundfx
            PauseUS 1000   'Pause for 1 millisecond
        Case 7
            LastLocation[7] = Current_X
            Currentdatareg[7] = datareg
            Change = abs (LastLocation[8] - Current_X) 'Amount of change from stored location
            if lastlocation[8] > lastlocation[7] then
                Lastlocation[7] = lastlocation[7] + Change
            if lastlocation[8] < lastlocation[7] then
                onrightside = 1
            Gosub Missed
        Case 6
            onrightside = 0
            LastLocation[6] = Current_X
            Change = abs (LastLocation[7] - Current_X) 'Amount of change from stored location
            if lastlocation[7] > lastlocation[6] then
                Lastlocation[6] = lastlocation[6] + Change
            if lastlocation[7] < lastlocation[6] then
                onrightside = 1
            Gosub Missed
            Currentdatareg[6] = datareg
            If Block_Lives > 2 then
                BLock_Lives = Block_Lives - 1
        Case 5
            onrightside = 0
            LastLocation[5] = Current_X
            Currentdatareg[5] = datareg
            Change = abs (LastLocation[6] - Current_X) 'Amount of change from stored location
            if lastlocation[6] > lastlocation[5] then
                Lastlocation[5] = lastlocation[5] + Change
            if lastlocation[6] < lastlocation[5] then
                onrightside = 1
            if Change = 2 and lastlocation[6] < lastlocation[5] then
                Change = 1
            Blink = Currentdatareg[5] & currentdatareg[6]
            if Blink = Currentdatareg[5] then
                Block_Lvl = Block_Lvl - 1
                gosub soundfx
                Gosub Missed
        Case 4
            onrightside = 0
            LastLocation[4] = Current_X
            Change = abs (LastLocation[5] - Current_X) 'Amount of change from stored location
            if lastlocation[5] > lastlocation[4] then
                Lastlocation[4] = lastlocation[4] + Change
            if lastlocation[5] < lastlocation[4] then
                onrightside = 1
            Gosub Missed
            Currentdatareg[4] = datareg
            If Block_Lives > 1 then
        Case 3
            onrightside = 0
            LastLocation[3] = Current_X
            Currentdatareg[3] = datareg
            Change = abs (LastLocation[4] - Current_X) 'Amount of change from stored location
            if lastlocation[4] > lastlocation[3] then
                Lastlocation[3] = lastlocation[3] + Change
            if lastlocation[4] < lastlocation[3] then
                onrightside = 1
            Blink = Currentdatareg[3] & currentdatareg[4]
            if Blink = Currentdatareg[3] then
                gosub soundfx
                Gosub Missed
        Case 2
            onrightside = 0
            LastLocation[2] = Current_X
            Currentdatareg[2] = datareg
            Change = abs (LastLocation[3] - Current_X) 'Amount of change from stored location
            if lastlocation[3] > lastlocation[2] then
                Lastlocation[2] = lastlocation[2] + Change
            if lastlocation[3] < lastlocation[2] then
                onrightside = 1
            Gosub Missed
        Case 1
            onrightside = 0
            lastlocation[1] = Current_X
            Currentdatareg[1] = datareg
            Change = abs (LastLocation[2] - Current_X) 'Amount of change from stored location
            if lastlocation[2] < lastlocation[1] then
                onrightside = 1
            Gosub Missed
            If Block_Lives >= 1 then
            Gosub WinningSoundFx
            Winorlose = 1
            goto Main
    goto Blocks_Moving
    Missed:
    if change = 0 then
            gosub soundfx
    if Change = 1 then
            gosub MissedSoundFx
            gosub Missed_Animation
            Block_Lives = Block_Lives - 1
    if Change = 2 then
            gosub MissedSoundFx
            Gosub Missed_Animation
            if Block_Lives = 1 then
            Block_Lives = Block_Lives - 2
    if Change > 2 then
            gosub MissedSoundFx
            Block_Lives = 0
            Winorlose = 0
            goto Blocks_Animation
    Missed_Animation:
            missblock = ncd datareg
            if onrightside = 1 then
                if Block_Lives > 2 then
                    if Change = 1 then
                    MissBlock = MissBlock - 2
                    if change = 2 then
                    MissBlock = MissBlock - 1
                if Block_Lives = 2 then
                    if change = 1 then
                        lookup MissBlock,[0,1,2,4,8,16,32,64,128],mybit 'One Block Blinking
                    if change = 2 then
                        lookup MissBlock,[0,0,3,6,12,24,48,96,192],mybit 'Two Blocks Blinking
                    if change > 2 then
                        lookup MissBlock,[0,0,0,7,14,28,56,112,224],mybit 'Three Blocks Blinking
                    if change = 2 then
                    if change > 2 then
            If Block_Lives = 1 then
            address = block_lvl : datareg = datareg ^ mybit
            gosub maxwrite
            Pause 1000
            gosub maxwrite
            gosub maxwrite
            Pause 1000
            gosub maxwrite
            Pause 1000
            gosub maxwrite
    MaxWrite:
    shiftout DAT,CLK,MSBFIRST,[ADDRESS,DATAREG] 'Shift out the data to the 'MAX7219 'first the address, then data.
    pulsout LOAD,1 'load the data into the MAX7219
    Clean:
    for Y = 1 to 8 'write $0F (blank) to all digits
    ADDRESS = Y : DATAREG = $00 : gosub MaxWrite
    next Y
    Clean_Lvl: 'write $0F (blank) to certain Lvl
    Y = 1
    While Y < Block_Lvl
    Y = Y + 1
    wend
    '----- Graphics ------
    GameState_Winning:  'Displays a Won
        for y = 0 to 7
        lookup y,[0,36,36,0,0,66,60,0],datareg ' "Smile Face" Game Winning Image
        address = y+1 : datareg = datareg
        gosub maxwrite
        next y
    GameState_Losing:   'Displays a Lost
        for y = 0 to 7
        lookup y,[0,36,36,0,0,60,66,0],datareg ' "Sad Face" Game Losing Image
        gosub maxwrite
        next y
    Bombay, India
    Default Re: Stacker Arcade Game 8*8 LED Matrix
    It would help you a lot if you posted a small video of your working project here.
    May 2014
    Bombay, India
    Very nice.
    aron11's Avatar
    aron11 Guest
    Thanks for share…
    Very nice project!
    May 2014
    thanks... I'm in my last year for biomedical, so hopefully i can land a good job and start my electronics hobby again...
    May 2014
    Realized one day while working on a controller, if I added an opto-isolator to the schematic it would have gotten rid of the noise... but just a theory I had one day... graduating in may w00t!
  1. 8x8 LED Matrix - Car / Boat Game (16F872)
    By wellyboot in forum Code Examples
    Last Post: - 13th February 2014, 21:28
  2. LED Matrix display
    By Art in forum General
    Last Post: - 5th October 2013, 04:06
  3. led matrix problem
    By dellpc in forum mel PIC BASIC Pro
    Last Post: - 6th September 2011, 08:18
  4. 245 led matrix
    By cesar35 in forum General
    Last Post: - 24th May 2011, 03:32
  5. Help led matrix
    By mosbc69 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 19:54
