TRISC=%10000000 is missing to set portsc.7 as input.
Steve Earl www.datageo.co.uk
I did the input thing both ways...TRISC.7 = 1 and TRISC=%10000000 - no change
I have two HC-05's hooked up to the RX and TX ports. They are hooked up backwards from one another. So I see the menu show up on one terminal screen, and I see the echo of what I type(a mirror of what the MC is receiving) show up in the other terminal on my screen on a different BT-com port. The second BT (as well as the MC presumably) receives 1 or 2 or whatever I type. But the when the menus didnt respond, I added the SEROUT and 1500 pause (to read it) and underneath the menu it'll only output [00] everytime no matter what key I hit. Just to be certain I added the next line for a total of:
serout TX, 2, [cereal]
serout TX, 2, ["Dingleberry"]
pause 1500
and I get
[00]Dingleberry
then after 1.5 seonds, it dissappears and the Main Menu is reborn to await another keystroke.....
Serin RX, 2, 500, MainMenu, cereal
This line goes to MainMenu if nothing is received after 500 ms therefore [00]Dingleberry will only be printed if something is received.
What is going on?
Can you send the whole code again please?
you are correct. However, when that didnt work, I removed it again. But when its there, it just cycles back (basically blinks) to the Main Menu unless you send a keystroke, in which case you get [00]Dingleberry.
[00] is Null is it not? Is it possible somewhere in the serin process it's trying to take the char before or after my keystroke? I tried 11, and 23 tho and still returns [00] even though 11 and 23 showed on the receiving terminal. I even tried it with a wait command llike wait for "A" then take the next char. Still same thing. And that was straight from the PBP manual....
__config _FOSC_HS & _WDT_OFF & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
TRISC=%10000000
DEFINE OSC 12
el var PORTD.7
TRISD.7 = 0
low el
az var PORTB.5
TRISB.5 = 0
low az
dir var PORTD.5
TRISD.5 = 0
low dir
TX var PORTC.6
TRISC.6 = 0
RX var PORTC.7
CNT var word
cereal var byte
i var byte
goto MainMenu
CLR:
For i = 0 to 30
serout TX, 2, [10]
next i
MainMenu:
gosub CLR
serout Tx, 2, ["******** MAIN MENU ********", 13, 10, 10]
serout Tx, 2, [" 1. Start Homing Sequence", 13, 10]
serout Tx, 2, [" 2. Manual JOG Mode", 13, 10]
serout Tx, 2, [" 3. Auto-Acquire Satellite", 13, 10]
serout Tx, 2, [" 4. Stow Dish for Travel", 13, 10, 10]
serout Tx, 2, ["Enter Your Selection:", 13, 10]
If cereal = "1" then goto HomeDish
If cereal = "2" then goto JogMenu
If cereal = "3" then goto AutoAcquire
If cereal = "4" then goto StowDish
serout TX, 2, [cereal] 'For debugging only
pause 1500
goto MainMenu
HomeDish:
gosub CLR
serout Tx, 2, ["******** HOME DISH ********", 13, 10, 10]
serout Tx, 2, [" 1. Start Homing Sequence", 13, 10, 10]
serout Tx, 2, [" 2 Abort Homing", 13, 10, 10]
Serin RX, 2, cereal
if cereal = "1" then goto StartHoming
if cereal = "2" then goto MainMenu
goto HomeDish
JogMenu:
gosub CLR
serout TX, 2, [" JOG MENU ", 13, 10, 10]
serout TX, 2, ["1. Elevation", 13, 10]
serout tx, 2, ["2. Azimuth", 13, 10]
serout tx, 2, ["3. Skew", 13, 10]
serout tx, 2, ["4. Main Menu", 13, 10, 10]
serout tx, 2, ["Enter Your Selection:"]
serin RX, 2, cereal
goto MainMenu
AutoAcquire:
gosub CLR
serout TX, 2, [" AUTO-ACQUIRE ", 13, 10, 10]
serout TX, 2, ["*** UNDER CONSTRUCTION *** ", 13, 10]
pause 3000
goto MainMenu
StowDish:
gosub CLR
serout TX, 2, [" STOW DISH ", 13, 10, 10]
pause 3000
goto MainMenu
StartHoming:
gosub CLR
serout TX, 2, [" Begin Homing, Homie ", 13, 10, 10]
pause 3000
goto MainMenu
TestPattern:
HIGH el
low el
high dir
pause 50
high el
low el
low dir
HIGH az
low az
high dir
pause 50
high az
low az
low dir
goto TestPattern
