Pic16f1825 adcon0
Results 1 to 4 of 4
    Default Pic16f1825 adcon0
    i'm using PIC16F1825 for the first time and want to use RC2 as analog input.
    Therefore i want to use the internal voltage reference (4.096V).
    I set the FVRCON = %10000011.
    But there is an item in the ADCON0 that i don't understand...
    I think i have to use ADCON0 = %00011001 for using analog channel 6?
    But what means (bit6-2) "11111 = FVR (Fixed Voltage Reference) Buffer 1 Output?
    What is this for?
    Must i use this for my reference voltage?
    Thanks in advance
    best regards
    norbert
    Jan 2011
    Sydney, Australia
    Default Re: Pic16f1825 adcon0
    Hi Norbert,
    I used the PIC16F1825 in a recent project with ADC input on AN0.
    I used FRVCON = %11010011 to enable the fixed voltage reference and set the voltage to 4.096V.
    Your ADCON0 = %000110001 is correct for selecting AN6 as the ADC channel (RC2).
    To apply the fixed voltage reference to the ADC you must set bit 1-0 of ADCON1 to "11"
    In my application I used ADCON1 = %10100011 to right justify the output, set A/D clock to Fosc/32 and set Vref- to VSS.
    You may need to change the A/D clock selection depending on you own oscillator choice.
    Cheers
    Barry
    VK2XBP
    But what means (bit6-2) "11111 = FVR (Fixed Voltage Reference) Buffer 1 Output?[
    It simply selects the output of the FVR and "connects it" to the ADC input in order to sample it, just as any other input.
    What is this for?
    It can be used to "calibrate" the ADC when you're not actually using the FVR as VRef for the ADC.
    No, in your case, with the output of the FVR used as VRef for the ADC there's no need to sample the FVR output - it would/should Always return a result of 1023.
    Hello Barry / Henrik,
    thanks for reply, it helped me understanding this function.
    I did my settings this way - everything's fine.
    Thanks for help.
    Norbert
  1. PIC16F1825 unable to Light an LED
    By Lestat in forum mel PIC BASIC Pro
    Last Post: - 16th March 2013, 18:38
  2. Adcon0,adcon1 pic 16f877
    By Eden Zeminian in forum mel PIC BASIC Pro
    Last Post: - 25th April 2011, 22:00
  3. Replies: 5
    Last Post: - 10th April 2011, 12:48
  4. adcon0,adcon1
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 14th September 2009, 09:42
  5. ADC_Clock Vs ADCON0
    By locko in forum mel PIC BASIC Pro
    Last Post: - 16th August 2007, 15:09
