Creating 4 to 20MA ?
Results 1 to 11 of 11
    Default Creating 4 to 20MA ?
    do anyone have knowledge of how to do circuitry for outputting the industry standard of 4-20ma, a internet search for "circuitry of/for 4 to 20MA" was fruitless.
    Some devices give the MA output from internal means or external DC supply thus governing the current.
    thanks,
    don
    amgen
    PS; did I not call the thermal switch in dc motor early on ??!!
    Are you wanting to make a sensor that outputs the signal or wanting to know how to read the signal?
    If it is reading the signal you want this may help
    http://www.omega.com/techref/das/4-20ma.html
    If you are making you own sensor, what type and method are you planning?
    Here is an article about current sources.
    http://en.wikipedia.org/wiki/Current_source
    And some other stuff.
    http://www.sensorland.com/HowPage028.html
    http://en.wikipedia.org/wiki/Current_loop
    Yes you did, And a good call it was too !
    How did you know with the info given?
    Probably borrowed mister_e's crystal ball, speakin' of Mister_e, where the heck is he ?
    Steve is a magnet for accidents. Hope he is doing much better now after testing how strong a car is...
    Italy
    4-20mA Current Loop Primer:
    http://www.murata-ps.com/data/meters/dms-an20.pdf
    Best regards,
    Luciano
    Oct 2003
    holland
    Here a schematic diagram I always use when using pic pwm and analog out.
    Default 4 to 20
    thankyou for links which I read all.
    Would like to make PIC ckts to output the 4-20 MA stuff.
    what I know (maybe), recieve ma. is easy, just read V across a 100 to 250 ohm resister and scale/calculate or limit the a/d reading. PIC can do 10 bit but many products reach to 12 or 14 bits.
    Send or creating ma signal seems a little more involved, apparently needed is 12 to 24 vdc supply to be able to adjust for wire and other loop resistance ??
    Getting a good DC level (0 to 5) volts from PIC with 1000 or more resolution --- not so easy. See diagram, and how to set limits of 4 and 20 ma with resisters ???
    motor t-stat
    used simple process of elimination (mental process that is) the 2-A and F wires are generally all thats needed to run motor in both directions and more times than not, two small wires will be for temp sw.
    don
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    Default Re: Creating 4 to 20MA ?
    Hello, last night very nearly completely finished my hardware to read 4-20mA (24VDC) and generate a PWM 4-20mA (24VDC) ... Everything runs based on two LM358 with single source (one is supplied 12Vdc and the other to 24VDC). GND is shared between the two operational amplifiers.
    I share the diagram, if you need anything else, ask me and I will share it...
    To read the 4-20mA signal and place it on the display, as I was tired last night and I can not think of anything to work with floating point, implement the following lines:
    ADCIN 0, ent420
    nivel = ent420
    aux1=(ent420*100)/250            ;(V*100)/(R*100)
    aux1= aux1 *2
    ;****blabla bla
     LCDOUT $FE, 1
    LCDOut $fe,2,"Sal: ",DEC4 aux1,"mA"
    to generate the pwm to take me filter 0-5Vdc to create the 4-20mA, implement these lines:
    PWM PORTC.2,nivelAUX,100  ;nivel PWM = (Vout * 255) / V.Fuente
    Sorry for my spanglish!!!!
    En Español
    Hola, anoche termine casi casi por completo mi hardware para poder leer señales 4-20mA (24Vcc) y generar con un PWM 4-20mA (24Vcc)... Todo corre en base a dos LM358 con fuente simple (uno se alimenta a 12Vcc y el otro a 24Vcc). GND se comparte entre ambos amplificadores operacionales.
    Te comparto el diagrama, si necesitas algo mas, me pedis y te lo comparto
    Para leer la señal 4-20mA y colocarlo en el display, como anoche estaba cansado y no se me ocurria nada para trabajar con punto flotante, implemente las siguientes lineas:
    ADCIN 0, ent420
    nivel = ent420
    aux1= aux1 *2
    ;****blabla bla
     LCDOUT $FE, 1
    para generar el pwm que me lleve el filtro de 0-5Vcc para crear los 4-20mA, implemente estas lineas:
  1. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 05:21
  2. Microcontroller with 2 way paging application problem
  3. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 13:55
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
