I2C lcd ( arduino ) with PICBASIC, help
Results 1 to 40 of 93
    Jun 2008
    Varese , Italy
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    That is clear to me now.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio
    I am working on the program by adding commands as you can see in the picture.
    Let me know when you are ready.
    Jun 2008
    Varese , Italy
    Steve, very good result !
    I think It will help a lot of people too .
    I am wait to receive the item ( about 20 days ).
    Could you please post the code : I will start to study it .
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Ambrogio
    Here it is. This is a simple test program for PBP2.5 or lower. Anything you do not understand please ask. The next step is to include the command selection inside the LCD_WRITE subroutine.
    '*  Name    : I2CLCD.BAS
    '*  Author  : Steve Earl
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS]
    '*          : All Rights Reserved
    '*  Date    : 17/07/2014
    '*  Version : 1.0
    '*  Notes   : Serial I2C LCD using PBP 2.5
    '*          : PCF8574T I2C port expander 20x4 LCD
    define OSC 40     ' set the correct speed here!!
    'DEFINE I2C_SLOW 1
    SDA         VAR PORTD.2       ; I2C Data pin
    SCL         VAR PORTD.3       ; I2C Clock Pin
    LCD_Addr CON 78               ; PCF8574T address
    'LCD_BuffSize    CON 30
    'LCD_Buff        VAR BYTE[LCD_BuffSize]
    'LCD_BuffAddr    CON EXT : @LCD_BuffAddr = _LCD_Buff
    'LCD_BuffLen     VAR WORD        ; Length of data in buffer
    LCD_Data        VAR BYTE        ; Data to Send to LCD
    LCD_Byte        VAR BYTE        ; Nibbles to Send
    LCD_RS          VAR LCD_Byte.0  ; Register Select bit
    LCD_RW          VAR LCD_Byte.1  ; Read/Write bit
    LCD_E           VAR LCD_Byte.2  ; Enable bit
    LCD_BackLight   VAR LCD_Byte.3  ; Backlight 1=ON
    LCD_WriteMode   VAR BYTE        ; 1=LowNibble, 2=HighNibble, 3=Both
    'LCD_CommandMode VAR BIT         ; Indicates next byte is a command
    LCD_Byte2       VAR BYTE        ; Same nibble without E bit
    'LCD_Idx         VAR BYTE
    seconds var byte
    minutes var byte
    hours   var byte
    Init:
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 250                           ; LCD Power-on delay
    LCD_Backlight = 1                   ; Backlight On
    LCD_RW = 0                          ; Write to LCD
    LCD_RS = 0                          ; Command Register
    LCD_WriteMode = 1                   ;-- Low Nibbles only
    LCD_Data = 3                        ; Software Reset 3 times
    gosub LCD_Write : PAUSEUS 6000
    gosub LCD_Write : PAUSEUS 1000
    LCD_Data = 2                        ; Start 4-bit mode
    LCD_WriteMode = 3                   ;-- Both Nibbles
    LCD_Data = $28 : gosub LCD_Write    ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C : gosub LCD_Write    ; Display ON
    LCD_Data = $01 : gosub LCD_Write    ; Clear Screen
    PAUSE 50
    LCD_Data = $06 : gosub LCD_Write    ; Entry Mode
    PAUSE 2                             ; Let command finish
    LCD_RS = 1                          ;Switch to Data
    ;Print Static Background to LCD
    LCD_Data = " " : gosub LCD_Write    ;Line 1
    LCD_Data = "S" : gosub LCD_Write
    LCD_Data = "t" : gosub LCD_Write
    LCD_Data = "e" : gosub LCD_Write
    LCD_Data = "v" : gosub LCD_Write
    LCD_Data = "E" : gosub LCD_Write
    LCD_Data = "a" : gosub LCD_Write
    LCD_Data = "r" : gosub LCD_Write
    LCD_Data = "l" : gosub LCD_Write
    lcd_rs = 0                          ;Command is next
    lcd_data=$a8 : gosub lcd_write      ;Move to start of line 2
    pause 2
    lcd_rs = 1                          ;Switch back to Data
    LCD_Data = " " : gosub LCD_Write    ;Line 2
    LCD_Data = "D" : gosub LCD_Write
    LCD_Data = "g" : gosub LCD_Write
    LCD_Data = "o" : gosub LCD_Write
    LCD_Data = "L" : gosub LCD_Write
    LCD_Data = "i" : gosub LCD_Write
    LCD_Data = "m" : gosub LCD_Write
    LCD_Data = "d" : gosub LCD_Write
    lcd_data=$99 : gosub lcd_write      ;Move to line 3 col 6
    pause 2
    LCD_Data = "*" : gosub LCD_Write    ;Line 3
    lcd_data=$D8 : gosub lcd_write      ;Move to line 4 col 5
    pause 2
    LCD_Data = "T" : gosub LCD_Write    ;Line 4
    LCD_Data = "s" : gosub LCD_Write
    LCD_Data = "P" : gosub LCD_Write
    pause 5000
    pause 2
    LCD_Data = " " : gosub LCD_Write    ;Clear line 4 and set clock
    LCD_Data = "0" : gosub LCD_Write
    LCD_Data = ":" : gosub LCD_Write
    main:                               ;Count seconds and refresh the clock
    for hours = 0 to 23
    for minutes = 0 to 59
    for seconds = 0 to 59
    lcd_data=$DA : gosub lcd_write      ;Move to line 4 col 7
    pause 2
    LCD_Data = (hours dig 1)+48 : gosub LCD_Write
    LCD_Data = (hours dig 0)+48 : gosub LCD_Write
    LCD_Data = (minutes dig 1)+48 : gosub LCD_Write
    LCD_Data = (minutes dig 0)+48 : gosub LCD_Write
    LCD_Data = (seconds dig 1)+48 : gosub LCD_Write
    LCD_Data = (seconds dig 0)+48 : gosub LCD_Write
    next    ;second
    next    ;minute
    next    ;hour
    LCD_WRITE:
       LCD_E = 1
       IF LCD_WriteMode.1 = 1 THEN                             ; Write High Nibble
         LCD_Byte = (LCD_Byte & $0F) | (LCD_Data  & $F0)
         LCD_Byte2 = LCD_Byte & $FB
         I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
       IF LCD_WriteMode.0 = 1 THEN                             ; Write Low Nibble
         LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio,
    Any feedback?
    If you have no questions then I will post the next improvement which includes the command in the LCD_Write subroutine. I am now looking at using arrays as the next step.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by EarlyBird2 View Post
    Ambrogio,
    Any feedback?
    Here it is! including LOOKUP and ARRAYs.
    '*  Name    : I2CLCD.BAS                                        *
    '*  Author  : Steve Earl                                        *
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 17/07/2014                                        *
    '*  Notes   : Serial I2C LCD using PBP 2.5                      *
    '*          : PCF8574T I2C port expander 20x4 LCD               *
    'DEFINE I2C_SLOW 1
    LCD_Line_1 con $80
    LCD_Line_2 con $A8
    LCD_Line_3 con $94
    LCD_Line_4 con $D4
    LCD_BuffSize    CON 22
    LCD_BuffLen     VAR byte        ; Length of data in buffer
    LCD_Idx         VAR BYTE
    seconds var byte
    minutes var byte
    hours   var byte
    Init:
    LCD_buff[0] = $28                   ; Function Set, 4-bit, 2-line
    LCD_buff[1] = $0C                   ; Display ON
    LCD_buff[2] = $FE
    LCD_buff[3] = $06                   ; Entry Mode
    LCD_buff[4] = $FE
    LCD_buff[5] = $01                   ; Clear Screen
    lcd_bufflen = 6
    gosub LCD_Buff_Write
    for lcd_idx = 0 to 85
                   ;|                    | 20 characters
    lookup lcd_idx,["     Steve Earl     ",_            ;20
     $FE,lcd_line_2,"   Datageo Limited  ",_            ;+22 = 42
     $FE,lcd_line_3,"     **********     ",_            ;+22 = 64
     $FE,lcd_line_4,"      00:00:00      "],lcd_data    ;+22 = 86  (0-85)
     gosub lcd_write
    next
    ;Set up fixed buffer characters
    lcd_bufflen = 10                     ;8 characters in clock + $FE + LCD_Line
    LCD_buff[0] = $FE                   ;Command is next
    LCD_buff[1] = lcd_line_4 + 6        ;Move to line 4 col 7
    LCD_buff[4] = ":"                   ;Fixed characters
    LCD_buff[7] = ":"                   ;       "
    for hours = 0 to 23
                LCD_buff[2] = (hours dig 1)+48
                LCD_buff[3] = (hours dig 0)+48
                LCD_buff[5] = (minutes dig 1)+48
                LCD_buff[6] = (minutes dig 0)+48
                LCD_buff[8] = (seconds dig 1)+48
                LCD_buff[9]= (seconds dig 0)+48
                gosub lcd_buff_write
            next    ;second
        next    ;minute
    next    ;hour
    LCD_WRITE:
    if lcd_data = $FE then
        lcd_commandMode = 1                 ;Next byte Command
        lcd_rs = 0                          ;Switch to Command Register
        LCD_E = 1
        if lcd_commandmode then
         lcd_commandmode = 0              ;Reset to data
         lcd_rs = 1                       ;Switch to Data Register
         pause 2
    Lcd_Buff_Write:
     for lcd_idx = 0 to lcd_bufflen - 1
      lcd_data=lcd_buff[LCD_idx]
      gosub LCD_Write
     next
    Jun 2008
    Varese , Italy
    Steve,
    I am sorry for the delayed reply : I am not at home on those days.
    I had a look to your code : it is a good work and I am waiting to check it soon when the hardware is arrived .
    Thanks a lot for the assistance.
    I think your work will help a lot of people .
    Ambrogio
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 23:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 17:13
Members who have read this thread : 4
