I2C lcd ( arduino ) with PICBASIC, help
Results 1 to 40 of 93
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    does 2.5 have the dig command
    The DIG modifier has been there forever....
    EN82fn
    Jun 2008
    Varese , Italy
    Thanks to all of you for the assistance.
    What is the dig modifier please ?
    Thnaks
    Ambrogio
    Sep 2009
    From manual:
    DIG returns the value of a decimal digit. Input the digit number (0 – 9, with 0 being the rightmost digit). DIG returns the value of the decimal digit that you specified. DIG is commonly used to distill BCD digits from numeric values and to isolate single digits for display on seven-segment LCD.
    B0 = 123 ' Set B0 to 123
    B1 = B0 DIG 2 ' Sets B1 to 1 (digit 2 of 123)
    Jun 2008
    Varese , Italy
    That is clear to me now.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio
    I am working on the program by adding commands as you can see in the picture.
    Let me know when you are ready.
    Jun 2008
    Varese , Italy
    Steve, very good result !
    I think It will help a lot of people too .
    I am wait to receive the item ( about 20 days ).
    Could you please post the code : I will start to study it .
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Ambrogio
    Here it is. This is a simple test program for PBP2.5 or lower. Anything you do not understand please ask. The next step is to include the command selection inside the LCD_WRITE subroutine.
    '*  Name    : I2CLCD.BAS
    '*  Author  : Steve Earl
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS]
    '*          : All Rights Reserved
    '*  Date    : 17/07/2014
    '*  Version : 1.0
    '*  Notes   : Serial I2C LCD using PBP 2.5
    '*          : PCF8574T I2C port expander 20x4 LCD
    define OSC 40     ' set the correct speed here!!
    'DEFINE I2C_SLOW 1
    SDA         VAR PORTD.2       ; I2C Data pin
    SCL         VAR PORTD.3       ; I2C Clock Pin
    LCD_Addr CON 78               ; PCF8574T address
    'LCD_BuffSize    CON 30
    'LCD_Buff        VAR BYTE[LCD_BuffSize]
    'LCD_BuffAddr    CON EXT : @LCD_BuffAddr = _LCD_Buff
    'LCD_BuffLen     VAR WORD        ; Length of data in buffer
    LCD_Data        VAR BYTE        ; Data to Send to LCD
    LCD_Byte        VAR BYTE        ; Nibbles to Send
    LCD_RS          VAR LCD_Byte.0  ; Register Select bit
    LCD_RW          VAR LCD_Byte.1  ; Read/Write bit
    LCD_E           VAR LCD_Byte.2  ; Enable bit
    LCD_BackLight   VAR LCD_Byte.3  ; Backlight 1=ON
    LCD_WriteMode   VAR BYTE        ; 1=LowNibble, 2=HighNibble, 3=Both
    'LCD_CommandMode VAR BIT         ; Indicates next byte is a command
    LCD_Byte2       VAR BYTE        ; Same nibble without E bit
    'LCD_Idx         VAR BYTE
    seconds var byte
    minutes var byte
    hours   var byte
    Init:
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 250                           ; LCD Power-on delay
    LCD_Backlight = 1                   ; Backlight On
    LCD_RW = 0                          ; Write to LCD
    LCD_RS = 0                          ; Command Register
    LCD_WriteMode = 1                   ;-- Low Nibbles only
    LCD_Data = 3                        ; Software Reset 3 times
    gosub LCD_Write : PAUSEUS 6000
    gosub LCD_Write : PAUSEUS 1000
    LCD_Data = 2                        ; Start 4-bit mode
    LCD_WriteMode = 3                   ;-- Both Nibbles
    LCD_Data = $28 : gosub LCD_Write    ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C : gosub LCD_Write    ; Display ON
    LCD_Data = $01 : gosub LCD_Write    ; Clear Screen
    PAUSE 50
    LCD_Data = $06 : gosub LCD_Write    ; Entry Mode
    PAUSE 2                             ; Let command finish
    LCD_RS = 1                          ;Switch to Data
    ;Print Static Background to LCD
    LCD_Data = " " : gosub LCD_Write    ;Line 1
    LCD_Data = "S" : gosub LCD_Write
    LCD_Data = "t" : gosub LCD_Write
    LCD_Data = "e" : gosub LCD_Write
    LCD_Data = "v" : gosub LCD_Write
    LCD_Data = "E" : gosub LCD_Write
    LCD_Data = "a" : gosub LCD_Write
    LCD_Data = "r" : gosub LCD_Write
    LCD_Data = "l" : gosub LCD_Write
    lcd_rs = 0                          ;Command is next
    lcd_data=$a8 : gosub lcd_write      ;Move to start of line 2
    pause 2
    lcd_rs = 1                          ;Switch back to Data
    LCD_Data = " " : gosub LCD_Write    ;Line 2
    LCD_Data = "D" : gosub LCD_Write
    LCD_Data = "g" : gosub LCD_Write
    LCD_Data = "o" : gosub LCD_Write
    LCD_Data = "L" : gosub LCD_Write
    LCD_Data = "i" : gosub LCD_Write
    LCD_Data = "m" : gosub LCD_Write
    LCD_Data = "d" : gosub LCD_Write
    lcd_data=$99 : gosub lcd_write      ;Move to line 3 col 6
    pause 2
    LCD_Data = "*" : gosub LCD_Write    ;Line 3
    lcd_data=$D8 : gosub lcd_write      ;Move to line 4 col 5
    pause 2
    LCD_Data = "T" : gosub LCD_Write    ;Line 4
    LCD_Data = "s" : gosub LCD_Write
    LCD_Data = "P" : gosub LCD_Write
    pause 5000
    pause 2
    LCD_Data = " " : gosub LCD_Write    ;Clear line 4 and set clock
    LCD_Data = "0" : gosub LCD_Write
    LCD_Data = ":" : gosub LCD_Write
    main:                               ;Count seconds and refresh the clock
    for hours = 0 to 23
    for minutes = 0 to 59
    for seconds = 0 to 59
    lcd_data=$DA : gosub lcd_write      ;Move to line 4 col 7
    pause 2
    LCD_Data = (hours dig 1)+48 : gosub LCD_Write
    LCD_Data = (hours dig 0)+48 : gosub LCD_Write
    LCD_Data = (minutes dig 1)+48 : gosub LCD_Write
    LCD_Data = (minutes dig 0)+48 : gosub LCD_Write
    LCD_Data = (seconds dig 1)+48 : gosub LCD_Write
    LCD_Data = (seconds dig 0)+48 : gosub LCD_Write
    next    ;second
    next    ;minute
    next    ;hour
    LCD_WRITE:
       LCD_E = 1
       IF LCD_WriteMode.1 = 1 THEN                             ; Write High Nibble
         LCD_Byte = (LCD_Byte & $0F) | (LCD_Data  & $F0)
         LCD_Byte2 = LCD_Byte & $FB
         I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
       IF LCD_WriteMode.0 = 1 THEN                             ; Write Low Nibble
         LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 23:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 17:13
Members who have read this thread : 4
