I2C lcd ( arduino ) with PICBASIC, help
Results 1 to 40 of 93
    Jun 2008
    Varese , Italy
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    Hi Steve,
    no change using both codes.
    I still have no backlight and no text.
    I appreciate your assistance on this matter: thanks a lot.
    I am not skilled enough to go deeper in those kind of codes ...
    Ambrogio
    Sep 2009
    Can I make one suggestion?
    First connect few led on output of PCF8574, and control them. So you are sure that I2C communication woks.
    Second connect LCD to PIC directly, get timing and control right.
    Then just combine that two.
    Jun 2009
    Sc*nthorpe, UK
    Try again
    DEFINE OSC 40 ' 10 MHz XTAL AND X 4 INTERNAL PLL
    DEFINE I2C_SLOW 1
    SDA         VAR PORTD.2       ; I2C Data pin
    SCL         VAR PORTD.3       ; I2C Clock Pin
    LCD_Addr CON 78
    'LCD_BuffSize    CON 30
    'LCD_Buff        VAR BYTE[LCD_BuffSize]
    'LCD_BuffAddr    CON EXT : @LCD_BuffAddr = _LCD_Buff
    'LCD_BuffLen     VAR WORD        ; Length of data in buffer
    LCD_Data        VAR BYTE        ; Data to Send to LCD
    LCD_Byte        VAR BYTE        ; Nibbles to Send
    LCD_RS          VAR LCD_Byte.0  ; Register Select bit
    LCD_RW          VAR LCD_Byte.1  ; Read/Write bit
    LCD_E           VAR LCD_Byte.2  ; Enable bit
    LCD_BackLight   VAR LCD_Byte.3  ; Backlight 0=ON
    LCD_WriteMode   VAR BYTE        ; 1=LowNibble, 2=HighNibble, 3=Both
    LCD_CommandMode VAR BIT         ; Indicates next byte is a command
    LCD_Byte2       VAR BYTE        ; Same nibble without E bit
    LCD_Idx         VAR BYTE
    testmode        var byte
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 1000            ; LCD Power-on delay
    LCD_Backlight = 1     ; Backlight OFF
    LCD_RW = 0            ; Write to LCD
    LCD_RS = 0            ; Command Register
    LCD_WriteMode = 1     ;-- Low Nibbles only
    LCD_Data = 3          ; Reset 3 times
    gosub LCD_Write
    PAUSEUS 6000
    gosub LCD_Write
    PAUSEUS 1000
    gosub LCD_Write
    PAUSEUS 1000
    LCD_Data = 2          ; Start 4-bit mode
    gosub LCD_Write
    PAUSEUS 1000
    LCD_WriteMode = 3     ;-- Both Nibbles
    LCD_Data = $28
    gosub LCD_Write      ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C
    gosub LCD_Write      ; Display ON
    LCD_Data = $01
    gosub LCD_Write      ; Clear Screen
    PAUSE 2
    LCD_Data = $06
    gosub LCD_Write      ; Entry Mode
    PAUSE 2               ; Let command finish
    LCD_RS = 1   ' this is data
    LCD_WRITE:
          LCD_E = 1
       IF LCD_WriteMode.1 = 1 THEN                             ; Write High Nibble
         LCD_Byte = (LCD_Byte & $0F) | (LCD_Data  & $F0)
         LCD_Byte2 = LCD_Byte & $FB
         I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
       IF LCD_WriteMode.0 = 1 THEN                             ; Write Low Nibble
         LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
    I2CWRITE SDA,SCL, LCD_Addr, [%00000000] ' bck_lt= off
    PAUSE 200
    I2CWRITE SDA,SCL, LCD_Addr, [%00001000] ' bck_lt=on
    PAUSE 200
    LCD_Data = "T"
    gosub LCD_Write: PAUSEUS 50
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    LCD_Data = "-"
    goto Main
    Jun 2009
    Sc*nthorpe, UK
    The problem could be with the delay on power up not being long enough for the LCD to initialise before the PIC starts.
    Adjust this line and test
    and please let me know the result.
    Jun 2008
    Varese , Italy
    Dear Steve:
    Your suggested test gave me the response on the lack of operation. ( see the attached).
    The pcf has P0, P5 and P6 not working. This is the reason of the trouble.
    I will no longer buy components on Ebay expecially if chinese. That is very bad.
    I have no words to express my state. I want to apologize .
    Thanks for the help given to me since the beginning.
    Will try to buy another expander board: do you know some reliable seller in Europe ?
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Dear Steve:
    Ambrogio
    No problem and no need to apologise. Could you do some more testing on this board?
    Check the voltages on the P0 to P7 pins when this program is running.
    DEFINE I2C_SLOW 1
    C VAR portd.3 ' S_CLOCK
    D VAR portd.2 ' S_DATA
    ADDR VAR BYTE
    ADDR = %01001110 ' dec 78 , hex 4E
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT2
    RS VAR LCD_CMD.BIT0
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    MAIN:
    I2CWRITE D, C, ADDR, [%00000000] ' port off
    PAUSE 200
    I2CWRITE D, C, ADDR, [%11111111] ' port on
    PAUSE 200
    GOTO MAIN
    If all pins change then the PCF8574 chip is good indicating that the fault is either bad soldering or bad PCB track. It is possible to solder jumper wire direct to pins for a temporary repair.
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 23:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 17:13
Members who have read this thread : 4
