I2C lcd ( arduino ) with PICBASIC, help
Results 1 to 40 of 93
    Jun 2008
    Varese , Italy
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    Steve,
    Thanks a lot for the intersest.
    It does not work. I added the bck_lt flashing in the main loop just to see if the communication is good > the bck_lt comes ond goes correctly.
    I am attaching the whole program
    Ambrogio
    '* Name : RKPK40 board pic18F452 40 MHz *
    '* Notice : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 23/06/2014 *
    '* Version : 1.0 *
    '* Notes : *
    ';Program Configuration Register 1H
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    ';Program Configuration Register 2L
    @ __CONFIG _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
    ';Program Configuration Register 2H
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    ';Program Configuration Register 3H
    @ __CONFIG _CONFIG3H, _CCP2MX_OFF_3H
    ';Program Configuration Register 4L
    @ __CONFIG _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ';Program Configuration Register 5L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    ';Program Configuration Register 5H
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    ';Program Configuration Register 6L
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    ';Program Configuration Register 6H
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    ';Program Configuration Register 7L
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    ';Program Configuration Register 7H
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    DEFINE OSC 40 ' 10 MHz XTAL AND X 4 INTERNAL PLL
    DEFINE I2C_SLOW 1
    SDA VAR PORTD.2 ; I2C Data pin
    SCL VAR PORTD.3 ; I2C Clock Pin
    LCD_Addr CON 78
    'LCD_BuffSize CON 30
    'LCD_Buff VAR BYTE[LCD_BuffSize]
    'LCD_BuffAddr CON EXT : @LCD_BuffAddr = _LCD_Buff
    'LCD_BuffLen VAR WORD ; Length of data in buffer
    LCD_Data VAR BYTE ; Data to Send to LCD
    LCD_Byte VAR BYTE ; Nibbles to Send
    LCD_RS VAR LCD_Byte.0 ; Register Select bit
    LCD_RW VAR LCD_Byte.1 ; Read/Write bit
    LCD_E VAR LCD_Byte.2 ; Enable bit
    LCD_BackLight VAR LCD_Byte.3 ; Backlight 0=ON
    LCD_WriteMode VAR BYTE ; 1=LowNibble, 2=HighNibble, 3=Both
    LCD_CommandMode VAR BIT ; Indicates next byte is a command
    LCD_Byte2 VAR BYTE ; Same nibble without E bit
    LCD_Idx VAR BYTE
    testmode var byte
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 250 ; LCD Power-on delay
    LCD_Backlight = 1 ; Backlight OFF
    LCD_RW = 0 ; Write to LCD
    LCD_RS = 0 ; Command Register
    LCD_WriteMode = 1 ;-- Low Nibbles only
    LCD_Data = 3 ; Reset 3 times
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = 2 ; Start 4-bit mode
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_WriteMode = 3 ;-- Both Nibbles
    LCD_Data = $28
    gosub LCD_Write_ ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C
    gosub LCD_Write_ ; Display ON
    LCD_Data = $01
    gosub LCD_Write_ ; Clear Screen
    PAUSE 2
    LCD_Data = $06
    gosub LCD_Write_ ; Entry Mode
    PAUSE 2 ; Let command finish
    LCD_WRITE_:
    LCD_E = 1
    IF LCD_WriteMode.1 = 1 THEN ; Write High Nibble
    LCD_Byte = (LCD_Byte & $0F) | (LCD_Data & $F0)
    LCD_Byte2 = LCD_Byte & $FB
    I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
    IF LCD_WriteMode.0 = 1 THEN ; Write Low Nibble
    LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    pause 5000
    i2cwrite sda, scl, LCD_addr, [0] ' back_lt blinking
    i2cwrite sda, scl, LCD_Addr,[%00010000]
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Steve,
    Ambrogio
    DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_RS = 1   ' this is data
    LCD_WRITE_:
       LCD_E = 1
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    I over simplified the program!
    need to add this line
    LCD_RS = 1 ' this is data highlighted in red above. This switches from command mode to data. It was in command mode that is why your back_lt instructions worked. An excellent clue for me.
    I am not sure about these lines
    LCD_Data = $28
    and what the location addresses are to position the cursor at the beginning of each line.
    Have you a datasheet for this LCD?
    When this simple example is working we can add Command/Data switching which we will obviously need to have. I will follow Darrel's method as close as possible, he uses $FE to indicate the next byte is a command and switches to command mode for one byte then back to data.
    Plenty for me to think about.
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 18:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 22:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 02:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 18:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 16:13
