I2C lcd ( arduino ) with PICBASIC, help - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 93
  1. #41
    Jun 2008
    Varese , Italy
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    Hi Steve,
    I am back again on this LCD ...
    I have repaired the programmer and so I had the occasion to test the program.
    > Back light does not come on at all .
    > nothing is displayed on the LCD
    If you have something more to suggest, I am ready to go on .
    Ambrogio
  2. #42
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Hi Steve,
    Ambrogio
    Not good news then!
    I need to refresh my memory. Post the full code you are using please.
  3. #43
    Jun 2008
    Varese , Italy
    here it is:
    DEFINE OSC 40 ' 10 MHz XTAL AND X 4 INTERNAL PLL
    DEFINE I2C_SLOW 1
    SDA VAR PORTD.2 ; I2C Data pin
    SCL VAR PORTD.3 ; I2C Clock Pin
    LCD_Addr CON 78
    'LCD_BuffSize CON 30
    'LCD_Buff VAR BYTE[LCD_BuffSize]
    'LCD_BuffAddr CON EXT : @LCD_BuffAddr = _LCD_Buff
    'LCD_BuffLen VAR WORD ; Length of data in buffer
    LCD_Data VAR BYTE ; Data to Send to LCD
    LCD_Byte VAR BYTE ; Nibbles to Send
    LCD_RS VAR LCD_Byte.0 ; Register Select bit
    LCD_RW VAR LCD_Byte.1 ; Read/Write bit
    LCD_E VAR LCD_Byte.2 ; Enable bit
    LCD_BackLight VAR LCD_Byte.3 ; Backlight 0=ON
    LCD_WriteMode VAR BYTE ; 1=LowNibble, 2=HighNibble, 3=Both
    LCD_CommandMode VAR BIT ; Indicates next byte is a command
    LCD_Byte2 VAR BYTE ; Same nibble without E bit
    LCD_Idx VAR BYTE
    testmode var byte
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 250 ; LCD Power-on delay
    LCD_Backlight = 1 ; Backlight OFF
    LCD_RW = 0 ; Write to LCD
    LCD_RS = 0 ; Command Register
    LCD_WriteMode = 1 ;-- Low Nibbles only
    LCD_Data = 3 ; Reset 3 times
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = 2 ; Start 4-bit mode
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_WriteMode = 3 ;-- Both Nibbles
    LCD_Data = $28
    gosub LCD_Write_ ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C
    gosub LCD_Write_ ; Display ON
    LCD_Data = $01
    gosub LCD_Write_ ; Clear Screen
    PAUSE 2
    LCD_Data = $06
    gosub LCD_Write_ ; Entry Mode
    PAUSE 2 ; Let command finish
    LCD_RS = 1 ' this is data
    LCD_WRITE_:
    LCD_E = 1
    IF LCD_WriteMode.1 = 1 THEN ; Write High Nibble
    LCD_Byte = (LCD_Byte & $0F) | (LCD_Data & $F0)
    LCD_Byte2 = LCD_Byte & $FB
    I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
    IF LCD_WriteMode.0 = 1 THEN ; Write Low Nibble
    LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    Jun 2009
    Sc*nthorpe, UK
    Please use code tags as it is easier for me to read.
  5. #45
    Jun 2009
    Sc*nthorpe, UK
    here it is:
    DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
       LCD_E = 1
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    Need to add pauseus!
    LCD_Data = "T"
    gosub LCD_Write_: PAUSEUS 50
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    Jun 2009
    Sc*nthorpe, UK
    And to test backlight is working try
    LCD_Backlight = 0
    LCD_Data = "T"
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    LCD_Backlight = 1
    LCD_Data = "-"
    Jun 2008
    Varese , Italy
    Steve,
    I uploaded the two codes you have sent to me and checked them one at the time :
    > backlight is still not working
    > lcd show nothing
    Ambrogio
  8. #48
    Jun 2009
    Sc*nthorpe, UK
    Is the address correct? It is 78 in the code.
    Try your code from post #24 as this did control the backlight.
  9. #49
    Jun 2008
    Varese , Italy
    Steve,
    this code still works well:
    Thanks ,Ambrogio
    DEFINE I2C_SLOW 1
    C VAR portd.3 ' S_CLOCK
    D VAR portd.2 ' S_DATA
    ADDR VAR BYTE
    ADDR = %01001110 ' dec 78 , hex 4E
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT2
    RS VAR LCD_CMD.BIT0
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    MAIN:
    I2CWRITE D, C, ADDR, [%00000000] ' bck_lt= off
    PAUSE 200
    I2CWRITE D, C, ADDR, [%00001000] ' bck_lt=on
    PAUSE 200
    GOTO MAIN
  10. #50
    Jun 2009
    Sc*nthorpe, UK
    Steve,
    Thanks ,Ambrogio
    DEFINE I2C_SLOW 1
    ADDR VAR BYTE
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT2
    RS VAR LCD_CMD.BIT0
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    MAIN:
    PAUSE 200
    PAUSE 200
    GOTO MAIN
    This works because you can see the backlight turn on and off. This tells me the LCD is working and the address is correct. Unfortunately that has eliminated the obvious. I will dig deeper into Darrel's code as I can not see anything that would stop it working.
  11. #51
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by EarlyBird2 View Post
    I have studied the HD44780 and PCF8574 datasheets and compared them to Darell's code and found as expected that his code follows the datasheets precisely. I compared the code
    DEFINE I2C_SLOW 1
    ADDR VAR BYTE
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT2
    RS VAR LCD_CMD.BIT0
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    MAIN:
    PAUSE 200
    PAUSE 200
    GOTO MAIN
    with Darrel's and noticed the I2C_SLOW definition is not included in his code. I then looked at I2CWRITE in the manual and noticed that PAUSE 10 is used to allow time for the transfer to complete again this is not included in Darrel's code.
    What does this indicate is the question?
    I compared PBP2.5 and pbp3 manuals and the I2CWRITE instruction is the same. I wondered if the pause in PBP3 is not needed as the compiler takes care of the I2C being busy.
    One step at a time.
    First remove the I2C_SLOW and test
    'DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
       LCD_E = 1
    LCD_Backlight = 0
    LCD_Data = "T"
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    LCD_Backlight = 1
    LCD_Data = "-"
    Then add pause 10 delays
    'DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
       LCD_E = 1
         I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte]
         PAUSE 10
         I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte2]
         PAUSE 10
         PAUSE 10
         PAUSE 10
    LCD_Backlight = 0
    LCD_Data = "T"
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    LCD_Backlight = 1
    LCD_Data = "-"
    and let me know the outcome.
    I will continue looking for answers.
  12. #52
    Jun 2008
    Varese , Italy
    Hi Steve,
    no change using both codes.
    I still have no backlight and no text.
    I appreciate your assistance on this matter: thanks a lot.
    I am not skilled enough to go deeper in those kind of codes ...
    Ambrogio
  13. #53
    Sep 2009
    Can I make one suggestion?
    First connect few led on output of PCF8574, and control them. So you are sure that I2C communication woks.
    Second connect LCD to PIC directly, get timing and control right.
    Then just combine that two.
  14. #54
    Jun 2009
    Sc*nthorpe, UK
    Try again
    DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    PAUSE 1000            ; LCD Power-on delay
    gosub LCD_Write
    PAUSEUS 6000
    gosub LCD_Write
    PAUSEUS 1000
    gosub LCD_Write
    PAUSEUS 1000
    gosub LCD_Write
    PAUSEUS 1000
    LCD_Data = $28
    gosub LCD_Write      ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C
    gosub LCD_Write      ; Display ON
    LCD_Data = $01
    gosub LCD_Write      ; Clear Screen
    PAUSE 2
    LCD_Data = $06
    gosub LCD_Write      ; Entry Mode
    LCD_WRITE:
          LCD_E = 1
    I2CWRITE SDA,SCL, LCD_Addr, [%00000000] ' bck_lt= off
    PAUSE 200
    I2CWRITE SDA,SCL, LCD_Addr, [%00001000] ' bck_lt=on
    PAUSE 200
    LCD_Data = "T"
    gosub LCD_Write: PAUSEUS 50
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    LCD_Data = "-"
    goto Main
  15. #55
    Jun 2009
    Sc*nthorpe, UK
    The problem could be with the delay on power up not being long enough for the LCD to initialise before the PIC starts.
    Adjust this line and test
    and please let me know the result.
  16. #56
    Jun 2008
    Varese , Italy
    Dear Steve:
    Your suggested test gave me the response on the lack of operation. ( see the attached).
    The pcf has P0, P5 and P6 not working. This is the reason of the trouble.
    I will no longer buy components on Ebay expecially if chinese. That is very bad.
    I have no words to express my state. I want to apologize .
    Thanks for the help given to me since the beginning.
    Will try to buy another expander board: do you know some reliable seller in Europe ?
    Ambrogio
  17. #57
    Jun 2009
    Sc*nthorpe, UK
    Dear Steve:
    Ambrogio
    No problem and no need to apologise. Could you do some more testing on this board?
    Check the voltages on the P0 to P7 pins when this program is running.
    DEFINE I2C_SLOW 1
    ADDR VAR BYTE
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT2
    RS VAR LCD_CMD.BIT0
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    MAIN:
    I2CWRITE D, C, ADDR, [%00000000] ' port off
    PAUSE 200
    I2CWRITE D, C, ADDR, [%11111111] ' port on
    PAUSE 200
    GOTO MAIN
    If all pins change then the PCF8574 chip is good indicating that the fault is either bad soldering or bad PCB track. It is possible to solder jumper wire direct to pins for a temporary repair.
  18. #58
    are you sure the new board has 8574t on it not a 8574A ?
    that might make a world of difference
  19. #59
    Jun 2009
    Sc*nthorpe, UK
    =richard;127791]are you sure the new board has 8574t on it not a 8574A ?
    It is definitely a 8574T as shown in #36 and copied below.
  20. #60
    is that the current device or the one that got zapped ?
    I found a 8574a in my junk box and fed your code into it (no lcd) and it seems ok (address is $78 for a version)
    the attached pcf8574a.txt file is really a salea logic data/setting file and should be renamed to pcf8574a.logicdata , if you don't have a salea logic analyser you can download the software from salea logic and view the complete data
    Jun 2008
    Varese , Italy
    Steve,
    I did run the program:
    P0, P5 and P6 do not toggle: they are always at 0vdc as seen by the scope.
    I did check the tracks : there is good continuity between each pin of the PCF and the display pins.
    I assume the pcf is gone or the module has been sent with a broken pcf.
    As you have seen in the photos, I have changed the contrast pot because it was shorting the 5 vdc to ground , I fit a new one with a "crossed" pins.
    Will order a new board from a reliable seller ... I am searching for it here.
    Thanks for all.
    Ambrogio
  22. #62
    Jun 2009
    Sc*nthorpe, UK
    It is the current device.
    The PCF8574 and PCF8574A are identical, except for the different fixed portion of the slave address. The address used is 78 which fits with it being a PCF8574T and you use $78 which again fits with yours being a PCF8574AT.
  23. #63
    Jun 2008
    Varese , Italy
    Thanks Richard,
    I confirm that the address is OK since I can get some pins toggling correctly.
    the PCF has definitively some "broken" port pins.
    I still have the suspect that this is a fake board: It has the contrast pot error ... and now it has this issue !
    Thanks a lot
    Ambrogio
    iw2fvo
  24. #64
    Jun 2009
    Sc*nthorpe, UK
    Steve,
    Thanks for all.
    Ambrogio
    Well done it is the PCF!
    I am surprised I thought the PCF was the least likely cause the PCB track or soldering fault was the most likely cause.
  25. #65
  26. #66
    Jun 2009
    Sc*nthorpe, UK
  27. #67
    Jun 2009
    Sc*nthorpe, UK
    I have tested this code and it works!
    'DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
       LCD_E = 1
    LCD_Backlight = 0
    LCD_Data = "T"
    LCD_Data = "e"
    LCD_Data = "s"
    LCD_Data = "t"
    LCD_Backlight = 1
    LCD_Data = "-"
    Jun 2009
    Sc*nthorpe, UK
    I am not a good programmer and I would like to convert the PBP program that is normally used now to EASY control the I2C display.
    At the moment I am using this piece of code:
    INS CON 254 ' $FE: INSTRUCTION COMMAND MODE
    CLR CON 1 ' CLEAR LCD , GOTO FIRST LINE, FIRST CHARACTER
    DG CON 223 ' DEG SYMBOL °
    LINE1 CON 128 ' $80: GOTO LINE 1
    LINE2 CON 192 ' $C0: GOTO LINE 2
    LINE3 CON 148 ' $94: GOTO LINE 3
    LINE4 CON 212 ' $D4: GOTO LINE 4
    And then I do the the following to write my own data on it:
    LCDOUT INS, LINE2, " V=", DEC2 VLT/10, ".", DEC1 VLT
    How could I translate the above in I2C enviroment for displaying ?
    Thanks for the assistance
    Ambrogio
    IW2FVO
    How to do this as neatly as possible are the next steps.
  29. #69
    the ext modifier should help
    lcdb VAR BYTE[22]
    lcd_cmd = _lcdb
    lcd_buff = _lcdb+2
    these must be after the asm code
    lcd_cmd var byte EXT
    lcd_buff var byte EXT
    lcdb[0]=$fe
    lcdb[1]= your lcd command eg 1 $80 $c0
    use arraywrite to load lcd_buff (max 20 chrs)
    then you can pass
    lcd_cmd to your lcd write code if you need to send a cmd with your lcd string
    or pass lcd_buff if no cmd required
    ps don't forget to add a dely after a cmd to give the lcd time to act
    ps ps
    the asm names are case sensitive
    left a bit out
    not sure if it needs to be try it and see
    lcd_cmd var byte[2] EXT
    lcd_buff var byte[20] EXT
  30. #70
    Jun 2009
    Sc*nthorpe, UK
    lcdb VAR BYTE[22]
    lcd_cmd = _lcdb
    lcd_buff = _lcdb+2
    lcdb[0]=$fe
    then you can pass
    ps ps
    left a bit out
    Steve,
    the point is that I do not have PBP_3.
    My pbp is 2.50 B.
    No arraywrite or read, no usercommand ... are available to me .
    Ambrogio
    Ambrogio is using pbp2.5 and I am even older on 2.46.
  31. #71
    without arraywrite that's a lot of code
  32. #72
    Jun 2009
    Sc*nthorpe, UK
    and a lot more fun!
    I am only along for the ride and to keep my brain ticking over.
  33. #73
    does 2.5 have the dig command
  34. #74
    The DIG modifier has been there forever....
    EN82fn
  35. #75
    Jun 2008
    Varese , Italy
    Steve,
    it is a very good new !
    I am looking to place an order for a couple of new extender boards. The point is the lead time .
    I will let you know.
    I appreciate your assistance.
    Ambrogio
  36. #76
    Jun 2008
    Varese , Italy
    Thanks to all of you for the assistance.
    What is the dig modifier please ?
    Thnaks
    Ambrogio
  37. #77
    Sep 2009
    From manual:
    DIG returns the value of a decimal digit. Input the digit number (0 – 9, with 0 being the rightmost digit). DIG returns the value of the decimal digit that you specified. DIG is commonly used to distill BCD digits from numeric values and to isolate single digits for display on seven-segment LCD.
    B0 = 123 ' Set B0 to 123
    B1 = B0 DIG 2 ' Sets B1 to 1 (digit 2 of 123)
  38. #78
    Jun 2009
    Sc*nthorpe, UK
    Steve,
    Ambrogio
    No next day delivery in Italy?
    I ordered my LCD and backpack for £9.30 including next day delivery, details in #66.
    The test program is not very useful as it only tests the LCD is working. I will add commands so that the screen can be cleared and the cursor can be positioned anywhere on the screen.
  39. #79
    Jun 2008
    Varese , Italy
    That is clear to me now.
    Ambrogio
  40. #80
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio
    I am working on the program by adding commands as you can see in the picture.
    Let me know when you are ready.
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 23:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 17:13
Members who have read this thread : 4
