I2C lcd ( arduino ) with PICBASIC, help
Results 1 to 40 of 93
    Jun 2009
    Sc*nthorpe, UK
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    I tried using the on board EEPROM by using DATA and READ.
    DATA "This is a string",0
    but it stores only alternate characters. I was surprised it worked at all but the alternate characters? There has to be a reason for it to work this way.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by EarlyBird2 View Post
    It looks like this was fixed back in 2010.
    http://www.picbasic.co.uk/forum/showthread.php?t=12775
    My PBP2.46 is from 2005.
    Jun 2009
    Sc*nthorpe, UK
    The plot thickens! Here is an extract from this thread http://www.picbasic.co.uk/forum/show...7143#post97143 using DATA with strings and it works.
    Quote Originally Posted by dan-tron View Post
    EUREKA!
    Thanks guys! You have been a huge help. I have finally figured it out.
    My problem was more like 3 problems...
    1. I have never done EEPROM stuff before so I was lost to begin with.
    2. As Bruce pointed out, the mathematical order of operations in one line was not correct. I guess the BS2 thinks a little differently from PBP in that respect.
    3. My PicBasic Pro compiler was Version 2.30 form 2000. It seems that v2.30 supports the PIC 16F628 but the PIC 16F628A was implemented in a later version. I have upgraded my PBP to version 2.47 and now the EEPROM features work correctly on the 16F628A. When I successfully tested a 16F84A using the same code, that lead me to question the compiler.
    So for future generations and the benefit of other people like me, here's my WORKING code that is tested successfully on a PIC 16F628A with a 20MHz resonator compiled using PBP v2.47. It reads data from the Parallax RFID Reader Module, compares it against known values stored in EEPROM and allows or denies access accordingly. Enjoy.
    CMCON = 7
    DEFINE OSC 20	'Set oscillator in MHz
    ' -----[ Variables ]-------------------------------------------------------
    buf	VAR	Byte(10)	' RFID bytes buffer
    tagNum	VAR	Byte	' from EEPROM table
    idx	VAR	Byte	' tag byte index
    char	VAR	Byte	' character from table
    ' -----[ EEPROM Data ]-----------------------------------------------------
    Tag1	DATA	"100050A4B7"
    Tag2	DATA	"1000508E0A"
    Tag3	DATA	"10005091DC"
    Tag4	DATA	"100050203A"
    Tag5	DATA	"100050DA36"
    ' -----[ Initialization ]--------------------------------------------------
    HIGH portb.3	' turn off RFID reader
    LOW portb.6	' lock the door!
    Low portb.4	'Turn off LED
    ' -----[ Program Code ]----------------------------------------------------
    LOW portb.3				' activate the reader
    SERIN2 portb.2, 396, [WAIT($0A), STR buf\10]	' wait for hdr + ID
    HIGH portb.3				' deactivate reader
    Check_List:
      FOR tagNum = 1 to 5			' scan through known tags
        FOR idx = 0 TO 9				' scan bytes in tag
        READ (((tagNum-1) * 10) + idx), char		' get tag data from table
        IF (char <> buf(idx)) THEN Bad_Char		' compare tag to table
        NEXT
        GOTO Tag_Found				' all bytes match!
    Bad_Char:					' try next tag
      NEXT
    Bad_Tag:
      tagNum = 0
      FREQOUT portb.5, 1000 */ $100, 115 */ $100	' groan
      PAUSE 1000
      GOTO Main
    Tag_Found:
      HIGH portb.6				' remove latch
      High portb.4				' Light LED
      FREQOUT portb.5, 2000 */ $100, 880 */$100	' beep
      LOW portb.6				' restore latch
      Low portb.4				' LED OFF
      GOTO Main
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio
    After more testing of the DATA command I have come to the conclusion that my very old setup is the cause. I have PBP2.46 and MCSP from ten years ago. Looking at my old code, ten years old, I used WRITE not DATA and I now believe that was because DATA never worked. I wrote a routine just to write to the EEPROM followed by the program fortunately my set up did not overwrite the EEPROM when the PIC was reprogramed, Bruce's FlashLab boards continue to perform flawlessly.
    There are three options for the screen setup
    1 LOOKUP
    2 Embedded string
    3 EEPROM
    They all work but LOOKUP uses most code space and EEPROM the least.
    Jun 2008
    Varese , Italy
    Steve,
    I am very interested in test the programs but I am still waiting to receive the PCF expander.
    It will arrive here after my summer holidays. I will let you know.
    Thanks for all.
    Ambrogio
    Feb 2007
    Ciao Ambrogio,
    take a look here ... could help!
    http://www.protonbasic.co.uk/showthr...ck-on-1602-LCD
    Leo
    Leo
    Jun 2008
    Varese , Italy
    Thanks to all of you in this forum for the assistance.
    I am having problem with my healt in this last period of time. I had an important surgery.
    I hope to be active again.
    Ambrogio
    IW2FVO
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 18:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 22:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 02:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 18:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 16:13
Members who have read this thread : 4
