PCA9685PW Coding
Results 1 to 3 of 3
    Oct 2009
    Default PCA9685PW Coding
    I'm hoping to use a PCA9685PW (16 channel PWM LED driver chip) to control some aquarium light I've made. Basically I want to use 4 channels of the chip so I can independently turn on and dim 4 sets of LEDS.
    I've got a PCA9685PW chip on a breakout board, opened up the datasheet ( http://www.nxp.com/documents/data_sheet/PCA9685.pdf ) and it went completely over my head.. Can someone advise on the basics, like how to set the address (I think its set by grounding / supplying 6 pins ?).
    In PicBASIC PRO I use the following to read the hours minutes and seconds from the DS1307 RTC chip
    I2CREAD SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
    The first part is straight forward, and I guess I need to use a different address than $D0,$00 so as not to clash with the RTC chip, but what would I need to do to send the PWM variable to the correct LED channel etc on the PCA chip. I currently use two variables B_PWM and W_PWM which currently has a value of between 0 and 254. It's simple enough to change that to from a byte to word variable as the PCA chip has 4095 steps, but other than that I'm lost ! Any help with interpreting the datasheet would be welcolm
    Default Re: PCA9685PW Coding
    if you connect a5 to vcc and a4-a0 to gnd the slave address should be $C0
    a quick google of this device found 0 results for example code for any language whatsoever.
    (might be natures way of saying "good luck with that")
    good luck with that
    Oct 2009
    Well for reference this works. Its fairly easy to modify the code to use a variables for the value for the pulse width which should be 0 - 4095
    i2cControl var BYTE
    i2cAddress var BYTE
    pcaAddress var BYTE
    pcaAddress = $40
    i2cAddress = pcaAddress << 1
    ;Reset
    ;PCA9685_MODE1 0x0
    i2cControl = 0
    I2CWRITE SDApin,SCLpin,i2cAddress,i2cControl,[0]
    ;Set PWM to 500Hz
    ;Prescaler = 11
    ;Calculate prescaler by:
    ;floor((((25000000/4096)/requiredFreqInHertz)-1)+0.5)
    ;For lack of float support or floor function the value can be calculated and then hard-coded
    ;Get old mode
    oldMode var BYTE
    ;PCA9685_MODE1 0x0
    i2cControl = 0
    I2CREAD SDApin,SCLpin,i2cAddress,i2cControl,[oldMode]
    newMode var BYTE
    ;MODE1 Sleep
    newMode = (oldMode & $7F) | $10
    ;Set MODE1 Sleep
    ;PCA9685_MODE1 0x0
    i2cControl = 0
    I2CWRITE SDApin,SCLpin,i2cAddress,i2cControl,[newMode]
    ;Set Prescaler
    ;PCA9685_PRESCALE $FE
    ;Prescaler is 11
    i2cControl = $FE
    I2CWRITE SDApin,SCLpin,i2cAddress,i2cControl,[11]
    ;Set old mode
    ;PCA9685_MODE1 0x0
    i2cControl = 0
    I2CWRITE SDApin,SCLpin,i2cAddress,i2cControl,[oldMode]
    Pause 5
    ;Set MODE1 AutoIncrementOn
    ;PCA9685_MODE1 0x0
    i2cControl = 0
    I2CWRITE SDApin,SCLpin,i2cAddress,i2cControl,[oldMode | $A1]
    ;;Set a PWM channel
    pcaChannel var BYTE
    pcaPwmValue var BYTE
    pcaChannel = 0
    pcaPwmValue = 4095
    ;LED0_ON_L 0x6
    i2cControl = $6 + 4*pcaChannel
    I2CWRITE SDApin,SCLpin,i2cAddress,i2cControl,[0,0,pcaPwmValue,pcaPwmValue >> 8]
    pcaChannel = 1
    pcaPwmValue = 1024
    ;LED0_ON_L 0x6
  1. Help in coding
    By aliciamee in forum General
    Last Post: - 10th March 2009, 03:27
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 07:31
  3. New to coding - Please look at my code thanks!
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 18:42
  4. PICBasic Coding Help
    By hodgdre in forum mel PIC BASIC Pro
    Last Post: - 28th November 2006, 16:55
  5. Turbo Coding
    By obaskirt in forum mel PIC BASIC Pro
    Last Post: - 17th November 2006, 15:54
