Can't get the simplest of programs to run using internal osc and just toggling a pin
Results 1 to 11 of 11
    May 2011
    Default Re: Can't get the simplest of programs to run using internal osc and just toggling a
    I have tried doing gpio.0 as well with no better result. This cut and paste is just the latest thing I have tried out of desperation. Not that it is right but I have numerous other programs that I just us "High 4" and it works. Thank you for your time in looking at this.
    When you compile, does ALLDIGITAL suggest lines to be added to your code?
    May 2011
    No, it didn't. Nothing was out of the ordinary as far as I could tell. It didn't before I added the alldigital file to the folder but I did it anyway just in case. I am completely baffled.
    See if this will work.
     __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _IOSCFS_4MHZ & _CP_OFF & _PWRTE_OFF & _IOSCFS_4MHZ & _BOR_OFF
    DEFINE OSC 4 ' keep above your code and registers settings
    Adcon0 = 0 'disable adc
    ANSEL = 0 'gpio all digital
    TRISIO = 0 'all outputs except gpio3
     do
     'serout2 gpio.5, 396, ["M"]
     high 0
     low 0
     loop
    Yes, I forgot the High/Low 0 statements are from the old Basic Stamp days.
    May 2011
    No dice. I have tried yet another PIC to make sure I didn't damage the last two and tried a different programmer in the event that was damaged (1 in a million, I know). My gut is that I am missing something oscillator related but cannot figure out what. Thanks for the look at what I have.
  1. Programs and Verifies, but won't run
    By rsfutch in forum mel PIC BASIC Pro
    Last Post: - 19th July 2013, 18:46
  2. PIC programs, resonator resonates, but does not run code.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 01:47
  3. PULSOUT versus toggling a pin
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:59
  4. Internal OSC, how to?
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 7th January 2008, 00:03
  5. Internal Osc help
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 12th January 2007, 20:50
