Serial comm between two PICs
Results 1 to 25 of 25
    Unhappy Serial comm between two PICs
    Hi, I am trying to interface two PICs together via serial connection. I am using two PIC16F88s running at 4mhz. PortB.0 on the tx chip is connected to PortB.0 on the rx chip. I have a button connected to PortB.1 on the tx that when pushed causes the pin to go high. I have an Led on PortB.1 of the rx. My goal is to transmit the state of the button to the rx chip to turn the LED on or off. This is just an experiment with serial communications and the actual application will be much more complex. here is my code:
    Tx:
    Include "modedefs.bas"
    b0 VAR BYTE
    Start:
    IF PortB.1 = 1 THEN LET b0 = 1
    LET b0 = 0
    SEROUT PortB.0, N2400, [b0]
    GOTO Start
    Rx:
    b0 VAR BYTE
    Start:
    SERIN PortB.0, N2400, [B0]
    IF b0 = 1 THEN HIGH PortB.1
    LOW PortB.1
    GOTO Start
    When I push the button nothing happens. I am confident that the circuit works so I am convinced that the problem is in the software. I do not fully understand the SERIN SEROUT commands and am interested in what happens when a serial command is executed. Does the Rx wait for the data or if there isn't any go to the next line of code? Do the SERIN SEROUT commands have to be executed at the same time for the communication to be successful.
    I appreciate all the help i can get on this.
    Hi ALFRED,
    When the program gets to the SEROUT statement, the value of b0 is always 0.
    Tx:
    b0 VAR BYTE
    Start:
    LET b0 = 0
    GOTO Start
    Yes, the way you have it now, it will wait forever to receive a byte. If you wanted it to continue if it doesn't receive anything, you can add a timeout to the SERIN statement.
    YES!
    Question
    Hi, i just realized that I typed my code in wrong. I had it the way you suggested but it still doesn't work. any other ideas of what could be wrong?
    Thanks for any more help.
    Well, it wasn't really a suggestion. I was just pointing out part of the problem.
    My suggestion would be to place the b0 = 0 line just prior to the IF PortB.1 = 1 line. Like this...
    Tx:
    b0 VAR BYTE
    Start:
        LET b0 = 0
        PAUSE 10
    GOTO Start
    And, add a short pause in the loop. Just to space things out a bit.
    Then on the receiving end...
    Rx:
    b0 VAR BYTE
    Start:
        IF b0 = 1 THEN
            HIGH PortB.1
            LOW PortB.1
    GOTO Start
    Sep 2003
    Vermont
    Start:
    LET b0 = 0
    PAUSE 10
    GOTO Start
    Don't forget the "ENDIF"
    Start:
    LET b0 = 0
    * ENDIF*
    PAUSE 10
    GOTO Start
    Question
    Hi, I tried Ron Marcus's "endif" and it did not compile. nothing seems to be working and I am beginning to thing that I should try the HSERIN and HSEROUT commands instead. My actual application will be a PIC 18F4320 PIC controlling 12 servos and monitoring 12 pushbuttons. The idea is to take the load of controlling servo motion routines of the master controller. I want to control the motion routines of the servos with the master controller via serial link. Does anyone have any ideas? I think that the hardware serial port would make the timing requirements easier to deal with but I do not fully understand the HSERIN HSEROUT commands and USAURT could someone please explain all this to me?
    Oct 2013
    Default Re: Serial comm between two PICs
    I have a problem with comunication betwin two PIC-es
    PIC1-16F877A
    PIC2-16F628A
    PIC1 code:
    TRISC=%00000010
    PORTC=%00000000
    DEFINE BEBUG_REG PORTC
    DEFINE DEBUG_BIT 0
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 10
    BROJ VAR BYTE
    POCETAK:
    WHILE PORTC.1=0
    DEBUG BROJ
    WEND
    GOTO POCETAK
    PIC2-code
    TRISA=%00000000
    TRISB=%00000010
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 1
    DEFINE DEBUG_MODE 0
    BR VAR BYTE
    POC:
    DEBUGIN [BR]
    WRITE 00,BR
    GOTO POC
    But something is wrong but what?
    Well, for starters, the line DEFINE BEBUG_REG PORTC is wrong.
    Oct 2013
    Sorry, but it was wrong tiping the letter, but it is steel not working.
    It's hard to guess since you haven't posted the actual code you're using, missing variable declarations etc but "it doesn't work" is THE worst problem description you can ever give - of course "it doesn't work"... You wouldn't even be posting here in the first place if it did, right?
    So, What exactly doesn't work? How do expect it TO work? What have you done, except posting here, to try finding the issue?
    Are the sending PIC actually running? Is it running at the correct speed (4MHz)? Is it sending anything at all? Is the receiving PIC actually running? Is IT running at the correct speed (4MHz)?
    One thing, which doesn't really prevent it from "working" but may be fooling you, is that on the sending side the variable BROJ never changes, it's always zero (or perhaps there's more code that you didn't show).
    Oct 2013
    Here are the codes of pic1 and pic2.Pic1 have the quartc on 8 MHz but I gave it a DEFINE OSC 4
    becouse the pic2 works at 4 MHz.I am shure that everything works in PIC1 exept DEBUG becouse I checkedout.I am shure that PIC2 is running becouse it puts the port-out signals in the right order and it change the PIC2 addresses 00,01,02,03 to zero values (00,00,00,00).PIC2 have an internal OSC and it works at 4 MHz and I can't measure it, but PIC1 works in 8 MHz but I guess it devides the 8MHZ becouse I wrote DEFINE OSC 4.I am wondering if the BAUDRATE is to fast or is the code of DEBUG correct?
    Not at all. That's not what DEFINE OSC does, look it up in the manual.
    Yes, the PIC is running at 8MHz but you're telling the compiler it's running at 4MHz. The compiler calculates the baudrate timings based on 4MHz when in reallity it's running twice as fast - the actual baudrate will be double what you tell it.
    Oct 2013
    Ahaa I will change PIC1 code to DEFINE OSC 8 and then I will let you know what will happen.Thanks.
    Oct 2013
    It is not working.I tried with SERIN and SEROUT instruction but it is the same thing.Is it the SERIN and SEROUT code wrong written?
    TRISC=%00000010
    PORTC=%00000000
    INCLUDE "Modedefs.bas"
    DEFINE OSC 8
    DEFINE DEBUG_PACING 100
    BROJ VAR BYTE
    BROJ=9
    POCETAK:
    WHILE PORTC.1=0
    SEROUT PORTC.0,T2400,[BROJ]
    WEND
    GOTO POCETAK
    PIC2:
    PCON=%00001011
    TRISA=%00000000
    TRISB=%00000010
    BR VAR BYTE
    POC:
    SERIN PORTB.1,T2400,[BR]
    WRITE 00,BR
    GOTO POC
    Again, saying "it doesn't work" really does not make it easy trouble shooting someone elses code from a remote location. You really need to figure out WHAT isn't working. Where is the problem, is it the sending PIC or the receiving PIC? Perhaps the communication is working just fine and it's the fact that your sending the same value all the time that's making it LOOK like it's not working? How are you determining that it's not working? What does it do?
    One thing I did notice, in your previosuly posted code, is that you're using DEFINE DEBUG_XXXX on the receiving side as well. You need to use DEFINE DEBUGIN_XXXX.
    Another thing I'd do is implement some sort of delay, or even handshake, so that the sending PIC sends the value ONCE each time instead of sending it over and over again as fast as it possibly can.
    Dec 2010
    I've also found it useful to stick a PC serial port in the middle during development. Set up your PC to run a terminal program, then start with making sure the transmitter and receiver work on their own before trying them together. Divide and conquer.
    Oct 2013
    your sending the same value all the time that's making it LOOK like it's not working?What does it do?
    I am shure that the PIC1 is sending the diferent value every time becouse I have LCD out view on PIC1.I am not shure that PIC2 is resiveing the data becouse the adress of PIC2: 00 is allwayes FF.So I must get a logic analiser and see what happens on resive PORTB.1.
    Jun 2009
    Sc*nthorpe, UK
    Having read the manual the serin statement has this format.
    SERIN Pin,Mode,{Timeout,Label,}{[Qual...],}{Item...}
    As you can see square brackets are around the Qualifier.
    The statement in your code
    Is therefore waiting for BR as a qualifier?
    Oct 2013
    Quote Originally Posted by EarlyBird2 View Post
    I had never use SERIN or SEROUT or DEBUG or DEBUGIN instruction so I can't shurely tell you what' right. I need to send decimal value of GREJAC from PIC1 to BR on PIC2.Then a decimal value of BR I will compare in SELECT CASE rutine which I didn't wrote.
    Oct 2013
    Now I made a PIC2 as a transmiter and pic1 as a resiver becouse I have a LCD out on pic1 so I can see what is happening all the time.I took osciloscope and found that pic 2 is not transmiting anything at all.This is the code of the pic2 - transmiter:-16f628a
    PCON=%00001011
    CMCON=%00000111
    TRISB=%00000000
    TRISA=%00100000
    PORTA=0
    PORTB=0
    BR VAR BYTE
    BR=15
    pocetak:
    SEROUT PORTB.1,T2400,[BR]
    PAUSE 5000
    GOTO pocetak
    Is the code wrong?I have 5V on the PORTB.1 and it is not changeing at the time.
  1. Pic to pic interrupt ans serial comm
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 10th May 2008, 23:43
  2. Multiple Pics to One serial port
    By Rleonard in forum Serial
    Last Post: - 18th January 2007, 19:30
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 5th April 2004, 00:58
