touble with a time calculation
Results 1 to 40 of 59
    Feb 2012
    PERTH AUSTRALIA
    Default Re: touble with a time calculation
    well after a few more tests that did not work well , yes , when you enter a event period of 10sec for the event time or 1 min or 1 hour , 1day then code answers earlier will allow for the <0 error when it roles over , but its does not when you combine Event set time for say 1 m 10 sec
    so lets start again
    sounds simple but its giving me a problem
    GOAL
    the count up elapsed base timer is counting up from 0 , when the set time values are => then time set for the event the Overtime clock is enabled starts counting up to show the time past the set time
    code references
    Base Elapsed timer is set to count up = EL1
    Overtime Clock = EL2
    Event1_OT_xxx = Time set duration for event
    EL1 has the standard time duration if statements enabled so that sec = 60 then sec = 0 , min = min +1 , same for hour , day 0 then 1 min , etc etc for counting up
    '-------  Event overrun timer 1--------
         if EL1_Days => Event1_OT_Day    and EL1_hOURS => Event1_OT_Hour  and _
            EL1_Minutes => Event1_OT_Min and EL1_Seconds => Event1_OT_Sec and _
            EL1_100th => Event1_OT_100th then EL2_Enable = 1
        if  Event1_OT_Day = 0 and Event1_OT_hour  = 0 and Event1_OT_Min = 0 and _  ' if all values are 0 , then dont enable the overrun timer
            Event1_OT_sec = 0 and Event1_OT_100th = 0 then  EL2_Enable = 0
         if EL2_Enable = 1 THEN     ;  EL2 = EL1 current values - set overrun value
            EL2_Days    = EL1_Days    - Event1_OT_Day
            EL2_Hours   = EL1_Hours   - Event1_OT_hour
            EL2_Minutes = EL1_Minutes - Event1_OT_Min
            EL2_Seconds = EL1_Seconds - Event1_OT_sec
            EL2_100th   = EL1_100TH   - Event1_OT_100th
    addings code to allow for <0 error ( EL1_Seconds - Event1_OT_sec) - this occurs when secs role over 1min but the work arround is not working when combined with sat set times of 1min 10 sec
    any further sugestions
    Jun 2009
    Sc*nthorpe, UK
           EL2_100th   = EL1_100TH   - Event1_OT_100th+100
            if EL2_100th<100 then
              EL1_Seconds=EL1_Seconds-1
           Else
             EL2_100th=EL2_100th-100
        EL2_Seconds = EL1_Seconds - Event1_OT_sec+60
          if EL2_Seconds<60 then
            EL1_Minutes=EL1_Minutes-1
           EL2_Seconds =EL2_Seconds -60
           EL2_Minutes = EL1_Minutes - Event1_OT_Min +60
         if EL2_Minutes<60 then
           EL1_Hours=EL1_Hours-1
           EL2_Minutes =EL2_Minutes -60
           EL2_Hours   = EL1_Hours   - Event1_OT_hour+24
         if EL2_Hours<24 then
            EL1_Days=EL1_Days-1
           EL2_Hours   =EL2_Hours   -24
    Just something to try
    steve has the right idea for the math but since el1/el2 vars can be updated via the isr at any time during the calcs the results will vary.
    statisticly it will fail about 4-5 times per hundred calcs based on :-
    I think chances of failure are 1/60+1/60+1/100+1/24 I might be wrong about the stats
    Jun 2009
    Sc*nthorpe, UK
    If isr affects EL1 vars create Temp_EL1 vars at the start of the routine and use these for the calculation.
    won't work . the isr can change the values as u copy them to the temp vars ,been there done that
    Jun 2009
    Sc*nthorpe, UK
    Ok some problems do not have an answer.
    Bye
    only solution I know is to disable isr and copy vars to a buffer then enable isr and then perform calcs on the buffered data.
    it may mean the odd lost interrupt / whats worse incorrect calcs or missed ints
    only the designer can make that call .
  1. Help with calculation
    Last Post: - 28th August 2012, 17:10
  2. CHECKSUM CALCULATION, Please Help!
    By wasilus in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2012, 07:55
  3. Calculation Problem - value goes to zero after 65
    Last Post: - 12th March 2010, 05:10
  4. calculation
    Last Post: - 20th May 2008, 16:28
  5. CRC Calculation - Need a little help
    By Steve43 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 01:23
