touble with a time calculation
Results 1 to 40 of 59
    Feb 2012
    PERTH AUSTRALIA
    Default Re: touble with a time calculation
    the reason for the enable is that until the time = > the setting , the output is not displayed , also the enable flag is used for other routines , hardware options and other timers., also if the values of the Set time all are 0 then that disables the flag for this timer for display on the Glcd's and other outputs
    there are several timer clock options that need to show - time in secs only , mins+ sec only , hours,min, sec only ,currently these options turn off / on flags inside the main up/ down timer counter code to enable hours, mins ,sec changes
    by changing the values to 59 from 60 for say the secs this results in the following
    if set_hour= 0 set_min = 0, Set_sec = 10
    if main elapsed time now shows = 0 hour, 1 min , 0 sec
    If OT_sec = 60 - Set_sec + Seconds(main elapsed ) then
    OT display = 50 (60 - 10 + 0)
    if OT_sec = 59 - Set_sec + Seconds(main elapsed ) then
    OT display = 49 (59 - 10 + 0)
    if the event time was set for 10 sec and the main time is now 1 min then the overtime should read 50secs , not 49 sec
    I think i have this correct , but i am still testing
    cheers
    Sheldon
    if you have a clock running
    try this
    h m s var bytes (current time )
    x y z var byte (old time )
    a b c var byte ( time difference)
    carry var bit
    time_difference: (assumes current time > old time)
    carry=0
    c=s-z
    if c>127 then
    c=c+60
    carry=1
    b=m-(y+carry)
    if b>127 then
    b=b+60
    carry=1
    carry=0
    a=h-(x+carry)
    if a>127 then
    a=a+24
    carry=1 ;extra day needed to be added
    carry=0
    Feb 2012
    PERTH AUSTRALIA
    time problem sorted , thanks steve for your help on that , cheers m8
    next part flash / data transfer from program mem to flash - problems never seems to stand still for long
  1. Help with calculation
    Last Post: - 28th August 2012, 18:10
  2. CHECKSUM CALCULATION, Please Help!
    By wasilus in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2012, 08:55
  3. Calculation Problem - value goes to zero after 65
    Last Post: - 12th March 2010, 06:10
  4. calculation
    Last Post: - 20th May 2008, 17:28
  5. CRC Calculation - Need a little help
    By Steve43 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 02:23
