touble with a time calculation
Page 1 of 2 12 LastLast
Results 1 to 40 of 59
    Feb 2012
    PERTH AUSTRALIA
    Default touble with a time calculation
    Hi guys , having a mind block on a time calculation
    what i need is to set a time and show the amount of time that has occurred past (OVERTIME ) that set time
    the hours mins , sec is working ok as a count up clock
    the calculation fails when overtime goes to 1min is sec 0 etc
    eg if the set value is say 0 hours , 0 mins 10sec
    the overtime clock will start counting past 10sec
            OT_Hours   = Hours   - set_hour
            OT_Minutes = Minutes - set_Min
            OT_Seconds = Seconds -set_sec
    Default Re: touble with a time calculation
    OT_Hours = 0 OT_Minutes = 0 OT_Seconds = 0
    #stop clock here for the test otherwise sec/min rollovers during if tests will give incorrect results
    if Hours > set_hour then OT_Hours = Hours - set_hour
    if Minutes > set_Min then OT_Minutes = Minutes - set_Min
    if Seconds > set_sec then OT_Seconds = Seconds -set_sec
    #resume clock
    note hour rollover to next day is not taken into account
    Feb 2012
    PERTH AUSTRALIA
    hi richard , the main clock cant be stopped and needs to be a running test
    the rollover from sec to mins is the issue as well as mins to hours
    with the Set_Day= 0, Set_Hour= 0 ,Set_min= 0, Set_sec = 10
    this code has that issue of when the clock roles over
    the OT variables are used to display the OT clock
    Days, Hours, Mins,Secs variables are the main clock
    "Set_" varables are the time allowed
    the OT clock is only enabled after the Set time is = > than the main clock
        if  OT_Days => Set_Day and OT_Hours => Set_Hour and OT_Minutes => Set_Min and OT_Seconds => Set_OT_Sec then OT_Enable = 1
       if OT_Enable = 1 THEN
            if Days     >  Set_Day   then OT_Days    = Days  - Set_Day
            if Hours    >  Set_Hour  then OT_Hours    = Hours - Set_Hour
            if Minutes  > Set_Min    then OT_Minutes = Minutes - Set_Min
            if Seconds > Set_Sec   then OT_Seconds = Seconds - Set_Sec
    Feb 2012
    PERTH AUSTRALIA
    corrected code to be, so only OT is enabled and shown when Set time matched or exceeded , but roll over is still the problem
      if  Days => Set_Day and Hours => Set_Hour and Minutes => Set_Min and Seconds => Set_OT_Sec then OT_Enable = 1
    I have the same sort of problems comparing multibyte values that increment in isr routines , the only solutions I can find are to
    1. stop the clock then compare vars (disable interrupts)
    2. compare the vars in the "clock" isr where they wont change as you compare them
    3. maybe have a special case for seconds=59, minutes=59 and seconds=59 , seconds= 59 and minutes=59 and hour=23 (if seconds and minutes and hours are all single byte vars )
    option 3 seems flaky
    Bombay, India
    Why not try something straight forward as this?
         ' run this every second along with your clock code
         if (Hours >= Set_Hours AND Minutes >= Set_Min AND Seconds >= Set_Sec)
               OT_Seconds = OT_Seconds+1
               if (OT_Seconds > 59)
                   OT_Seconds = 0
                   OT_Minutes = OT_Minutes+1
                   if (OT_Minutes > 59)
                        OT_Minutes = 0
                        OT_Hours = OT_Hours+1
                        ' you may want to restrict / rollover the hours to 24 hours format here.
    Feb 2012
    PERTH AUSTRALIA
    I have a main clock in place
    the overtime clock = main clock - set time
    the problem occures when the clock value roles over and the clockvalue - set_time < 0
    during that time the value of the OT clock is incorrect
    eg set time = 10 sec , when main clock counts to 1min , the over time clock would show 0.50 instead of 0.51 etc, for the duration of main clock moving 1.00 - 1.10 , then it be fine
    this approch seems to be correct but i am not sure if it needs to be nested
     if     Days => Set_Day    and Hours => Set_Hour  and _
            Minutes => Set_Min and Seconds => Set_Sec and _
            100th => Set_100th then OT_Enable = 1
            OT_Seconds =Seconds - Set_sec
            OT_100th   = 100TH   - Set_100th
          if  Hours   - Set_Hour <0 then
              OT_Days    = Days - 1
              OT_Hours   = 24 - Set_Day  + Hours
         if   Minutes - Set_Min  <0 then
              OT_Hours   = OT_Hours - 1
              OT_Minutes = 60 - Set_Min + Minutes
         if  Seconds - Set_Sec   <0 then
             OT_Minutes =  OT_Minutes - 1
             OT_Seconds =  60 - Set_Sec + Seconds
         if 100TH - Set_100th   <0 then
             OT_Seconds = OT_Seconds - 1
             Ot_100TH   = 100 - Set_100th + 100TH
    Feb 2012
    PERTH AUSTRALIA
              OT_Days    = Days - 1
              OT_Hours   = 24 - Set_Hour  + Hours
    typo fixed
    hows this going to work
    imagine set day=0 set hour=1 set min=30
    if hour = 2 and min=29 then it will test false when it should be true
    u need to think in terms of timestamp
    timestamp= sec+min*60 +hour*3600 etc day * whatever. (unix does it from some arcane date in 1980 in microseconds)
    then compare timestamp
    this will not solve rollovers however
    from wiki
    unix timestamp 00:00:00 UTC on January 1, 1970
    just for the sake of an argument on a raspberry pi
    you could just go datetime.datetime(now)-settime and you wold get a RESULT in years,months,days,hours,minutes,seconds and microseconds
    a pi costs about 40 bucks has 512m of ram usb and Ethernet built in . makes life easy
    Jun 2009
    Sc*nthorpe, UK
    A clock does not have values of
    24 hours
    60 min
    60 sec
    100 100th
    for example a clock showing 59 seconds will change to 0 on the next second.
    the calculation
    should be
    OT_Seconds = 59 - Set_Sec + Seconds
    and the same for the other < comparisons.
    Jun 2009
    Sc*nthorpe, UK
    Are you advising us all to use Raspbbery Pi?
    not at all however it depends on the size of the task ,think of moving bricks with a Toyota corolla if you only need to move a few its fine, to move 10000 would be an ordeal better suited to a tray truck with hydraulic loader.
    pbp is a great product but if you want to do a lot with floats, longs , singed math , datetime objects colour gui's etc then other platforms and languages make life a lot easier.
    Jun 2009
    Sc*nthorpe, UK
    Easy does not increase understanding.
    Unfortunately we live in a plug and play world. The Pi was created to address the issue of children not understanding how computers work and introduce them to programming so it is made easy to produce quick results and grab their imagination. What it does not do is teach electronics. But as I have never had one my opinion is not a first hand informed one.
    Anyway this thread is about time calculation not Pi and have we just hijacked a thread which is against the rules?
    do I understand the problem correctly
    I'm assuming we have a set time day-h:m:s.xx ie day 0 hour 2 minute 30 sec 28.34 and that we then subsequently read a clock and calculate the elapsed time between now and the set time if and only if the now time is greater than the set time .
    is this right ?
    Jun 2009
    Sc*nthorpe, UK
    Richard No.
    longpole001's program counts down to set time then counts up after set time.
    Feb 2012
    PERTH AUSTRALIA
    in fact i have several clock timers running for this project , most are based on the master timer with other value settings to change the displayed results
    for this task the time counter counts up from 0 , the set _time value is the length of time before trigging the overtime clock , which counts up to show the total amount of time exceeding the set_time values
    when the main timer exceeds the set_time then a secondary timer ( overtime clock ) is enabled and then shows and continues to run until the main timer stops
    as seen if the overtime clock values = main clock - set time , when a sec , min , hour roles over , a < 0 value will occur untill the time value = set_time value again
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by longpole001 View Post
    Yes that is exactly what your code does. I did wonder if that was what you wanted to do.
    I was also thinking if this is necessary
    and what would be the implications of just having this
    OT_Days = Days - 1
    OT_Hours = 23 - Set_Day + Hours
    OT_Minutes = 59 - Set_Min + Minutes
    Ot_100TH = 99 - Set_100th + 100TH
    Just a thought
    Feb 2012
    PERTH AUSTRALIA
    the reason for the enable is that until the time = > the setting , the output is not displayed , also the enable flag is used for other routines , hardware options and other timers., also if the values of the Set time all are 0 then that disables the flag for this timer for display on the Glcd's and other outputs
    there are several timer clock options that need to show - time in secs only , mins+ sec only , hours,min, sec only ,currently these options turn off / on flags inside the main up/ down timer counter code to enable hours, mins ,sec changes
    by changing the values to 59 from 60 for say the secs this results in the following
    if set_hour= 0 set_min = 0, Set_sec = 10
    if main elapsed time now shows = 0 hour, 1 min , 0 sec
    If OT_sec = 60 - Set_sec + Seconds(main elapsed ) then
    OT display = 50 (60 - 10 + 0)
    if OT_sec = 59 - Set_sec + Seconds(main elapsed ) then
    OT display = 49 (59 - 10 + 0)
    if the event time was set for 10 sec and the main time is now 1 min then the overtime should read 50secs , not 49 sec
    I think i have this correct , but i am still testing
    cheers
    Sheldon
    if you have a clock running
    try this
    h m s var bytes (current time )
    x y z var byte (old time )
    a b c var byte ( time difference)
    carry var bit
    time_difference: (assumes current time > old time)
    carry=0
    c=s-z
    if c>127 then
    c=c+60
    carry=1
    b=m-(y+carry)
    if b>127 then
    b=b+60
    carry=1
    carry=0
    a=h-(x+carry)
    if a>127 then
    a=a+24
    carry=1 ;extra day needed to be added
    carry=0
    Feb 2012
    PERTH AUSTRALIA
    that should work as well richard , cheers
    the mind block orginally came from not sure why i was seeing the output i was , and finding that the <0 resulted in the displayed variables being incorrect during that time
    Feb 2012
    PERTH AUSTRALIA
    well after a few more tests that did not work well , yes , when you enter a event period of 10sec for the event time or 1 min or 1 hour , 1day then code answers earlier will allow for the <0 error when it roles over , but its does not when you combine Event set time for say 1 m 10 sec
    so lets start again
    sounds simple but its giving me a problem
    GOAL
    the count up elapsed base timer is counting up from 0 , when the set time values are => then time set for the event the Overtime clock is enabled starts counting up to show the time past the set time
    code references
    Base Elapsed timer is set to count up = EL1
    Overtime Clock = EL2
    Event1_OT_xxx = Time set duration for event
    EL1 has the standard time duration if statements enabled so that sec = 60 then sec = 0 , min = min +1 , same for hour , day 0 then 1 min , etc etc for counting up
    '-------  Event overrun timer 1--------
         if EL1_Days => Event1_OT_Day    and EL1_hOURS => Event1_OT_Hour  and _
            EL1_Minutes => Event1_OT_Min and EL1_Seconds => Event1_OT_Sec and _
            EL1_100th => Event1_OT_100th then EL2_Enable = 1
        if  Event1_OT_Day = 0 and Event1_OT_hour  = 0 and Event1_OT_Min = 0 and _  ' if all values are 0 , then dont enable the overrun timer
            Event1_OT_sec = 0 and Event1_OT_100th = 0 then  EL2_Enable = 0
         if EL2_Enable = 1 THEN     ;  EL2 = EL1 current values - set overrun value
            EL2_Days    = EL1_Days    - Event1_OT_Day
            EL2_Hours   = EL1_Hours   - Event1_OT_hour
            EL2_Minutes = EL1_Minutes - Event1_OT_Min
            EL2_Seconds = EL1_Seconds - Event1_OT_sec
            EL2_100th   = EL1_100TH   - Event1_OT_100th
    addings code to allow for <0 error ( EL1_Seconds - Event1_OT_sec) - this occurs when secs role over 1min but the work arround is not working when combined with sat set times of 1min 10 sec
    any further sugestions
    its never going to work if you don't allow for the negative carry (borrow) , subtracting time is no different to subtracting base (16 12 10 8 2 ) numbers except that hours are base 24 , minutes and seconds are base 60 . have a look again at my example note the order of calculation also
    i'll say it again if the el1 time data vars update in real time via an isr (as I suspect they may) the whole process is flawed unless you can fix (stop the clock) the el1 time vars for the duration of the subtraction .
    Feb 2012
    PERTH AUSTRALIA
    i thought about just starting another clock by using the base ticks but i cant cos
    EL0 is the master clock elasped clock , which counts up or down and when started is not stoped untill reset
    EL1 is copy of EL0 - used to display the time and has enable /disable to stop the count on EL1 on display , then enable EL1 copies the current values from the master clock to EL1
    EL2 is the overtime clock based on the values of EL1 - set event times
    this why i really need to correct the errors in EL2 values by using EL1 - set times as far as i can see
    Feb 2012
    PERTH AUSTRALIA
    hi richard yes sent you a pm on this
    cheers
    Sheldon
    Jun 2009
    Sc*nthorpe, UK
           EL2_100th   = EL1_100TH   - Event1_OT_100th+100
            if EL2_100th<100 then
              EL1_Seconds=EL1_Seconds-1
           Else
             EL2_100th=EL2_100th-100
        EL2_Seconds = EL1_Seconds - Event1_OT_sec+60
          if EL2_Seconds<60 then
            EL1_Minutes=EL1_Minutes-1
           EL2_Seconds =EL2_Seconds -60
           EL2_Minutes = EL1_Minutes - Event1_OT_Min +60
         if EL2_Minutes<60 then
           EL1_Hours=EL1_Hours-1
           EL2_Minutes =EL2_Minutes -60
           EL2_Hours   = EL1_Hours   - Event1_OT_hour+24
         if EL2_Hours<24 then
            EL1_Days=EL1_Days-1
           EL2_Hours   =EL2_Hours   -24
    Just something to try
    steve has the right idea for the math but since el1/el2 vars can be updated via the isr at any time during the calcs the results will vary.
    statisticly it will fail about 4-5 times per hundred calcs based on :-
    I think chances of failure are 1/60+1/60+1/100+1/24 I might be wrong about the stats
    Jun 2009
    Sc*nthorpe, UK
    If isr affects EL1 vars create Temp_EL1 vars at the start of the routine and use these for the calculation.
    won't work . the isr can change the values as u copy them to the temp vars ,been there done that
    Jun 2009
    Sc*nthorpe, UK
    Ok some problems do not have an answer.
    Bye
    only solution I know is to disable isr and copy vars to a buffer then enable isr and then perform calcs on the buffered data.
    it may mean the odd lost interrupt / whats worse incorrect calcs or missed ints
    only the designer can make that call .
    Feb 2012
    PERTH AUSTRALIA
    the isr updates EL0,EL1 , EL2 during the call
    the isr reloads timer1 every 10ms , then updates EL0-2 variables during that call and displaying them take time ,
    a long as the running display is clearly correct for EL2 =EL1 - set_times for sec,min, hour ,day , then i think it be ok.
    at the moment its just show the totaly wrong values for duration of the set time
    Feb 2012
    PERTH AUSTRALIA
    thanks guys
    ill try both ways i rather not have wrong calculations but i also know this interupt is serviced every 10ms , and the E0-2 varables should be correct for that amount of time ??
    that's the wrong way to think about it , you can never know when the 10ms period will start or finish , this way is better.
    the interrupt latency with a 32mHZ clk will be about 10uS anyway , time to copy 4 bytes to a buffer say 4 uS , the interrupt will only be deferred 4uS plus another couple for the int disable enable worst case you'll hardly notice
    Feb 2012
    PERTH AUSTRALIA
    hI GUYS , using the code by steve seems to work , a small change cos i use EL1 values to show the current time value , so any changes that change the EL1 values in the calculating the EL2 , is not possible so i need to copy the values of EL1 to EL3 , then use EL3 as a temp group
    I am trying to disable the interupt whilest in the ISR subroutine , before the copy of EL0 to EL1-3 , then re -enable interrupt after ,
    but i get a interrupt priority state not found error when compile atm
    it serves no purpose to stop the isr from within the isr , its a waste of time copying the el vars to a buffered copy inside the isr .
    time in your case is in essence a multi byte var , the value is volatile and cannot be guaranteed outside the isr when the isr is running.
    the correct procedure is
    disable isr
    copy bytes to buffer
    enable isr
    do your subtraction
    Feb 2012
    PERTH AUSTRALIA
    ok done that , cheers
    Feb 2012
    PERTH AUSTRALIA
    steve was wodering what the code may be if i was to use the el1 values plus event1 setting to the overrun point , and use say event 2 seting to show the amount time left before overrun , eg EL0 is counting up , copied to EL1 for display , Event 1 setts time for the overrun , Event2 sets time to show time before reching the overrun time , EL3 displays the time counting down to reach time set by Event1 time.
    Jun 2009
    Sc*nthorpe, UK
    Probably easy to do. Post some code from the relevant section for me to look at.
  1. Help with calculation
    Last Post: - 28th August 2012, 17:10
  2. CHECKSUM CALCULATION, Please Help!
    By wasilus in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2012, 07:55
  3. Calculation Problem - value goes to zero after 65
    Last Post: - 12th March 2010, 05:10
  4. calculation
    Last Post: - 20th May 2008, 16:28
  5. CRC Calculation - Need a little help
    By Steve43 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 01:23
