I'm trying to use the RTCC in the PIC18F67J90 with an external 32 KHz watch crystal. I've probed the crystal with my scope and shown that the timer is running it, but for some reason the RTCC refuses to increment. I've also printed the timer1 values, it seems to be counting, but still the RTCC doesn't increment. Also I don't get a pulse output on the RTCC pin (pin 8 on this chip).
Config:
Initialization:Code:#CONFIG CONFIG OSC = HS CONFIG LPT1OSC = OFF CONFIG CP0 = OFF CONFIG WDTEN = OFF CONFIG XINST = OFF CONFIG T1DIG = OFF CONFIG IESO = OFF CONFIG FCMEN = OFF CONFIG WDTPS = 512 CONFIG RTCSOSC = T1OSCREF CONFIG STVREN = ON #ENDCONFIG
Readout Code:Code:initRTCC: RTCCFG = %10000100 T1CON = %10001001 PADCFG1 = %00000010 EECON2 = $55 EECON2 = $AA RTCCFG.5 = 0
Output:Code:readRTC: RTCCFG.1 = 1 : RTCCFG.0 = 1 DEBUG "RTCPRT = ", DEC RTCCFG.1, DEC RTCCFG.0, " ", "H: ", DEC RTCVALH, " L:", DEC RTCVALL,10,13 DEBUG "RTCPRT = ", DEC RTCCFG.1, DEC RTCCFG.0, " ", "H: ", DEC RTCVALH, " L:", DEC RTCVALL,10,13 DEBUG "RTCPRT = ", DEC RTCCFG.1, DEC RTCCFG.0, " ", "H: ", DEC RTCVALH, " L:", DEC RTCVALL,10,13 DEBUG "RTCPRT = ", DEC RTCCFG.1, DEC RTCCFG.0, " ", "H: ", DEC RTCVALH, " L:", DEC RTCVALL,10,13 DEBUG "Timer1: ", DEC TMR1H, ",", DEC TMR1L,10,13 DEBUG "RTC Reads: ", STR hour, ":", STR minute, ":", STR sec,10,13,10,13 pause 2000 goto readRTC
I've been beating my head against this for hours, does anyone have any insight?Code:RTCPRT = 11 H: 0 L:0 RTCPRT = 10 H: 0 L:0 RTCPRT = 01 H: 0 L:0 RTCPRT = 00 H: 0 L:0 Timer1: 77,102 RTC Reads: :: RTCPRT = 11 H: 0 L:0 RTCPRT = 10 H: 0 L:0 RTCPRT = 01 H: 0 L:0 RTCPRT = 00 H: 0 L:0 Timer1: 66,103 RTC Reads: ::
Walter
doh! Sure enough, it's ticking right along now. I didn't realize that register was locked too! Thanks a million!
