Help with Maxim Ibutton "IF THEN ELSE" statements please
Results 1 to 39 of 39
    May 2012
    Merseyside, UK
    Default Re: Help with Maxim Ibutton "IF THEN ELSE" statements please
    mainloop:
    Start:
    OWOUT IBUTTON, 1, [$33], start ; Detect if OW device is present
    Owout ibutton,1,[$33]
    owin ibutton,0,[Serial[0],Serial[1],Serial[2],Serial[3],Serial[4],Serial[5],Serial[6],Serial[7]]
    Edited this from phone so might be dodgy..... Maybe the solution ?
    May 2012
    Merseyside, UK
    Code
    mainloop:
    High led
    pause 250
    low led
    pause 250
    Owout ibutton,1,[$33],mainloop
    'If Serial[1]=$15 and Serial[2]=$D3 and Serial[3]=$7D AND Serial[4]=$16 AND Serial[5]=$00 AND Serial[6]=$00 then correct1
    'If Serial[1]=$68 and Serial[2]=$36 and Serial[3]=$4F AND Serial[4]=$17 AND Serial[5]=$00 AND Serial[6]=$00 then correct2
    'If Serial[1]=$1E and Serial[2]=$1A and Serial[3]=$2C AND Serial[4]=$17 AND Serial[5]=$00 AND Serial[6]=$00 then correct3
    'If Serial[1]=$F0 and Serial[2]=$66 and Serial[3]=$2C AND Serial[4]=$17 AND Serial[5]=$00 AND Serial[6]=$00 then nocache
    If Serial[7]=$E6 then correct1
    If Serial[7]=$90 then nocorrect
    gosub wrong
    Goto mainloop
    We seem to be getting there.... My issue now has changed, I suspect a timing issue.
    It loves the "wrong" gosub...if I hold the button on the contacts all good but the slightest slip and I am in the wrong gosub!
    I have tried just minimising the code to the CRC of the serial and using that but the same results... putting delays in not helping...
    I am hoping it is not the debounce on the contacts.... though we could fix that ??
    Any Ideas anyone
    Thank you ...Andy
    Jun 2009
    Sc*nthorpe, UK
    Change this
    to this
    owin ibutton,0,[Serial[0],Serial[1],Serial[2],Serial[3],Serial[4],Serial[5],Serial[6],Serial[7]],mainloop
    or this
    Jun 2009
    Sc*nthorpe, UK
    I am curious as to how many ibuttons and "doors" you expect to have in your system.
    I have developed an entry system in the past which had many entry points and swipe cards. Hard coding the serial numbers into the program is not the way to go, for all but the smallest systems.
    May 2012
    Merseyside, UK
    Thumbs up Re: Help with Maxim Ibutton "IF THEN ELSE" statements please
    Quote Originally Posted by EarlyBird2 View Post
    Only three Buttons (One Door or in this case Gate)
    The data sheet suggests the pause 100… So that good.
    Have already tried the mainloop label on the Owin as well as the Owout !! (I did read the manual…again!)
    Also seems to be no difference in operation between DS1990R device and DS1990A Device…. The "R" has the Presence…. But Datasheets are sparse !!!
    I am still pondering over timing issues…..I know hardcoding serial numbers is not ideal but it is only small ,,
    Having said that I just made the change from 1k to 2k memory..627 to 628 !
    Also wondering "IF" I can shorten the VAR ARRAYS any!
    Learning a lot here ….. Thank you!
    Jun 2009
    Sc*nthorpe, UK
    You could set up a retry loop.
    mainloop:
    High led
    pause 250
    low led
    pause 250
    for I=1 to 5 'or anything you like
    Next i
    gosub wrong
    Goto mainloop
    change the value of I to test for optimum performance.
    May 2012
    Merseyside, UK
    The retry loop seems to have cured the missreading.... If it dont get it the first time it tries 3 more times... I=3
    I have also put :- If (Serial[1]=$F0) etc in brackets... Tides things up a bit.:-)
    It seems to be working OK now
    Thank you again for help....Maybe see you in Scunny on Monday ...!!!
    THank you all others who helped..... Great Forum!!
    Jun 2009
    Sc*nthorpe, UK
    Andy
    You are welcome. If you need any more help just ask.
    Cheers
  1. Replies: 0
    Last Post: - 14th November 2013, 04:32
  2. Replies: 3
    Last Post: - 15th October 2012, 09:06
  3. Replies: 8
    Last Post: - 3rd March 2011, 23:20
  4. Replies: 5
    Last Post: - 28th February 2011, 16:33
  5. Replies: 1
    Last Post: - 16th February 2005, 21:05
