Help with Maxim Ibutton "IF THEN ELSE" statements please
Results 1 to 39 of 39
    May 2012
    Merseyside, UK
    Default Re: Help with Maxim Ibutton "IF THEN ELSE" statements please
    Could this be the Presence Pulse.. It mentions this in the Datasheet but no command. I Know the 1990R has it the 1990A has not .... I am using a "R"
    Read Rom [33h] or [0Fh]
    Search [F0h]
    Match [55h]
    Skip [CCh]
    Presence [??h]
    Searching around on a phone internet at moment so limited on resources!
    BR
    Andy
    Jun 2009
    Sc*nthorpe, UK
    Could you use the value in S0 as a check. What value does it have with no button and what value with a button? There is also S7 CRC value that could be used in the same way.
    You may need to reset S0 on each loop say to $0 then run owout owin and test the new value.
    Just ideas nothing is tested
  1. Replies: 0
    Last Post: - 14th November 2013, 04:32
  2. Replies: 3
    Last Post: - 15th October 2012, 09:06
  3. Replies: 8
    Last Post: - 3rd March 2011, 23:20
  4. Replies: 5
    Last Post: - 28th February 2011, 16:33
  5. Replies: 1
    Last Post: - 16th February 2005, 21:05
