Long Delays - Is there a valid way?
Results 1 to 9 of 9
    Desterline's Avatar
    Desterline Guest
    The PIC doesn't have an "internal resonator", it has an internal R-C oscilator (some require extrnal parts) an RC oscillator is much less acurate than a resonator or crystal. It also has a much greater temperature coeficient. Meaning that the speed of the osc will be related to the ambient temperature. And yes, it could run fast and slow depending on the temp.
    If the place where you intend to install this has a mostly steady temp, then you could probably get by with a "fudge factor" and get within a couple minutes a day. But remember the error will be cumulative. One minute a day is half an hour a month, six hours a year. To keep it near midnight you'll have to reset it about every 6 months.
    -Denny
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  2. Serial communication fails after long pause
    By brid0030 in forum General
    Last Post: - 13th February 2008, 19:56
  3. Using RTC to generate long time delays
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 01:31
  4. Long varible strings
    By flashg in forum Serial
    Last Post: - 14th October 2006, 05:40
  5. Is "PAUSE 0" a valid command
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 19th July 2006, 17:39
