HPWM statement problems with 18F45K20
Results 1 to 5 of 5
    Default HPWM statement problems with 18F45K20
    According to datasheet, 18F45K20 has up to 5 CCP/PWM modules, which itself have 4 PWM ports and can be configured independently.
    However, Picbasic pro has problem with them - none of them works, and in code like below, you can write ANY port number - no errors will be given.
    hpwm 1,100,1000
    hpwm 2,100,1000
    hpwm 3,100,1000
    hpwm 99,100,1000
    What is the problem?
    OK
    Default Re: HPWM statement problems with 18F45K20
    In your defines you have to state what pin PWM 1 is (as well as 2, 3, 99, etc.; page 148 of the Manual). It looks like this:
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    DEFINE CCP2_REG PORTC
    DEFINE CCP2_BIT 1
    Hope this helps.
    I meant a slightly different thing.
    Say I have 16F870. No specific DEFINE's added.
    Since this chip has 1 hpwm channel only, hpwm 1,100,1000 works. But if I type hpwm 4,100,1000, compiler will give error, since there's no such hardware port. In case of 18F45K20, compiler absolutely does not cares, what port address you enter in hpwm statement. This is the problem.
    Does 16F870 have PWM enabled by default?
    What about 18F45K20?
    I make it a habit not to assume and set feature registers as required.
    According to manual, HPWM statement does all required configs by itself.
    Here not problem in HPWM not working, here problem is compiler passing any garbage to hpwm statement without error.
  1. Configuration bits 18F45K20
    By robertg in forum mel PIC BASIC Pro
    Last Post: - 19th September 2013, 08:31
  2. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  3. Blink.Bas on 18f45k20 Newbie seeks working example.
    By DiscoEd in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 03:36
  4. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 01:09
  5. HPWM problems
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 8th November 2006, 07:23
