When i compile it, it shows me syntax error in the lines from #header till #ENDCONFIG
Ok. I compile it. According to http://melabs.com/support/config_defaults.htm i change the settings in PBP 16F1824.inc file and i add @ at the beggining of config.
I will inform you for the results.
Thank you!
