PIC16F1824, problem with oscillator and RA3,RA4,RA5
Results 1 to 16 of 16
    Nov 2013
    Default Re: PIC16F1824, problem with oscillator and RA3,RA4,RA5
    Ok, with the oscillator, but the problem with RA3,RA4 and RA5 continue.
    I replace the pic with another 1824 with no better result.
    Is this the read-modify-write issue?
    (I never remember the details)
    I would try turn on 1 second, off 1 second, goto start (keep it simple blinker to start).
    Nov 2013
    Thank you for your reply, I will try it.
    But the mystery is that RA0,RA1,RA2 working.
    I will try it with simpler code.
    Nov 2013
    Thank you gunayburak for your answer.
    I add it to the code and i will try it.
    I also focus the problem in fuse settings.
    How will you define the fuse settings ?
  1. Power up problem with PIC16F1824
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 29th April 2013, 16:11
  2. PIC16F685 RA4/RA5 pins
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 16:45
  3. PIC18F2320 RA4 output problem
    By Kristjan in forum General
    Last Post: - 31st May 2007, 00:56
  4. problem with output RA2 and RA3
    Last Post: - 8th December 2006, 14:49
  5. RA5/MCLR input in 16f88
    By kacho in forum mel PIC BASIC Pro
    Last Post: - 5th April 2005, 18:21
