this is driving me nuts lol... still cant figure out why it hangs on the owout command, no matter how it's done, what port, config settings, etc.. Have no problems at all with it on other pics.
(ugly but working temp recorder/readout to monitor our flaky fridge)
@ device pic12F683, intrc_osc_noclkout
@ device pic12F683, wdt_on
@ device pic12F683, mclr_off
@ device pic12F683, protect_off
DEFINE OSC 8
OSCCON.0=1    'system clock select bit 1=internal 0=config word
OSCCON.4=1    'set int osc to 8MHZ
OSCCON.5=1
OSCCON.6=1
ANSEL.3=0     'set all digital
ANSEL.2=0
ANSEL.1=0
ANSEL.0=0
CMCON0=7      'turn comparators off!
ADCON0=0      'turn ADC off
GPIO.7 = 0    'enable weak pullups  'NOTE: this didn't work for one wire or i2c coms.
WPU = %00111000                     '   had to use external pullup anyways (did I set it wrong?)
DEFINE DEBUG_REGG GPIO         'set debug port to porta
DEFINE DEBUG_BIT 0             'use pin a0 of porta for debug
DEFINE DEBUG_BAUD 9600         'set baud rate to 2400
DEFINE DEBUG_MODE 0            'communicate in true mode
                               '12f683 is 14bit, no scl/sda defines
SCL var GPIO.4 ' Clock pin
SDA var GPIO.5 ' Data pin
readbutton var GPIO.3
maxsensor con 4
trisio.3 = 1                   ' switch logging/readout stored temps (using mclr pin, mclr disabled)
Cold_Bit    VAR Raw.Bit11      ' Sign-Bit for +/- Temp. 1 = Below 0 deg C
id          var byte[8]
ADDR        var WORD           ' 24c32a uses 2 bytes for address (24lc256 as well)
raw         var word
records     var word
recordaddr  var word
readloops   var word
readaddr    var word
tempc       var word
tempf       var word
Sign        VAR byte            ' +/- sign for temp display
fsign       var byte
sensor      var byte
hexbyte     var byte
col         var byte
busy        var bit
rsign       var bit
CLEAR
recordaddr = 31998 'store records at end (been writing to address 0 too much)
ADDR = 2      ' normal start address
'addr = 31960 'temporary testing eeprom full
goto start
subC_TO_F:
    'DISABLE ' Necessary if On Interrupt used
    'tempF = tempC * 9
    'tempf = DIV32 5
    'ENABLE ' Necessary if On Interrupt used
    tempf = (tempc */ 461)
    IF rsign = 1 THEN 'if the sign bit is "1" is minus C
      IF tempF > 3200 THEN
       fsign="-"
        tempF = tempF - 3200
        'SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/100,".",DEC2 C," C  = -",DEC F/100,".",DEC2 F," F",13]
      fsign="+"
        tempF = 3200 - tempF
        'SEROUT2 sSEROUT_PIN,cBAUD,[" -",DEC C/100,".",DEC2 C," C  = ",DEC F/100,".",DEC2 F," F",13]
      tempF = tempF + 3200
      fsign = "+"
      'SEROUT2 sSEROUT_PIN,cBAUD,["  ",DEC C/100,".",DEC2 C," C  = ",DEC F/100,".",DEC2 F," F",13]
GetID:
    Select Case sensor
        Case 1 :LOOKUP hexbyte,[$28,$00,$3E,$D8,$05,$00,$00,$10], col
        Case 2 :LOOKUP hexbyte,[$28,$E1,$E2,$D6,$05,$00,$00,$64], col
        Case 3 :LOOKUP hexbyte,[$28,$3C,$75,$D6,$05,$00,$00,$0C], col
        Case 4 :LOOKUP hexbyte,[$28,$4F,$62,$D8,$05,$00,$00,$F5], col
        'Case 5 :LOOKUP hexbyte,[], col
        'Case 6 :LOOKUP hexbyte,[], col
        'Case 7: LOOKUP hexbyte,[], col
        'Case 8 :LOOKUP hexbyte,[], col
        'Case 9 :LOOKUP hexbyte,[], col
    end select
IDLOOP:
    for hexbyte=0 to 7  'each sensor address is 8 bytes
            gosub getid     'go look up each sensors address
            id[hexbyte]=col 'load the ID array with the retrieved address byte
    next hexbyte
DisplayTemp:                        ' +32.0 to +257 F
    IF raw.bit15 = 1 THEN   ' If Cold_Bit = 1, it's below "0" deg C
    rsign = 1
    Sign  = "-"
    sign = "+"
    raw = abs(raw)
    tempc = raw */ 1600
    'tempf = (tempc */ 461) + 3200
     debug $0D,$0A,"reading : ",dec records
     if readbutton = 1 then debug " - Sensor: ",dec1 sensor
     debug "  ",sign, DEC (tempc / 100), ".", DEC2 tempc, " C "
     gosub subc_to_f
     debug " / ",fsign, DEC (tempf / 100), ".", DEC2 tempf, " F "
START:
pause 800
IF readbutton = 0 then readstart
ReadSensor:
    OWOUT GPIO.2, 1, [$cc,$44] 'skip romcheck (only one sensor), initiate[$44] temperature conversion
Ckbsy:
    OWIN GPIO.2, 4, [busy]      ' Check for still busy converting
    IF busy = 0 THEN ckbsy  ' Still busy?, then loop
    sensor = sensor + 1
    if sensor = maxsensor+1 then sensor = 1
    gosub idloop
    'owout GPIO.2,1,[$cc,$BE]   'skiprom (one sensor only) send back scratchpad[$BE]
    owout GPIO.2,1,[$55,str id\8,$BE]   'instructs sensors to match[$55] this[ID] and start sending back scratchpad[$BE]
    OWIN GPIO.2, 2, [Raw.LOWBYTE,Raw.HIGHBYTE]
        if addr > 31997 then
            debug "eeprom full, not stored"
            I2CWRITE SDA,SCL,$A0,ADDR,[raw.lowbyte,raw.highbyte]
            records = addr / 2
            i2cwrite sda,scl,$A0,recordaddr,[records]
            addr = addr + 2
   gosub displaytemp
goto start
readstart:
  readaddr = 0
  i2cread sda,scl,$A0,recordaddr,[records]
  readloops = records*2
rloop:
    while readaddr < readloops
    pause 50
    I2CREAD SDA,SCL,$A0,readaddr,[raw.lowbyte,raw.highbyte]
    readaddr = readaddr + 2
    records = readaddr / 2
    gosub displaytemp
    IF readbutton = 1 then start
    wend
goto start
really frustrating as I really wanted to use one of these 16f77 boxes I have.
