I have a headache.....INPUT anyone?
Results 1 to 3 of 3
    Default I have a headache.....INPUT anyone?
    Could someone please enlighten me as to why this doesn't work on a PIC16F688?
    led1 var porta.2
    led2 var portc.2
    onoff var word
    sig var word
    p0 var word
    trisa.2 = 0
    trisc.2 = 0
    trisc.3 = 1
    trisa.0 = 1
    ADCON0 = 1
    onoff = portc.3
    If onoff = 1 then <----Hangup is here
    high led1
    ADCIN 0,p0
    sig = p0*4
    pause(sig)
    high led2
    pause(sig)
    low led2
    low led1
    low led2
    If I write it unconditional, it works beautifully. As soon as I try to tell it "only if C.3 is high" nothin...
    If I tell it "only if C.3 = 0"... works fine.
    I've also tried
    if (PORTC.3 = 1) THEN
    and
    if PORTC.3 = 1 THEN
    and
    onoff = PORTC.3
    if onoff = 1 then
    and
    if (onoff = 1) then
    According to everything I have found online, any of these should work. I'm apparently missing something.....
    Default Re: I have a headache.....INPUT anyone?
    PortC.3 is also AN7 and the pins comes up in analog mode by default, to use the pin as a digital onput you need to enable the digital circuitry.
    See the ANSEL register and also the CMCON register even though it's not related to PortC.7 specifically.
    Thanks so much! added ANSEL = 0 and works like a charm!
  1. Have a headache - need some suggestions with code logic
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 20th October 2013, 16:45
  2. Need some input
    By dhouston in forum Off Topic
    Last Post: - 7th March 2012, 13:23
  3. Mplab headache lol
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 26th December 2009, 01:58
  4. Real time clock... what a headache!
    By Eng4444 in forum mel PIC BASIC
    Last Post: - 8th June 2006, 22:56
  5. DS1820 headache
    By Calco in forum mel PIC BASIC Pro
    Last Post: - 12th August 2004, 01:28
