PIC to PIC communication between 18F4620 & 10F202
Results 1 to 9 of 9
    May 2014
    Default Re: PIC to PIC communication between 18F4620 & 10F202
    Re: Jerson
    Thank you for your answer.
    After reading your post I started testing with loops, but did not work. Now I will try interrupt.
    If you can not get it working in a loop you will never get an interrupt to work.
    Take a look at this
    http://melabs.com/samples/PBP-mixed/serin.htm
    Have you set DEFINE_OSC to proper values on both chips? various speeds can cause devices not to listen each other properly, unless you use HSERIN statement.
  1. Fast yet reliable PIC-PIC communication?
    Last Post: - 27th September 2009, 15:34
  2. Pic 18f4620
    By 78Davide in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:24
  3. Coding Style - PIC 18F4620 config fuses
    Last Post: - 8th January 2008, 20:05
  4. SPI PIC to PIC Bi-Directional Communication
    By CocaColaKid in forum Serial
    Last Post: - 23rd December 2006, 22:44
  5. PIC to PIC RS485 with users the communication
    By x0914667 in forum Serial
    Last Post: - 21st July 2005, 00:20
