Help with using variables
Results 1 to 3 of 3
    you could also use SELECT CASE
    select case MyVar
         case XYZ
              ' according stuff
         case XYZ AND ABC
              ' according stuff
         end select
    but i've never try with the AND in a select case... but it should work.
    Case not
    select case MyVar
         Case ABC
              If Myvar=XYZ then
                   'According stuff for Myvar = ABC AND =XYZ
         end select
    Hangover, Germany
    Hello,
    it's hard for me to understand your problem.
    What does it matters with the headline ?
  1. Max Variables
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 05:05
  2. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 15:36
  4. edit names of variables
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th January 2005, 22:00
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 19:37
