Help with using variables
Results 1 to 3 of 3
    jessey's Avatar
    jessey Guest
    Default Help with using variables
    Hello,
    I was wondering if someone could review some code I wrote and make suggestions on any different approaches or more efficient ways of accomplishing this? I have these 2 segments of code that will be read in the mainloop. Of these 2 segments of code only one will be true so only one will be executed. When I first apply power to the circuit then one of these blocks of code is only executed once and also whenever I switch from operating the circuit on batteries to a 120 VAC transformer (or vise versa) then the other code segment will be true and will be executed again but only once while in the mainloop. The reason that I want to do this is that I have other If...Then statements that use this same variable to accomplish other tasks in the mainloop.
    Here are the two segments code:
    Circuit_Is_Powered_By VAR PORTC.5 'when the transformer is plugged in, a 1 is placed here.
    The_Transformer CON 1
    The_Batteries CON 0
    IF Circuit_Is_Powered_By = The_Batteries THEN
    U = 0
    U = U + 1
    IF U >= 2 THEN U = 2 'prevents the var from rolling over & equaling 1 again
    '----------------------- First Segment Of Code -----------------------------'
    IF Circuit_Is_Powered_By = The_Transformer AND U = 1 THEN
    this is where I place the code that I want to be read only
    once whenever the transformer is powering the circuit.
    IF Circuit_Is_Powered_By = The_Transformer THEN
    V = 0
    V = V + 1
    IF V >= 2 THEN V = 2 'prevents the var from rolling over & equaling 1 again
    '---------------------- Second Segment Of Code -----------------------------'
    IF Circuit_Is_Powered_By = The_Batteries AND V = 1 THEN
    once whenever the batteries are powering the circuit
    Any comments or suggestions will be gratefully accepted.
    Thanks jessey
    you could also use SELECT CASE
    select case MyVar
         case XYZ
              ' according stuff
         case XYZ AND ABC
              ' according stuff
         end select
    but i've never try with the AND in a select case... but it should work.
    Case not
    select case MyVar
         Case ABC
              If Myvar=XYZ then
                   'According stuff for Myvar = ABC AND =XYZ
         end select
    Hangover, Germany
    Hello,
    it's hard for me to understand your problem.
    What does it matters with the headline ?
  1. Max Variables
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 04:05
  2. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 14:36
  4. edit names of variables
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th January 2005, 21:00
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 18:37
