How to setup pbp3 with MPLABX?
Results 1 to 17 of 17
    Default Re: How to setup pbp3 with MPLABX?
    I agree , i'm heading back to mikro C for new projects . their latest update enables source level debugging for some of the newer chips ,finally!
    wrong [again] its almost if nobody wants anyone to be able to use 8 bit pic chips any longer .
    the chips can be now compiled for and programmed but that's it , no icd support.
    pic16f1619 is a no go for icd
    Aug 2011
    It's not entirely clear, but you might need the AC244066 Emulation Extension Pak to debug the 16F1619.
    Only if you got MPLAB REAL ICE...
    Aug 2011
    Looking at it again I think you're right. I was looking in the datasheet and didn't see anything about debug support.
    According to mplabx 4 the 16F1619 should be supported by PK3 and ICD3.
    Which MPLABX in turn does not support PBP3...
    Back to square 1.
  1. Integrate PBP3 in MPLABX.
    By Ziko87 in forum PBP3
    Last Post: - 21st May 2013, 14:41
  2. PBP3 Long setup
    By iphillipsca in forum mel PIC BASIC Pro
    Last Post: - 30th October 2012, 21:03
  3. Can't get ISIS/Proteus VSM to work with PBP3 and MPLABX
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 28th July 2012, 21:45
  4. PIC16F777 - setup
    By orjon1 in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2011, 21:17
  5. ADCIN setup help need
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 26th February 2008, 16:22
