DHT22 and PIC18F25K22
Results 1 to 3 of 3
    Sep 2005
    France
    Default DHT22 and PIC18F25K22
    Hi I'm using a PIC18F25K22 to drive 2x DHT22.
    I found here some code working on PORTB.4
    The other DHT is connected on PORTB.2 and... not working
    I tried to exchange the 2 DHT22 without success. The 2 DHT22 are working fine on portB.4
    sequence is:
    TRISB.2 = 1 'input
    my program... then
    TRISB.2 = 0 'output
    PORTB.2 = 0 'low
    With my DSO, I can see something strange. It takes more than 1mSec to become low (see curve)
    This is only on PORTB.2 !
    May be you have an idea ? (I'm using PBP2.60)
    Oct 2009
    Default Re: DHT22 and PIC18F25K22
    Have a read of this thread http://www.picbasic.co.uk/forum/showthread.php?t=19975
    The excellent library file allows multiple sensors to be used (I have four running to monitor temperature and humidity in my reptile enclosures)
    Sep 2005
    France
    Hi Scampy,
    Yes this code is well done... But I'd like to use my own...
    I tried another PIC (18f2520) = same pb, changing pullup resistors, capacitors...
    I just found the problem... It's an hardware problem. Can't see it without binoculars... soldering to ground on PCB was not good
    Thank you.
  1. pic18f25k22 clock
    By connortop in forum mel PIC BASIC Pro
    Last Post: - 14th September 2016, 17:42
  2. DHT22, AM2302 and pic18F2320
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 15th November 2015, 00:42
  3. DHT22 interface problem
    By mazytis in forum Code Examples
    Last Post: - 25th July 2015, 03:01
  4. dht22 using bit field array and ext references
    By richard in forum Code Examples
    Last Post: - 1st April 2015, 03:20
  5. PIC18f25k22 help with OSC configs
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 7th February 2012, 18:23
