MPPT solar battery charger
Results 1 to 40 of 41
    Jun 2008
    Varese , Italy
    Default Re: MPPT solar battery charger
    Demon,
    thanks for having respond to my msg.
    here is the code.
    I will re_draw the schematics ( by hand )in a decent way tonight. I will post it tomorrow.
    thnks
    Ambrogio
    '*  Name    :  pic 18f4523                                      *
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 28/04/2014                                        *
    '*  Notes   : modificare file 18f4523 nella cartella PBP        *
    '*          : per il config ... oscillatore MCLR etc            *
    '* picbasic pro 2.6  : long used.  12294 BYTES USED.            *
    '* 50 WATT SOLAR PANEL, 27 AH 12 VDC SLA BATTERY                *
    ' WARNING:
    ' HSPLL OSCILLATOR HAS BEEN DEFINED IN THE PBP FOLDER > 18F4523 FILE
    DEFINE OSC 40    ' 10 MHz XTAL  AND x4 PLL GIVES 40 MHz CLOCK SPEED.
    INCLUDE "MODEDEFS.BAS"
    'DEBUG DEFINITION> WITH_OUT MAX 232...USE INVERTED=1, 57600 BAUD 8N1
    ' Set Debug pin port   ________________________________________
    DEFINE DEBUG_REG PORTC
    ' Set Debug pin bit   _________________________________________
    DEFINE DEBUG_BIT 6
    ' Set Debug baud rate _________________________________________
    DEFINE DEBUG_BAUD 57600
    ' Set Debug mode: 0 = true, 1 = inverted ______________________
    DEFINE DEBUG_MODE 1
    ' LCD CONFIGURATION ...HD_4470 LIKE > 4 LINES BY 20 CHRS IS USED HERE
    ' Set LCD Data port   _________________________________________
    DEFINE LCD_DREG PORTD
    ' Set starting Data bit (0 or 4) if 4-bit bus ________
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port  (R/S)  ________________________
    DEFINE LCD_RSREG PORTD
    ' Set LCD Register Select bit   _______________________________
    DEFINE LCD_RSBIT 5
    ' Set LCD Enable port    (EN_DCDC)__________________________________
    DEFINE LCD_EREG PORTD
    ' Set LCD Enable bit       ____________________________________
    DEFINE LCD_EBIT 4
    ' Set LCD bus size (4 or 8 bits)  _____________________________
    'DEFINE LCD_BITS 4
    ' Set number of lines on LCD     ______________________________
    DEFINE LCD_LINES 4
    ' Set command delay time in us   ______________________________
    DEFINE LCD_COMMANDUS 2500
    ' Set data delay time in us   _________________________________
    DEFINE LCD_DATAUS 50
    PAUSE 500
    '  SOME CONSTANTS TO CONTROL THE LCD.
    INS   CON 254 '   $FE: INSTRUCTION COMMAND MODE
    CLR   CON 1   '   CLEAR LCD , GOTO FIRST LINE, FIRST CHARACTER
    DG    CON 223 '   SIMBOLO DEL GRADO °
    LINE1 CON 128 '   $80: GOTO LINE 1
    LINE2 CON 192 '   $C0: GOTO LINE 2
    LINE3 CON 148 '   $94: GOTO LINE 3
    LINE4 CON 212 '   $D4: GOTO LINE 4
    ' eg.: LCDOUT INS, LINE1, "PIBPO TXT=",........
    ' ADC CONFIGURATION
    ADCON1=%00001010   ' AN0,AN1,AN2,AN3,AN4 ENABLED.THE REMAINING PINS ARE DIGITAL
    VB_ADC VAR WORD    ' AN0 PIC_PIN 2     ' BATTERY VOLTAGE
    VP_ADC VAR WORD    ' AN1 PIC_PIN 3     ' PANEL VOLTAGE
    IP_ADC VAR WORD    ' AN2 PIC_PIN 4     ' PANEL CURRENT
    IB_ADC VAR WORD    ' AN3 PIC_PIN 5     ' BATTERY VOLTAGE
    POT_ADC VAR WORD   ' AN4 PIC_PIN 7     ' POT VOLTAGE FOR MANUAL DUTY INPUT...
    ' FILTERS          '........................................................
    IPT VAR WORD
    VPT VAR WORD
    VBT VAR WORD
    IBT VAR WORD
    AVG VAR BYTE
    AVG=8               ' MAX AVG=16  4096*16=65536  IN A WORD !    PANEL  data
    AVG_B VAR BYTE
    AVG_B=4             ' MAX AVG_B=16  4096*16=65536  IN A WORD !  BATTERY data
    I VAR BYTE
    Y VAR BIT
    Y=0
    Z VAR BYTE
    Z=0
    DLY_FLG VAR BIT
    DLY_FLG =1
    IPF_ADC VAR WORD
    VPF_ADC VAR WORD
    VBF_ADC VAR WORD
    IBF_ADC VAR WORD
    VP VAR LONG
    IP VAR LONG
    VB VAR LONG
    IB VAR LONG
    WP VAR LONG
    WB VAR LONG
    IBSIGN VAR BYTE    ' BATTERY CURRENT SIGN
    DUTY VAR WORD      ' PIC PWM DUTY CYCLE CONTROL
    DUTY=150           '  START  AT MINIMUM DUTY
    GOSUB SET_PWM
    DUTY_S VAR BYTE    ' DUTY CYCLE STEP for MPPT
    DUTY_S=1           ' MUST BE WIDE ENOUGH TO OVERCOME PANEL DATA NOISE !
                       ' IF MPP IS NOT FOUND USE 2, 3, 4 OR 5...
    LD_EN VAR PORTC.1  ' PIC_PIN 16   LOAD POWER MOSFET CONTROL PIN
    LOW LD_EN          ' DISABLE LOAD POWER MOSFET
    EN_DCDC VAR PORTC.3     ' PIC_pin 18   DC/DC CONVERTER ENABLE
    low EN_DCDC             ' DISABLE DC/DC CONVERTER
    LOAD VAR BIT
    LOAD=1
    MODE VAR BYTE
    MODE=0
    STATE VAR BYTE
    STATE=0
    ' STATE 0= OFF
    ' STATE 1= ON
    ' STATE 3= FLOAT
    ' STATE 4= BULK
    DV VAR BIT         ' PANEL DELTA VOLT USED FOR HILL CLIMBING
    DP VAR BIT         ' PANEL DELTA POWER
    VP_OLD VAR LONG    ' OLD PANEL VOLTAGE
    WP_OLD VAR LONG    ' OLD PANEL POWER
    ' SCAN FOR MPP ......................
    WPMAX VAR LONG
    WPMAX=0
    VPMAX VAR LONG
    VPMAX=0
    IPMAX VAR LONG
    IPMAX =0
    VBMAX VAR LONG
    IBMAX VAR LONG
    WBMAX VAR LONG
    DUTYMAX VAR BYTE
    DUTYMAX=0
    ' BACK LIGHTING    ......................................................
    BCK_LT VAR PORTA.4     ' PIC_PIN 6
    FOR I=3 TO 0 STEP -1   ' LCD BACK LIGHT TEST AT POWER ON
        HIGH BCK_LT
        pAUSE 100
        LOW BCK_LT
        PAUSE 100
    NEXT I
    HIGH BCK_LT            ' LEAVE BACK LIGHT ON AT THE END ...
    ' EXTERNAL POWER  ........................................................
    EXT_PWR_RLY VAR PORTC.0    ' PIC_PIN 15 OUTPUT CONTROL FOR EXT_PWR SOURCE RELAY
    HIGH EXT_PWR_RLY           ' DISABLE EXT PWR_RELAY   HIGH= DISABLE
    EXTPWR_OK VAR PORTC.4      ' PIC_PIN 23  INPUT > POWER_LINE STATUS; 1=OK
    U_VOLT VAR BIT             ' EXT POWER MONITOR
    U_VOLT=0                   ' EXT POWER GOOD
    U_FLG VAR BIT      ' BATTERY UNDERVOLTAGE FLAG
    U_FLG=1
    EX VAR BIT
    EX=0
    ' SPLASH SCREEN:
    Lcdout INS,line1, "Ambrogio 06/04/2014 "    ' LCD CHECK
    Lcdout INS,line2, "PV PIC18F4523       "
    debug 13,10,13,10
    DEBUG " STARTING H E R E ! ! ! ! "          ' SERIAL LINK CHECK
    PAUSE 1000
    LCDOUT INS,CLR                              ' TURN LCD OUT
    ' PUSH BUTTONS PIN ASSIGNEMENT
    PB_1 VAR PORTE.0       'PIC_PIN 8  STEPS THROUGH THE MODES
    PB_2 VAR PORTE.1       'PIC_PIN 9
    PB_3 VAR PORTE.2       'PIC_PIN 10  TOGGLE LOAD MOSFET
    MAIN:  ' ************************************************************
    ' PB_1 SELECTS THE MODES ...
    ' mode =0 is THE normal OPERATING MODE
    ' mode =1 pot input controls the duty cycle
    ' mode =2 scan duty cycle to search for the MPP CONDITION
    ' mode =3 TOGGLES the duty cycle to see the system response caracteristics
    ' MODES SELECTION....................
    IF PB_1=0 THEN          ' MODE SELECTION...
       MODE=MODE+1
       IF MODE >=4 THEN
          MODE=0
       IF MODE=1 THEN
          LCDOUT INS, CLR
          HIGH EN_DCDC
       IF MODE=2 THEN
          LCDOUT INS, CLR
          WPMAX=0         ' reset maximum registers
          VPMAX=0
          IPMAX=0
          VBMAX=0
          IPMAX=0
          WBMAX=0
          DUTYMAX=0
          HIGH EN_DCDC
          DUTY=150          ' THIS IS MY MINIMUM DUTY CYCLE
          GOSUB SET_PWM
          PAUSE 1000
       IF MODE=3 THEN
          LCDOUT INS, CLR
          LCDOUT INS, LINE1, " DC STEP TEST "
    WHILE PB_1=0: WEND
    ' LOW VOLTAGE PROTECTION ...and load control..................................
    IF ( VB<11800 ) THEN       ' BATT LOWER THAN 11.8 Vdc
       U_VOLT=1                ' SET UNDER_VOLTAGE FLAG
       LOAD=0
       U_FLG=1
        IF ( VB>12600 ) THEN   ' IF VBATT MORE THAN 12.6 Vdc
           U_VOLT=0            ' RESET UNDER_VOLTAGE FLAG
           IF U_FLG=1 THEN
              HIGH LD_EN       ' ENABLE LOAD
              LOAD=1
              U_FLG=0
    IF (U_VOLT=1) AND (EXTPWR_OK=1) THEN
       LOW EXT_PWR_RLY             ' ACTIVATE EXT POWER RELAY
       EX=1
        IF U_VOLT=0 THEN
           HIGH EXT_PWR_RLY        ' RELASE EXT POWER RELAY
           EX=0
    IF U_VOLT=0 THEN
        IF PB_3=0 THEN
           if LOAD=0 THEN
              LOAD=1
              LOAD=0
           IF LOAD=0 THEN
              LOW LD_EN
           IF LOAD=1 THEN
              HIGH LD_EN
        WHILE PB_3=0 : WEND
    ' MODES MANAGEMENT BY PUSH BUTTONS ...........................................
    IF MODE=0 THEN         ' NORMAL MODE  ........................................
       GOTO NORMAL_MODE
    IF MODE=1 THEN         ' POT CONTROLLED DUTY CYCLE............................
         LCDOUT INS, LINE1,"POT CONTROLLED DUTY:"
         GOSUB ACQ_POT     ' ACQ TAKES ABOUT 2.3 mSEC
         DUTY=((POT_ADC/39)+149)   ' POT CONTROLS DUTY 0>4096 = 150 to 254
         GOSUB SET_PWM
         GOSUB GET_PANEL_DATA
         GOSUB GET_BATTERY_DATA
         LCDOUT INS, LINE3,DEC VP/1000,".",DEC1 VP/100,"  ",DEC IP/1000,_
               ".",DEC2 IP/10,"  ",DEC WP/1000,".",DEC1 WP/100," ", DEC DUTY,"  "
         LCDOUT INS, LINE4,DEC VB/1000,".",DEC1 VB/100," ",IBSIGN,DEC IB/1000,_
               ".",DEC2 IB/10, " ",IBSIGN,DEC WB/1000,".",DEC1 WB/100,"  "
         GOSUB SERIAL_OUT
         GOTO MAIN
    IF MODE=2 THEN         ' SCAN DUTY CYCLE FOR MPP SEARCHING.................
       DUTY=DUTY+1         ' INCREMENT DUTY CYCLE
       GOSUB SET_PWM
       PAUSE 10            ' NOT REALLY NEEDED .. LCDOUT PROVIDES TIME DLY
       IF WP> WPMAX THEN   ' STORE MAX READINGS
          WPMAX=WP
          VPMAX=VP
          IPMAX=IP
          VBMAX=VB
          IBMAX=IB
          WBMAX=WB
          DUTYMAX=DUTY
       IF DUTY >= 254 THEN
          LCDOUT INS, CLR
          LCDOUT INS, LINE1, " MAX POWER :        "
          LCDOUT INS, LINE3,DEC VPMAX/1000,".",DEC1 VPMAX/100,"  ",_
                 DEC IPMAX/1000,".",DEC2 IPMAX/10,"  ",DEC WPMAX/1000,_
                 ".",DEC1 WPMAX/100," ", DEC DUTYMAX
          LCDOUT INS,LINE4,DEC VBMAX/1000,".",DEC1 VBMAX/100,"  ",_
                 DEC IBMAX/1000,".",DEC2 IBMAX/10,"  ",DEC WBMAX/1000,_
                 ".",DEC1 WBMAX/100
          DUTY=150
          GOSUB SET_PWM
          while PB_2=1 :wend       ' WAIT FOR PB_2 TO BE PRESSED
       lcdout ins, line1, "MAX PWR SEARCHING:"
       GOSUB SERIAL_OUT
       GOTO MAIN
    IF MODE=3 THEN    'DUTY STEP CHANGE RESPONSE TEST > SET TWO DUTY VALUES
                      'SET PAUSE FOR STEP TIME_WIDTH ,,,,,,,,,,,,,,,,,,,,,,,,,
                      ' system response time to duty change is about 15 msec
                      ' measured with a scope
       STEP_DUTY:
       IF Y=0 THEN
          HIGH BCK_LT      ' CONNECT TO SCOPE TRIGGER INPUT
          DUTY=170         ' FIRST DUTY VALUE
          GOSUB SET_PWM
          Y=1
          PAUSE 50         ' WIDTH
          GOSUB SERIAL_OUT
       IF Y=1 THEN
           low bck_lt
           DUTY=175       ' SECOND DUTY VALUE  > DUTY_step is 5 now
           GOSUB SET_PWM
           Y=0
           PAUSE 50       ' step time WIDTH  IS 50 MSEC
           GOSUB SERIAL_OUT
           GOTO MAIN
    NORMAL_MODE:    '*************************************************************
    ' BATTERY STATE CONTROL ......................................................
    GOSUB GET_PANEL_DATA         ' 2.3 msec x avg
    GOSUB GET_BATTERY_DATA       ' 2.3 msec x avg_b
    SELECT CASE STATE       ' MODIFIED TIM NOLAND PROGRAM IN c LANGUAGE... ( ! )
         CASE 0    ' OFF  ***  * * * * * * * * * * * * * * * * * * * * * * * * * *
             Z=Z+1
             IF Z>=254 THEN  ' wait sometime for the battery to settle down
                DLY_FLG=0
             DUTY=150       ' MINIMUM DUTY CYCLE.
             low EN_DCDC         ' DISABLE DC / DC CONVERTER
             GOSUB SET_PWM
             debug dec z,13,10
             IF DLY_FLG=0 THEN
                 IF VP > VB+1500 THEN      ' day light is coming ...
                    IF VB < 13800 THEN
                        DUTY=150
                        HIGH EN_DCDC
                        GOSUB SET_PWM
                        PAUSE 1000
                        STATE=1 ' >> ON
         CASE 1    ' ON  ***  * * * * * * * * * * * * * * * * * * * * * * * * * *
             HIGH EN_DCDC
             IF (VP < VB) and ( IP<80 ) THEN     ' it is dark
                DLY_FLG=1  : Z=0
                DUTY=150
                GOSUB SET_PWM
                STATE= 0  ' >> OFF
             IF VB > 14800 THEN        ' MAX BATTERY VOLTAGE IS 14.8 VDC
                STATE=2   ' >> FLOAT
                DUTY=150
                GOSUB SET_PWM
             IF ( WP < 5000 ) THEN
                DUTY=254
                GOSUB SET_PWM
             IF WP> 5000 THEN
                DUTY=240
                GOSUB SET_PWM
                STATE=3   ' >> BULK
         CASE 2   ' FLOAT  *** * * * * * * * * * * * * * * * * * * * * * * * * *
             HIGH EN_DCDC
             IF VB > 14200 THEN      ' KEEP FLOAT VOLTAGE @ 13.8 TO 14.2 VDC
                DUTY=DUTY-1          ' DECREASE DUTY
                GOSUB SET_PWM
             IF VB < 13800 THEN
                DUTY=DUTY+1          ' INCREASE DUTY
                GOSUB SET_PWM
             IF DUTY >= 254 THEN
                 DUTY=200
                 GOSUB SET_PWM
                 STATE=3  ' >> BULK
                DLY_FLG=1 : Z=0
                DUTY=150
                GOSUB SET_PWM
                STATE=0 '  >> OFF
         CASE 3   ' BULK
             HIGH EN_DCDC
             IF (WP < 5000)  THEN
                STATE= 1  ' >> ON
             IF WP >= 5000 THEN
                GOSUB MPPT
                 DLY_FLG=1  : Z=0
                 DUTY=150
                 GOSUB SET_PWM
                 STATE=0  ' >> OFF
             IF VB > 14800 THEN
                DUTY=150
                GOSUB SET_PWM
                STATE=2  ' >> FLOAT
    END SELECT
    ' DATA OUTPUT TO LCD, SERIAL AND RADIO.......................................
    GOSUB DIS_LCD         ' execution time is 15 msec
    GOSUB SERIAL_OUT      ' execution time is 25 msec
    GOTO MAIN             ' main loop execution time is 65 msec if avg=8 and
                          ' avg_b=4
    '========================  SUBROUTINES  =====================================
    ACQ_PV:    'ACQUIRE PV ANALOG DATA      ... 2.3 msec ........................
        ' READ ANALOG 0 VP   .........................
        ADCON0=%00000000    ' SELECT AN0, VP
        ADCON2=%10100110    ' ACQ TIME AND FOSC SELECTION
        ADCON0=%00000001    ' ON, ACCESO
        PAUSE 1             ' INPUT RESISTANCE AND CAP FOR DC ACQISISTION
        ADCON0=%00000011    ' ON + GO
        WHILE ADCON0.1=1    ' WAIT FOR CONVERSION COMPLETED , DONE
        WEND
        VP_ADC=(ADRESH<<8) + ADRESL   ' ADC RESULT  12 BIT
        ADCON0=%00000000    ' TURN OFF,
        'READ ANALOG 2 IP    ........................
        ADCON0=%00001000    ' SELECT AN0, IP
        ADCON0=%00001001    ' ON, ACCESO
        ADCON0=%00001011    ' ON + GO
        WEND
        IP_ADC=(ADRESH<<8)+ ADRESL   ' ADC RESULT  12 BIT
    ACQ_BATT:    ' ACQUIRE BATTERY ANALOG DATA   ........ 2.3 msec ................
        ' READ ANALOG 1 VB  ..........................
        ADCON0=%00000100    ' SELECT AN0, VB
        ADCON0=%00000101    ' ON, ACCESO
        ADCON0=%00000111    ' ON + GO
        WEND
        VB_ADC=(ADRESH<<8) + ADRESL   ' ADC RESULT  12 BIT
        'READ ANALOG 3 IB   ........................
        ADCON0=%00001100    ' SELECT AN0, IB
        ADCON0=%00001101    ' ON, ACCESO
        ADCON0=%00001111    ' ON + GO
        WEND
        IB_ADC=(ADRESH<<8)+ ADRESL   ' ADC RESULT  12 BIT
    ACQ_POT:    'ACQUIRE POT ANALOG VOLTAGE   ....................................
        'READ ANALOG 4 POT
        ADCON0=%00010000    ' SELECT AN0, VPOT
        ADCON0=%00010001    ' ON, ACCESO
        ADCON0=%00010011    ' ON + GO
        WEND
        POT_ADC=(ADRESH<<8)+ ADRESL   ' ADC RESULT  12 BIT
    DIS_LCD:     '.................... 15 msec ...................................
        IF STATE=0   THEN   LCDOUT INS, LINE1,"OFF  "
        IF STATE=1   THEN   LCDOUT INS, LINE1,"ON   "
        IF STATE=2   THEN   LCDOUT INS, LINE1,"FLOAT"
        iF STATE=3   THEN   LCDOUT INS, LINE1,"BULK "
        IF U_VOLT=1  THEN   LCDOUT LINE1,"LOAD> OFF > UV"
        IF LOAD=0    THEN   LCDOUT LINE1,"LOAD> OFF     "
        IF LOAD=1    THEN   LCDOUT LINE1,"LOAD> ON      "
        IF EXTPWR_OK=1 THEN LCDOUT INS,LINE2,"LINE> AVL    "
        IF EXTPWR_OK=0 THEN LCDOUT INS,LINE2,"LINE> NOT AVL"
        IF EX=1        THEN LCDOUT INS,LINE2+14,"EXT_PWR"
        IF EX=0        THEN LCDOUT INS,LINE2+14,"       "
               ".",DEC2 IP/10,"  ",DEC2 WP/1000,".",DEC1 WP/100," ", DEC DUTY
               ".",DEC2 IB/10, " ",IBSIGN,DEC2 WB/1000,".",DEC1 WB/100,"  "
    SERIAL_OUT:  ' .................. 25 msec.....................................
         DEBUG "VP ",DEC VP/1000,".",DEC1 VP/100,"  IP ",DEC IP/1000,_
               ".",DEC2 IP/10, " WP ", DEC WP/1000,".",DEC1 WP/100,_
               " DC ",  DEC DUTY, " VB ",DEC VB/1000,".",DEC1 VB/100,_
               " IB ",IBSIGN,DEC IB/1000,".",DEC2 IB/10, " WB ",IBSIGN,_
               DEC WB/1000,".",DEC1 WB/100," M ",DEC MODE," S ",DEC STATE,13,10
    MPPT:        '...............................................................
        ' PANEL DATA CHANGE
        IF WP>WP_OLD THEN         ' POWER INCREASES
           DP=1
             IF WP<WP_OLD THEN     ' POWER DECREASES
                DP=0
        if wp=WP_OLD THEN RETURN
        IF VP>VP_OLD THEN         ' VOLTAGE INCREASES
           DV=1
             IF VP<VP_OLD THEN     ' VOLTAGE DECREASES
                DV=0
        ' HILL CLIMBING.... FOR MPP SEARCH
        ' CLIMBING FROM LEFT
        IF DV=1 AND DP=1 THEN
           DUTY=DUTY-DUTY_S     ' DECREASE LOAD TO INCREASE P_VOLTAGE
        'DESCEND TO THE RIGHT
        IF DV=1 AND DP=0 THEN
           DUTY=DUTY+DUTY_S     ' INCREASE LOAD TO REDUCE P_VOLTAGE
        ' CLIMBING FROM RIGHT
        IF DV=0 AND DP=1  THEN
        ' DESCEND TO THE LEFT
        IF DV=0 AND DP=0 THEN
        GOSUB SET_PWM
        WP_OLD=WP
        VP_OLD=VP
    SET_PWM:  '...................................................................
        IF DUTY >= 254 THEN      ' MAX DUTY FOR IR2104
           DUTY=254
        if   DUTY <=150 THEN     ' CONSIDERING ABOUT 12 VDC OUTPUT..
             DUTY=150
        HPWM 1,DUTY,75000       ' 75 KHz CLOCK FREQUENCY @ DUTY....
    GET_PANEL_DATA:     ' ........................................................
    ' GET PANEL DATA
        FOR I=1 TO AVG              ' VP AND IP FILTERING LOOP
            GOSUB ACQ_PV            ' ACQ_PV TAKES ABOUT 2.3 mSEC...
            IPT=IPT+IP_ADC
            VPT=VPT+VP_ADC
        NEXT I
        IPF_ADC=IPT/AVG
        VPF_ADC=VPT/AVG
        IPT=0 : VPT=0
        VP=(VPF_ADC*7200)/1000      ' MILLIVOLTS
        IF IPF_ADC>2052 THEN        ' ACS_712 BIAS IS ABOUT 2.5 VDC... 12 BIT adc
           IPF_ADC=IPF_ADC-2052
             IF IPF_ADC =< 2052 THEN
                IPF_ADC=2052-IPF_ADC
        IP=(IPF_ADC*6790)/1000     '  MILLIAMPS
        WP=(IP*VP)/1000            '  MILLIWATT
    GET_BATTERY_DATA:    '........................................................
    ' GET BATTERY DATA
        FOR I=1 TO AVG_B
           GOSUB ACQ_BATT      ' ACQ_BATT TAKES ABOUT 2.3 mSEC
           VBT=VBT+VB_ADC
           IBT=IBT+IB_ADC
        NEXT I
        VBF_ADC=VBT/AVG_B
        IBF_ADC=IBT/AVG_B
        IBT=0 :VBT=0
        IF IBF_ADC>2053 THEN
          IBF_ADC=IBF_ADC-2053
          IBSIGN="-"
          IF IBF_ADC=<2053 THEN
             IBF_ADC=2053-IBF_ADC
             IBSIGN="+"
        VB=(VBF_ADC*7000)/1000          '  MILLIVOLTS
        IB=(IBF_ADC*6790)/1000          '  MILLIAMPS
        WB=(IB*VB)/1000                 '  MILLIWATT
    Last edited by Demon; - 1st May 2014 at 20:10. Reason: Added [CODE] tags to make code more clear - Robert
  1. DC/DC with MPPT for solar panels
    Last Post: - 14th May 2013, 03:26
  2. Replies: 14
    Last Post: - 6th March 2011, 06:08
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 20:15
  4. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 01:28
  5. 12v Lead acid solar charger
    Last Post: - 26th May 2006, 23:01
