MPPT solar battery charger
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
    Jun 2008
    Varese , Italy
    Default MPPT solar battery charger
    I have built up a solar battery charger to be used in my Radio Ham station. It is used to keep charge a 27 AH 12 V SLA battery.
    The panel power is 50 watt for now. I am NOT a programmer or a software guy and so I wrote the program for the pic18f4523 using a picbasic pro in a very preliminary mode.
    The Pic is running at 40 Mhz clock speed and controls the duty cycle of a buck converter at 75 khz frequency.
    The whole charger works well : there is a small problem relevant to the status selection that appears when the sky is cloudy (but not always): it jumps between status 0 and status 3.
    This is not really a problem but I would like to fix it and make it stable in all the sky condition.
    I told before that I am not an expert in programming so I would like if someone could help to improve the software that I wrote: I also think that there could be a lot of simplifications, corrections and others to be improved.
    I will try to attach the basic program here. I could post the schematics diagram too but it is hand drawn.
    Thanks in advance for any assistance .
    Beste regards,
    Ambrogio
    Jun 2008
    Varese , Italy
    Default Re: MPPT solar battery charger
    Demon,
    thanks for having respond to my msg.
    here is the code.
    I will re_draw the schematics ( by hand )in a decent way tonight. I will post it tomorrow.
    thnks
    Ambrogio
    '*  Name    :  pic 18f4523                                      *
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 28/04/2014                                        *
    '*  Notes   : modificare file 18f4523 nella cartella PBP        *
    '*          : per il config ... oscillatore MCLR etc            *
    '* picbasic pro 2.6  : long used.  12294 BYTES USED.            *
    '* 50 WATT SOLAR PANEL, 27 AH 12 VDC SLA BATTERY                *
    ' WARNING:
    ' HSPLL OSCILLATOR HAS BEEN DEFINED IN THE PBP FOLDER > 18F4523 FILE
    DEFINE OSC 40    ' 10 MHz XTAL  AND x4 PLL GIVES 40 MHz CLOCK SPEED.
    INCLUDE "MODEDEFS.BAS"
    'DEBUG DEFINITION> WITH_OUT MAX 232...USE INVERTED=1, 57600 BAUD 8N1
    ' Set Debug pin port   ________________________________________
    DEFINE DEBUG_REG PORTC
    ' Set Debug pin bit   _________________________________________
    DEFINE DEBUG_BIT 6
    ' Set Debug baud rate _________________________________________
    DEFINE DEBUG_BAUD 57600
    ' Set Debug mode: 0 = true, 1 = inverted ______________________
    DEFINE DEBUG_MODE 1
    ' LCD CONFIGURATION ...HD_4470 LIKE > 4 LINES BY 20 CHRS IS USED HERE
    ' Set LCD Data port   _________________________________________
    DEFINE LCD_DREG PORTD
    ' Set starting Data bit (0 or 4) if 4-bit bus ________
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port  (R/S)  ________________________
    DEFINE LCD_RSREG PORTD
    ' Set LCD Register Select bit   _______________________________
    DEFINE LCD_RSBIT 5
    ' Set LCD Enable port    (EN_DCDC)__________________________________
    DEFINE LCD_EREG PORTD
    ' Set LCD Enable bit       ____________________________________
    DEFINE LCD_EBIT 4
    ' Set LCD bus size (4 or 8 bits)  _____________________________
    'DEFINE LCD_BITS 4
    ' Set number of lines on LCD     ______________________________
    DEFINE LCD_LINES 4
    ' Set command delay time in us   ______________________________
    DEFINE LCD_COMMANDUS 2500
    ' Set data delay time in us   _________________________________
    DEFINE LCD_DATAUS 50
    PAUSE 500
    '  SOME CONSTANTS TO CONTROL THE LCD.
    INS   CON 254 '   $FE: INSTRUCTION COMMAND MODE
    CLR   CON 1   '   CLEAR LCD , GOTO FIRST LINE, FIRST CHARACTER
    DG    CON 223 '   SIMBOLO DEL GRADO °
    LINE1 CON 128 '   $80: GOTO LINE 1
    LINE2 CON 192 '   $C0: GOTO LINE 2
    LINE3 CON 148 '   $94: GOTO LINE 3
    LINE4 CON 212 '   $D4: GOTO LINE 4
    ' eg.: LCDOUT INS, LINE1, "PIBPO TXT=",........
    ' ADC CONFIGURATION
    ADCON1=%00001010   ' AN0,AN1,AN2,AN3,AN4 ENABLED.THE REMAINING PINS ARE DIGITAL
    VB_ADC VAR WORD    ' AN0 PIC_PIN 2     ' BATTERY VOLTAGE
    VP_ADC VAR WORD    ' AN1 PIC_PIN 3     ' PANEL VOLTAGE
    IP_ADC VAR WORD    ' AN2 PIC_PIN 4     ' PANEL CURRENT
    IB_ADC VAR WORD    ' AN3 PIC_PIN 5     ' BATTERY VOLTAGE
    POT_ADC VAR WORD   ' AN4 PIC_PIN 7     ' POT VOLTAGE FOR MANUAL DUTY INPUT...
    ' FILTERS          '........................................................
    IPT VAR WORD
    VPT VAR WORD
    VBT VAR WORD
    IBT VAR WORD
    AVG VAR BYTE
    AVG=8               ' MAX AVG=16  4096*16=65536  IN A WORD !    PANEL  data
    AVG_B VAR BYTE
    AVG_B=4             ' MAX AVG_B=16  4096*16=65536  IN A WORD !  BATTERY data
    I VAR BYTE
    Y VAR BIT
    Y=0
    Z VAR BYTE
    Z=0
    DLY_FLG VAR BIT
    DLY_FLG =1
    IPF_ADC VAR WORD
    VPF_ADC VAR WORD
    VBF_ADC VAR WORD
    IBF_ADC VAR WORD
    VP VAR LONG
    IP VAR LONG
    VB VAR LONG
    IB VAR LONG
    WP VAR LONG
    WB VAR LONG
    IBSIGN VAR BYTE    ' BATTERY CURRENT SIGN
    DUTY VAR WORD      ' PIC PWM DUTY CYCLE CONTROL
    DUTY=150           '  START  AT MINIMUM DUTY
    GOSUB SET_PWM
    DUTY_S VAR BYTE    ' DUTY CYCLE STEP for MPPT
    DUTY_S=1           ' MUST BE WIDE ENOUGH TO OVERCOME PANEL DATA NOISE !
                       ' IF MPP IS NOT FOUND USE 2, 3, 4 OR 5...
    LD_EN VAR PORTC.1  ' PIC_PIN 16   LOAD POWER MOSFET CONTROL PIN
    LOW LD_EN          ' DISABLE LOAD POWER MOSFET
    EN_DCDC VAR PORTC.3     ' PIC_pin 18   DC/DC CONVERTER ENABLE
    low EN_DCDC             ' DISABLE DC/DC CONVERTER
    LOAD VAR BIT
    LOAD=1
    MODE VAR BYTE
    MODE=0
    STATE VAR BYTE
    STATE=0
    ' STATE 0= OFF
    ' STATE 1= ON
    ' STATE 3= FLOAT
    ' STATE 4= BULK
    DV VAR BIT         ' PANEL DELTA VOLT USED FOR HILL CLIMBING
    DP VAR BIT         ' PANEL DELTA POWER
    VP_OLD VAR LONG    ' OLD PANEL VOLTAGE
    WP_OLD VAR LONG    ' OLD PANEL POWER
    ' SCAN FOR MPP ......................
    WPMAX VAR LONG
    WPMAX=0
    VPMAX VAR LONG
    VPMAX=0
    IPMAX VAR LONG
    IPMAX =0
    VBMAX VAR LONG
    IBMAX VAR LONG
    WBMAX VAR LONG
    DUTYMAX VAR BYTE
    DUTYMAX=0
    ' BACK LIGHTING    ......................................................
    BCK_LT VAR PORTA.4     ' PIC_PIN 6
    FOR I=3 TO 0 STEP -1   ' LCD BACK LIGHT TEST AT POWER ON
        HIGH BCK_LT
        pAUSE 100
        LOW BCK_LT
        PAUSE 100
    NEXT I
    HIGH BCK_LT            ' LEAVE BACK LIGHT ON AT THE END ...
    ' EXTERNAL POWER  ........................................................
    EXT_PWR_RLY VAR PORTC.0    ' PIC_PIN 15 OUTPUT CONTROL FOR EXT_PWR SOURCE RELAY
    HIGH EXT_PWR_RLY           ' DISABLE EXT PWR_RELAY   HIGH= DISABLE
    EXTPWR_OK VAR PORTC.4      ' PIC_PIN 23  INPUT > POWER_LINE STATUS; 1=OK
    U_VOLT VAR BIT             ' EXT POWER MONITOR
    U_VOLT=0                   ' EXT POWER GOOD
    U_FLG VAR BIT      ' BATTERY UNDERVOLTAGE FLAG
    U_FLG=1
    EX VAR BIT
    EX=0
    ' SPLASH SCREEN:
    Lcdout INS,line1, "Ambrogio 06/04/2014 "    ' LCD CHECK
    Lcdout INS,line2, "PV PIC18F4523       "
    debug 13,10,13,10
    DEBUG " STARTING H E R E ! ! ! ! "          ' SERIAL LINK CHECK
    PAUSE 1000
    LCDOUT INS,CLR                              ' TURN LCD OUT
    ' PUSH BUTTONS PIN ASSIGNEMENT
    PB_1 VAR PORTE.0       'PIC_PIN 8  STEPS THROUGH THE MODES
    PB_2 VAR PORTE.1       'PIC_PIN 9
    PB_3 VAR PORTE.2       'PIC_PIN 10  TOGGLE LOAD MOSFET
    MAIN:  ' ************************************************************
    ' PB_1 SELECTS THE MODES ...
    ' mode =0 is THE normal OPERATING MODE
    ' mode =1 pot input controls the duty cycle
    ' mode =2 scan duty cycle to search for the MPP CONDITION
    ' mode =3 TOGGLES the duty cycle to see the system response caracteristics
    ' MODES SELECTION....................
    IF PB_1=0 THEN          ' MODE SELECTION...
       MODE=MODE+1
       IF MODE >=4 THEN
          MODE=0
       IF MODE=1 THEN
          LCDOUT INS, CLR
          HIGH EN_DCDC
       IF MODE=2 THEN
          LCDOUT INS, CLR
          WPMAX=0         ' reset maximum registers
          VPMAX=0
          IPMAX=0
          VBMAX=0
          IPMAX=0
          WBMAX=0
          DUTYMAX=0
          HIGH EN_DCDC
          DUTY=150          ' THIS IS MY MINIMUM DUTY CYCLE
          GOSUB SET_PWM
          PAUSE 1000
       IF MODE=3 THEN
          LCDOUT INS, CLR
          LCDOUT INS, LINE1, " DC STEP TEST "
    WHILE PB_1=0: WEND
    ' LOW VOLTAGE PROTECTION ...and load control..................................
    IF ( VB<11800 ) THEN       ' BATT LOWER THAN 11.8 Vdc
       U_VOLT=1                ' SET UNDER_VOLTAGE FLAG
       LOAD=0
       U_FLG=1
        IF ( VB>12600 ) THEN   ' IF VBATT MORE THAN 12.6 Vdc
           U_VOLT=0            ' RESET UNDER_VOLTAGE FLAG
           IF U_FLG=1 THEN
              HIGH LD_EN       ' ENABLE LOAD
              LOAD=1
              U_FLG=0
    IF (U_VOLT=1) AND (EXTPWR_OK=1) THEN
       LOW EXT_PWR_RLY             ' ACTIVATE EXT POWER RELAY
       EX=1
        IF U_VOLT=0 THEN
           HIGH EXT_PWR_RLY        ' RELASE EXT POWER RELAY
           EX=0
    IF U_VOLT=0 THEN
        IF PB_3=0 THEN
           if LOAD=0 THEN
              LOAD=1
              LOAD=0
           IF LOAD=0 THEN
              LOW LD_EN
           IF LOAD=1 THEN
              HIGH LD_EN
        WHILE PB_3=0 : WEND
    ' MODES MANAGEMENT BY PUSH BUTTONS ...........................................
    IF MODE=0 THEN         ' NORMAL MODE  ........................................
       GOTO NORMAL_MODE
    IF MODE=1 THEN         ' POT CONTROLLED DUTY CYCLE............................
         LCDOUT INS, LINE1,"POT CONTROLLED DUTY:"
         GOSUB ACQ_POT     ' ACQ TAKES ABOUT 2.3 mSEC
         DUTY=((POT_ADC/39)+149)   ' POT CONTROLS DUTY 0>4096 = 150 to 254
         GOSUB SET_PWM
         GOSUB GET_PANEL_DATA
         GOSUB GET_BATTERY_DATA
         LCDOUT INS, LINE3,DEC VP/1000,".",DEC1 VP/100,"  ",DEC IP/1000,_
               ".",DEC2 IP/10,"  ",DEC WP/1000,".",DEC1 WP/100," ", DEC DUTY,"  "
         LCDOUT INS, LINE4,DEC VB/1000,".",DEC1 VB/100," ",IBSIGN,DEC IB/1000,_
               ".",DEC2 IB/10, " ",IBSIGN,DEC WB/1000,".",DEC1 WB/100,"  "
         GOSUB SERIAL_OUT
         GOTO MAIN
    IF MODE=2 THEN         ' SCAN DUTY CYCLE FOR MPP SEARCHING.................
       DUTY=DUTY+1         ' INCREMENT DUTY CYCLE
       GOSUB SET_PWM
       PAUSE 10            ' NOT REALLY NEEDED .. LCDOUT PROVIDES TIME DLY
       IF WP> WPMAX THEN   ' STORE MAX READINGS
          WPMAX=WP
          VPMAX=VP
          IPMAX=IP
          VBMAX=VB
          IBMAX=IB
          WBMAX=WB
          DUTYMAX=DUTY
       IF DUTY >= 254 THEN
          LCDOUT INS, CLR
          LCDOUT INS, LINE1, " MAX POWER :        "
          LCDOUT INS, LINE3,DEC VPMAX/1000,".",DEC1 VPMAX/100,"  ",_
                 DEC IPMAX/1000,".",DEC2 IPMAX/10,"  ",DEC WPMAX/1000,_
                 ".",DEC1 WPMAX/100," ", DEC DUTYMAX
          LCDOUT INS,LINE4,DEC VBMAX/1000,".",DEC1 VBMAX/100,"  ",_
                 DEC IBMAX/1000,".",DEC2 IBMAX/10,"  ",DEC WBMAX/1000,_
                 ".",DEC1 WBMAX/100
          DUTY=150
          GOSUB SET_PWM
          while PB_2=1 :wend       ' WAIT FOR PB_2 TO BE PRESSED
       lcdout ins, line1, "MAX PWR SEARCHING:"
       GOSUB SERIAL_OUT
       GOTO MAIN
    IF MODE=3 THEN    'DUTY STEP CHANGE RESPONSE TEST > SET TWO DUTY VALUES
                      'SET PAUSE FOR STEP TIME_WIDTH ,,,,,,,,,,,,,,,,,,,,,,,,,
                      ' system response time to duty change is about 15 msec
                      ' measured with a scope
       STEP_DUTY:
       IF Y=0 THEN
          HIGH BCK_LT      ' CONNECT TO SCOPE TRIGGER INPUT
          DUTY=170         ' FIRST DUTY VALUE
          GOSUB SET_PWM
          Y=1
          PAUSE 50         ' WIDTH
          GOSUB SERIAL_OUT
       IF Y=1 THEN
           low bck_lt
           DUTY=175       ' SECOND DUTY VALUE  > DUTY_step is 5 now
           GOSUB SET_PWM
           Y=0
           PAUSE 50       ' step time WIDTH  IS 50 MSEC
           GOSUB SERIAL_OUT
           GOTO MAIN
    NORMAL_MODE:    '*************************************************************
    ' BATTERY STATE CONTROL ......................................................
    GOSUB GET_PANEL_DATA         ' 2.3 msec x avg
    GOSUB GET_BATTERY_DATA       ' 2.3 msec x avg_b
    SELECT CASE STATE       ' MODIFIED TIM NOLAND PROGRAM IN c LANGUAGE... ( ! )
         CASE 0    ' OFF  ***  * * * * * * * * * * * * * * * * * * * * * * * * * *
             Z=Z+1
             IF Z>=254 THEN  ' wait sometime for the battery to settle down
                DLY_FLG=0
             DUTY=150       ' MINIMUM DUTY CYCLE.
             low EN_DCDC         ' DISABLE DC / DC CONVERTER
             GOSUB SET_PWM
             debug dec z,13,10
             IF DLY_FLG=0 THEN
                 IF VP > VB+1500 THEN      ' day light is coming ...
                    IF VB < 13800 THEN
                        DUTY=150
                        HIGH EN_DCDC
                        GOSUB SET_PWM
                        PAUSE 1000
                        STATE=1 ' >> ON
         CASE 1    ' ON  ***  * * * * * * * * * * * * * * * * * * * * * * * * * *
             HIGH EN_DCDC
             IF (VP < VB) and ( IP<80 ) THEN     ' it is dark
                DLY_FLG=1  : Z=0
                DUTY=150
                GOSUB SET_PWM
                STATE= 0  ' >> OFF
             IF VB > 14800 THEN        ' MAX BATTERY VOLTAGE IS 14.8 VDC
                STATE=2   ' >> FLOAT
                DUTY=150
                GOSUB SET_PWM
             IF ( WP < 5000 ) THEN
                DUTY=254
                GOSUB SET_PWM
             IF WP> 5000 THEN
                DUTY=240
                GOSUB SET_PWM
                STATE=3   ' >> BULK
         CASE 2   ' FLOAT  *** * * * * * * * * * * * * * * * * * * * * * * * * *
             HIGH EN_DCDC
             IF VB > 14200 THEN      ' KEEP FLOAT VOLTAGE @ 13.8 TO 14.2 VDC
                DUTY=DUTY-1          ' DECREASE DUTY
                GOSUB SET_PWM
             IF VB < 13800 THEN
                DUTY=DUTY+1          ' INCREASE DUTY
                GOSUB SET_PWM
             IF DUTY >= 254 THEN
                 DUTY=200
                 GOSUB SET_PWM
                 STATE=3  ' >> BULK
                DLY_FLG=1 : Z=0
                DUTY=150
                GOSUB SET_PWM
                STATE=0 '  >> OFF
         CASE 3   ' BULK
             HIGH EN_DCDC
             IF (WP < 5000)  THEN
                STATE= 1  ' >> ON
             IF WP >= 5000 THEN
                GOSUB MPPT
                 DLY_FLG=1  : Z=0
                 DUTY=150
                 GOSUB SET_PWM
                 STATE=0  ' >> OFF
             IF VB > 14800 THEN
                DUTY=150
                GOSUB SET_PWM
                STATE=2  ' >> FLOAT
    END SELECT
    ' DATA OUTPUT TO LCD, SERIAL AND RADIO.......................................
    GOSUB DIS_LCD         ' execution time is 15 msec
    GOSUB SERIAL_OUT      ' execution time is 25 msec
    GOTO MAIN             ' main loop execution time is 65 msec if avg=8 and
                          ' avg_b=4
    '========================  SUBROUTINES  =====================================
    ACQ_PV:    'ACQUIRE PV ANALOG DATA      ... 2.3 msec ........................
        ' READ ANALOG 0 VP   .........................
        ADCON0=%00000000    ' SELECT AN0, VP
        ADCON2=%10100110    ' ACQ TIME AND FOSC SELECTION
        ADCON0=%00000001    ' ON, ACCESO
        PAUSE 1             ' INPUT RESISTANCE AND CAP FOR DC ACQISISTION
        ADCON0=%00000011    ' ON + GO
        WHILE ADCON0.1=1    ' WAIT FOR CONVERSION COMPLETED , DONE
        WEND
        VP_ADC=(ADRESH<<8) + ADRESL   ' ADC RESULT  12 BIT
        ADCON0=%00000000    ' TURN OFF,
        'READ ANALOG 2 IP    ........................
        ADCON0=%00001000    ' SELECT AN0, IP
        ADCON0=%00001001    ' ON, ACCESO
        ADCON0=%00001011    ' ON + GO
        WEND
        IP_ADC=(ADRESH<<8)+ ADRESL   ' ADC RESULT  12 BIT
    ACQ_BATT:    ' ACQUIRE BATTERY ANALOG DATA   ........ 2.3 msec ................
        ' READ ANALOG 1 VB  ..........................
        ADCON0=%00000100    ' SELECT AN0, VB
        ADCON0=%00000101    ' ON, ACCESO
        ADCON0=%00000111    ' ON + GO
        WEND
        VB_ADC=(ADRESH<<8) + ADRESL   ' ADC RESULT  12 BIT
        'READ ANALOG 3 IB   ........................
        ADCON0=%00001100    ' SELECT AN0, IB
        ADCON0=%00001101    ' ON, ACCESO
        ADCON0=%00001111    ' ON + GO
        WEND
        IB_ADC=(ADRESH<<8)+ ADRESL   ' ADC RESULT  12 BIT
    ACQ_POT:    'ACQUIRE POT ANALOG VOLTAGE   ....................................
        'READ ANALOG 4 POT
        ADCON0=%00010000    ' SELECT AN0, VPOT
        ADCON0=%00010001    ' ON, ACCESO
        ADCON0=%00010011    ' ON + GO
        WEND
        POT_ADC=(ADRESH<<8)+ ADRESL   ' ADC RESULT  12 BIT
    DIS_LCD:     '.................... 15 msec ...................................
        IF STATE=0   THEN   LCDOUT INS, LINE1,"OFF  "
        IF STATE=1   THEN   LCDOUT INS, LINE1,"ON   "
        IF STATE=2   THEN   LCDOUT INS, LINE1,"FLOAT"
        iF STATE=3   THEN   LCDOUT INS, LINE1,"BULK "
        IF U_VOLT=1  THEN   LCDOUT LINE1,"LOAD> OFF > UV"
        IF LOAD=0    THEN   LCDOUT LINE1,"LOAD> OFF     "
        IF LOAD=1    THEN   LCDOUT LINE1,"LOAD> ON      "
        IF EXTPWR_OK=1 THEN LCDOUT INS,LINE2,"LINE> AVL    "
        IF EXTPWR_OK=0 THEN LCDOUT INS,LINE2,"LINE> NOT AVL"
        IF EX=1        THEN LCDOUT INS,LINE2+14,"EXT_PWR"
        IF EX=0        THEN LCDOUT INS,LINE2+14,"       "
               ".",DEC2 IP/10,"  ",DEC2 WP/1000,".",DEC1 WP/100," ", DEC DUTY
               ".",DEC2 IB/10, " ",IBSIGN,DEC2 WB/1000,".",DEC1 WB/100,"  "
    SERIAL_OUT:  ' .................. 25 msec.....................................
         DEBUG "VP ",DEC VP/1000,".",DEC1 VP/100,"  IP ",DEC IP/1000,_
               ".",DEC2 IP/10, " WP ", DEC WP/1000,".",DEC1 WP/100,_
               " DC ",  DEC DUTY, " VB ",DEC VB/1000,".",DEC1 VB/100,_
               " IB ",IBSIGN,DEC IB/1000,".",DEC2 IB/10, " WB ",IBSIGN,_
               DEC WB/1000,".",DEC1 WB/100," M ",DEC MODE," S ",DEC STATE,13,10
    MPPT:        '...............................................................
        ' PANEL DATA CHANGE
        IF WP>WP_OLD THEN         ' POWER INCREASES
           DP=1
             IF WP<WP_OLD THEN     ' POWER DECREASES
                DP=0
        if wp=WP_OLD THEN RETURN
        IF VP>VP_OLD THEN         ' VOLTAGE INCREASES
           DV=1
             IF VP<VP_OLD THEN     ' VOLTAGE DECREASES
                DV=0
        ' HILL CLIMBING.... FOR MPP SEARCH
        ' CLIMBING FROM LEFT
        IF DV=1 AND DP=1 THEN
           DUTY=DUTY-DUTY_S     ' DECREASE LOAD TO INCREASE P_VOLTAGE
        'DESCEND TO THE RIGHT
        IF DV=1 AND DP=0 THEN
           DUTY=DUTY+DUTY_S     ' INCREASE LOAD TO REDUCE P_VOLTAGE
        ' CLIMBING FROM RIGHT
        IF DV=0 AND DP=1  THEN
        ' DESCEND TO THE LEFT
        IF DV=0 AND DP=0 THEN
        GOSUB SET_PWM
        WP_OLD=WP
        VP_OLD=VP
    SET_PWM:  '...................................................................
        IF DUTY >= 254 THEN      ' MAX DUTY FOR IR2104
           DUTY=254
        if   DUTY <=150 THEN     ' CONSIDERING ABOUT 12 VDC OUTPUT..
             DUTY=150
        HPWM 1,DUTY,75000       ' 75 KHz CLOCK FREQUENCY @ DUTY....
    GET_PANEL_DATA:     ' ........................................................
    ' GET PANEL DATA
        FOR I=1 TO AVG              ' VP AND IP FILTERING LOOP
            GOSUB ACQ_PV            ' ACQ_PV TAKES ABOUT 2.3 mSEC...
            IPT=IPT+IP_ADC
            VPT=VPT+VP_ADC
        NEXT I
        IPF_ADC=IPT/AVG
        VPF_ADC=VPT/AVG
        IPT=0 : VPT=0
        VP=(VPF_ADC*7200)/1000      ' MILLIVOLTS
        IF IPF_ADC>2052 THEN        ' ACS_712 BIAS IS ABOUT 2.5 VDC... 12 BIT adc
           IPF_ADC=IPF_ADC-2052
             IF IPF_ADC =< 2052 THEN
                IPF_ADC=2052-IPF_ADC
        IP=(IPF_ADC*6790)/1000     '  MILLIAMPS
        WP=(IP*VP)/1000            '  MILLIWATT
    GET_BATTERY_DATA:    '........................................................
    ' GET BATTERY DATA
        FOR I=1 TO AVG_B
           GOSUB ACQ_BATT      ' ACQ_BATT TAKES ABOUT 2.3 mSEC
           VBT=VBT+VB_ADC
           IBT=IBT+IB_ADC
        NEXT I
        VBF_ADC=VBT/AVG_B
        IBF_ADC=IBT/AVG_B
        IBT=0 :VBT=0
        IF IBF_ADC>2053 THEN
          IBF_ADC=IBF_ADC-2053
          IBSIGN="-"
          IF IBF_ADC=<2053 THEN
             IBF_ADC=2053-IBF_ADC
             IBSIGN="+"
        VB=(VBF_ADC*7000)/1000          '  MILLIVOLTS
        IB=(IBF_ADC*6790)/1000          '  MILLIAMPS
        WB=(IB*VB)/1000                 '  MILLIWATT
    Last edited by Demon; - 1st May 2014 at 20:10. Reason: Added [CODE] tags to make code more clear - Robert
    Quote Originally Posted by iw2fvo View Post
    ... there is a small problem relevant to the status selection that appears when the sky is cloudy (but not always): it jumps between status 0 and status 3...
    Are you sure it isn't a debounce issue?
    Maybe add 1 second PAUSE to rule that out?
    Jun 2008
    Varese , Italy
    Thanks Robert,
    I will put a delay ( 1 sec or more ) when changing status.
    Need to wait for next cloudy days to check if OK .
    Do you see any other area om the program that could be improved ?
    Ambrogio
    Honestly I have trouble concentrating so it's kinda easy for me to lose track of logic.
    I try to help with the simple things.
    Edit: your program is huge, have you considered breaking it down?
    I'd make a copy, reduce all the subroutines to only display a status on LCD, then add logic one section at a time.
    Jun 2008
    Varese , Italy
    Robert,
    I am attaching the schematics digram for the charger and two captures.
    I am sorry : it is hand drawn. I am not an electronics expert nor a software man !
    This morning I have activated the delay as suggested, I am waiting to see the results in the next days.
    The whole device works well and the MPPT is tracked well too.
    Thanks for all.
    regards,
    Ambrogio
    Wow!
    Wish I could contribute something.
    Now you're making me think of adding a solar panel to my alarm project.
    Jun 2008
    Varese , Italy
    Robert,
    i woluld like to attach a photo of the LCD and a screen shot of the output.
    I am not able to attach any .jpeg : any direction for me ?
    Ambrogio
    Test attachment using picture icon on posting toolbar:
    Last edited by Demon; - 1st May 2014 at 20:01. Reason: removed pic, no longer necessary
    Jun 2008
    Varese , Italy
    Robert,
    they are here.
    Ambrogio
    Thanks Robert,
    I'd put it here temporarily:
       IF MODE=3 THEN
          LCDOUT INS, CLR
       PAUSE 1000     ' Test if problem is debounce issue
       ' Not necessary during test ... WHILE PB_1=0: WEND
    Oh great, I misread. I thought it was jumping between MODEs. Aaargh, sorry.
    Gonna look through logic later. I have errands to do during the day.
    Jun 2008
    Varese , Italy
    Robert,
    i think it ias a problem related to panel power wp, panel voltage vp and duty cycle when switching among the various status...
    It needs to find out the proper values that controls the switching...
    tnks,
    Ambrogio
    Robert,
    tnks,
    Ambrogio
    Yup. I can't see bad GOSUB structure, nothing that stands out anyways.
    The STATE can evolve from 0 to 3 in a single pass of that SELECT CASE. I can only assume the readings from your hardware makes it jump unexpectedly.
    Are you able to debug in real time and step thru your code?
    It's about the only way I can think of the visualize what is going on. I see you dump a lot of information but I'm unable to follow that manually through your logic.
    I prefer to dump like this:
    MAIN --------------------------------------------------
    STEP 1, list of variables.
    SUBROUTINE XYZ ----------------------------------------
    STEP 2, list of variables.
    SUBROUTINE ABC ----------------------------------------
    ...etc...
    I find it easier to follow in the code this way. I place the STEPS in relevant places, like before & after IFs, etc.
    Jun 2008
    Varese , Italy
    Robert ,
    I agree with you.
    The point is the data input to the state machine.
    In particular sun condition it plays back and forth between the two status because of the data input.
    I have to change / find out some different duty / panel power / panel voltage to be used to control the staus and avoid oscillations.
    It does not happen frequently: just in some particular case and in a cloudy day.
    The delay applied to the program as stated reduce the oscillation frequency.
    Anyway it is not a real problem since it happens when the charging current is already low because of the low sun condition.
    Thanks for all.
    regards,
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    A very impressive piece of code! I have been programing for over 40 years and never seen a novice produce such elegant code before.
    The issue is in your select case section. If case =0 then within this code case is set to 1 then case 1 code is run and again Case is set to 2 then Case is set to 3. Here is the main issue Case 3 is bulk charging because the battery is low as you would want but if a cloud comes over then Panel Voltage is less than Battery Voltage and Case is set to 0. Once the cloud goes then the Case will again revert to 3 bulk charge until the next cloud. Obviously depending on how dark the cloud is there is a possibility that the Panel Voltage can be above Battery Voltage changing to below Battery Voltage and then above as the cloud passes.
    This explains what is happening. My only question is why are you switching the Panel on and off?
    All my solar panels are permanently connected to the battery regulator. The panels do have a diode in line.
    If you do not switch the panels on and off you can take out all of the switching code and solve the problem.
    Dec 2011
    Sofia, BG
    Hi iw,
    I'm impressed of your work.
    I played once with mppt converters and i know how crazy is.
    the attachments show dc simulation of 21V@8A photovoltaic. May be will be useful for you. I have dozens simulations of buck, boost and sepic converters, but i didn't finish the work because the 'client' give up. Now i have 3kg prototype but no panel to play
    Allow me to ask you what mppt algorithm you use ?
    Some of them are:
    * perturb and observe (P&O - sign dP)
    * incremental conductance (dP/dV=0)
    * constant voltage or current (CV,CI)
    May be i'm too lazy to read all your code and find out, sorry.
    I suggest reading of this:
    Comparative Study of
    Maximum Power Point
    Tracking Algorithms
    D. P. Hohm and M. E. Ropp*,y
    Electrical Engineering Department, South Dakota State University, Brookings, SD 5700-2220, USA
    It helps me a lot, amazing study.
    Jun 2008
    Varese , Italy
    Thanks EarlyBird2,
    Yes , the system works as you described.
    The point is that sometime it jumps or oscillates around OFF state. I think your suggestion to do not turn off the converter ( see EN_DCDC ) could solve the problem.
    I will try it durnig next week. I will post the results.
    Thanks again
    Ambrogio
    Jun 2008
    Varese , Italy
    Thanks TheFob,
    I think that the trick to get a stable MPP tracking is that the "Perturbation" must generate a delta power that is greater than the " noise Power ".
    If the VP and IP acquisistion by the PIC ADC has some noise, then the power has a noise too. The perturbation created by " DUTY_step" must generate a delta power response bigger than the noise power.
    If the hardware is good then and the noise low we could use a duty_step=1 . If you have a sensible noise you could increase it to 2, 3 , 4 ...
    The piece of program is this:
    MPPT: '................................................. ..............
    ' PANEL DATA CHANGE
    DP=1
    DP=0
    DV=1
    DV=0
    GOSUB SET_PWM
    WP_OLD=WP
    VP_OLD=VP
    Thanks for the interest,
    Ambrogio
    IW2FVO
    North Italy
    Dec 2011
    Sofia, BG
    Thanks iw,
    I suppose the first chart explains your code. I found it in the net. But i'm still out of focus.
    Why is the measurement of dV? As is shown on the simulation, the voltage of the panel
    is almost constant up to 90% of available current. So there is "constant voltage" and "constant current" methods. The voltage remain the same even at night, of course with almost no load. The photons flow become electrons flow, i.e. available current. So the panel is kind of current generator.
    And of course, measured dV will be small and inaccurate, may be the noise is from there.
    I used hardware circuit similar as algorithm in second chart. So i'm interested of your work. I will try to find my circuits, but unfortunately they are on almost dead HDD ...
    Dec 2011
    Sofia, BG
    ok, i answered myself. I did simulation again.
    The voltage have little change indeed and can be used to determine the direction of duty. But this can be done without this too.
    Iw, if i find some time i will make Proteus simulation with your code.
    Will be nice to check some other algorithms before the fire of soldering iron
Size:  32.1 KBName:  pv02spv.PNG
    PS I don't know how to resize the images, sorry
    Jun 2008
    Varese , Italy
    Thanks theFob,
    I am interested in seeing the simulation of my program when you have time .
    The mpp_tracking code I am using works well . My program allow to find out the MPP manually using the potentiometer. It also allows to scan the duty cycle to search the MPP : this is automatic.
    The normal mode of the program continuously tracks the MPP. There is a very minor difference among them.
    Thanks again,
    regards,
    Ambrogio
    IW2FVO
    North Italy
    Dec 2011
    Sofia, BG
    Hi iw,
    I'll be glad to do this Had no such fun from long time.
    I need the nominal voltage and maximum current values of the panel or just the model.
    I noticed the lack of general decoupling diode in your circuit. Is needed for reverse current protection. May be the panel have such internally.
    Also a small input filter will be good idea, because the input current of the buck is trapezoidal and is very stressful for the panel.
    So the preferred converters are boost (when is possible) or sepic. The input currents there are triangle in continuous mode.
    I allowed myself to check your CQ on the net. How far you've come with SG3525 inverter ? I guess it will work with this converter .... ?
    Jun 2008
    Varese , Italy
    TheFob:
    panel data are:
    max power 50 w
    open circuit volt: 21.6 Vdc
    short circuit current : 3.04 A
    Max pp volt: 17.6 Vdc
    Max pp current : 2.84 A
    There is a reverse protection diode ( see D1 on buck converter schematics ).
    There is 220 uF at the buck input . Could it be too small ?
    The panel keeps the SLA battery charged and so I do not have any inverter to produce line alternate power. I just need 12 VDC nominal.
    CQ: >> I have a fully working homemade SDR rx tx for the HF. I have to re_install the antenna that went out completely during the last windy thunderstorm.
    I plan to do that at the beginning of the next month.
    Thanks.
    73, IW2FVO.
    Ambrogio
    Dec 2011
    Sofia, BG
    No, you have no panel protection diode. there must be a diode right after the panel, before the point C. It is essential.
    If the sun goes down and you have no load at the moment, the input capacitor will return current which can destroy the junctions in the panel.
    Diode D1 protect only the buck from the battery. Also the input capacitor is good to be bigger. At least 2200uF in my opinion.
    Plus ~1uH inductance after the diode - will help a lot against noise. Few turns on the fly.
    SDR sounds interesting, it is something new for me.
    Jun 2008
    Varese , Italy
    Thanks.
    I have learn now the need for a panel diode. I will move D1 to the panel input. I will also install a 2200 uF low ESR at panel input and after the diode.
    The RF choke is a good idea too.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Thanks Ambrogio for this very interesting and informative thread.
    When I first read this thread I wondered why make your own Solar Regulator when I buy them for 20€ but obviously now I realise the models I use are not MPPT. The MPPT version costs 250€ so making your own is not only an interesting project but saves lots of cash.
    I also realise that your design allows for Solar or Mains power which makes it even more interesting but I could not work out how the program/micro does the switching between the two power sources.
    Jun 2008
    Varese , Italy
    Steve,
    the program controls both the load disconnection and the external power .
    You can set the voltages at your choice.
    Here is the piece of code. The whole code is not optimized : I am not a software expert as I told at the beginning. There are a lot of comments on the program.
    I think that a software guy could improve the code in a significant way. BTW it is still working at my home.
    regards,
    Ambrogio
    iw2fvo
    LOAD=0
    U_FLG=1
    IF U_FLG=1 THEN
    LOAD=1
    U_FLG=0
    EX=1
    IF U_VOLT=0 THEN
    EX=0
    IF U_VOLT=0 THEN
    IF PB_3=0 THEN
    if LOAD=0 THEN
    LOAD=1
    LOAD=0
    IF LOAD=0 THEN
    LOW LD_EN
    IF LOAD=1 THEN
    HIGH LD_EN
    WHILE PB_3=0 : WEND
    Jun 2009
    Sc*nthorpe, UK
    My rules for programming in order of importance.
    1 It works
    2 It is easy to follow
    3 It is easy to modify
    My definition of a good program is
    It works
    Which yours does except for one minor detail. So the question is whether to rewrite the program or not to solve this cloud issue? Personally I would rewrite the program because I would learn by doing so. I only wish I had the hardware.
    Jun 2008
    Varese , Italy
    As far as the cloud issue I wikll modify the program to improve stability.
    I will do the modification to the code tomorrow and I will then test it for some days expecially when cloudy.
    If ok I will post the mod later on. The mod will involve the ON STATE code only.
    Ambrogio
    IW2FVO
    North Italy
    Jun 2008
    Varese , Italy
    I am posting the picbasic program B_4523 mainly modified to avoid oscillation among the ON state in particulary cloud sky condition.
    I did minor changes as reported in the .txt program headlines.
    Thanks to all of you for the suggestions provided.
    Ambrogio
    IW2FVO
    North Italy
    Jun 2008
    Varese , Italy
    Good day,
    I connected my charger to the PV and I left it for about 10 days having good results in all the sun conditions available in that period of time.
    The final code together with the photo of the prototype implementation is attached to the present mail .
    Ambrogio
    IW2FVO
    North Italy
    Congratulations!
    Jun 2008
    Varese , Italy
    Hi to all of you in the forum.
    My MPPT charger is working since last June with no problem.
    In this period I have no possibility to go on with my electronics hobbies.
    I would like to know if someone has reproduced this project and has introduce some improvements.
    Just to know !
    Ambrogio
    Sep 2005
    France
    HI IW2FVO,
    I plan to use your schematics and parts of your code for my project (just ordered 2x100w PV, now need battery)
    I would like to know what do you mean (schematics) replace D1 with ideal diode ?
    It could take some times to make my project because of the season.
    Congratulation for your work
    Regards - 73'
    F1SLU
    Herve
    Jun 2008
    Varese , Italy
    Hi Herve,
    D1 introduce a voltage drop that impact on the whole system efficiency. This loss can be calculated an depends on current and diode performance in terms od forward voltage drop.
    I used an ideal diode circuit to replace D1 during my last test at the bench only. I have not introduce it on my final circuit because of the space on the board.
    You could find out a lot of these circuits here :
    https://www.google.it/search?q=ideal...L&ved=0CCAQsAQ
    You can also google " ideal diode solar " for additional info.
    I do suggest to calculate the power saved and evaluate if really worth. It is up to you !
    I will really start without it.
    Best regards,
    iw2fvo, Ambrogio
    Sep 2005
    France
    Hi Ambrogio,
    I just finished to install my solar panels 2 weeks ago. (Yes... I'm a turtle...)
    As I doesn't make any charger I bought a cheap MPPT solar charger from Ebay (china) and it's a fake MPPT (just PWM).
    So I've made the PCB for my real MPPT solar charger. Using most same parts as your schematics (just using other equivalent parts and not ACS712 but a maxim current sensor)
    I have to modify your source program. :-)
    I just would like to ask you, if you're happy with your charger/program, or did you make any changes ?
    I have 220W solar panels.
    I will give some news about the MPPT charger asap, I just received 5 PCB from... china today.... Have to solder now.
    regards and 73
    F1SLU Hervé
    Best regards
    Jun 2008
    Varese , Italy
    HI Herve,
    It is still working well and no additional modification was introduced to the program.
    I introduced an IDEAL DIODE found on the Ebay in place of the diode: it is OK.
    I think the state machine portion of the program could be improved sometime...
    My system has no PCB: do you have a spare one for me ?
    All the best,
    73, Ambrogio
    Sep 2005
    France
    Hi Ambrogio,
    My schematic is a bit different, so my PCB too ! As I have 220W panels some choice have to be done, and I also want to use serial to log on my computer. I think to make a python script to do that. I will upload picture of the schematics and PCB here but next week because I have it at work.
    OK for the ideal diode. May be I will buy some of them ...
    73, Hervé
    Jun 2008
    Varese , Italy
    I will like to see it .
    73, Ambrogio
  1. DC/DC with MPPT for solar panels
    Last Post: - 14th May 2013, 03:26
  2. Replies: 14
    Last Post: - 6th March 2011, 06:08
  3. Charger battery with pic12f675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 20:15
  4. Li-Ion battery charger
    By Nicmus in forum Off Topic
    Last Post: - 21st May 2008, 01:28
  5. 12v Lead acid solar charger
    Last Post: - 26th May 2006, 23:01
