LED ON and OFF with 2 Push button switches
Results 1 to 16 of 16
    Sep 2015
    Default Re: LED ON and OFF with 2 Push button switches
    Hi fratello,
    Thanks for the link.
    mike
    Aug 2003
    It’s a flip-flop, so if you do it in software a flip-flop might as well be 1 bit of memory.
    You’re going to want to look a the LED in a real program and know if it’s on or off,
    so will usually want to store the LED state which would usually represent some program state.
    flipflop var bit ‘ 1 = LED is on 0 = LED is off
    debounce var byte ‘ button debounce counter
    flipflop = 0 ‘ start with LED off at power up, or on if you want to
    debounce = 0 ‘ reset debounce counter
    trisb.0 = 1’ button pin input
    trisb.7 = 0’ LED pin output
    cycle: 'program cycle
    if debounce > 199 then
    if portb.0 = 1 then
    flipflop = 1
    debounce = 0
    flipflop = 0
    debounce = 0
    if flipflop = 1 then ‘ set LED to flip flop state
    portb.7 = 1
    portb.7 = 0
    if debounce < 200 then ‘ increment button debounce counter
    debounce = debounce + 1
    goto cycle ‘ repeat loop forever
    But that's only using 1 button Art not 2 as in the title of the thread.....
    EN82fn
    Aug 2003
    Whoops!
    No need to accommodate contact bounce for the buttons then.
    trisb.0 = 1’ buttonA pin input ON
    trisb.1 = 1’ buttonB pin input OFF
    if portb.0 = 1 then
    flipflop = 1 ‘ set memory bit
    if portb.1 = 1 then
    flipflop = 0 ‘ reset memory bit
    portb.7 = flipflop ‘ set LED on or off
    Now, Thats nice and easy. The only thing I would change is not having a variable for the state of the output pin but reading the output state.
    EN82fn
    Aug 2003
    In the long run, for midrange pics that don’t have a port latch register,
    we should be using a byte port latch to avoid RWM error if time allows.
    So it would go, write single bit to port latch byte, write entire port latch byte to port, read back bit from port latch byte.
    Not that I can say I’ve ever encountered a problem I’d put down to RWM error.
  1. Push button on PIC16F887
    By menta in forum General
    Last Post: - 25th June 2008, 07:47
  2. 12f629 push button & LED
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 01:45
  3. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 10:06
  4. push button problem
    Last Post: - 2nd June 2005, 19:44
  5. Push Button 'Menu' to Choose Variable.
    Last Post: - 10th March 2005, 07:00
