Hi Guys thanks for all the inputs.
I actually need to use a pic like the 16f128 etc because the actual application has 4 inputs (in other words 4 inputs that will give me a 5v high signal independent from each other). Once any of these inputs are triggered a corresponding LED must then switch on.(in other words input 1 must switch on LED 1, input 2 must switch on LED 2, input 3 must switch on LED 3, input 4 must switch on LED 4) I then need to have 4 separate push button switches to cancel the corresponding LED's - one for each LED.
So I was trying to use the 12f675 just to see if I can get it to work with one push button as an input to switch-on a LED and then another pushbutton to switch-off the LED but am battling to get it right.
Any help will be appreciated
Thanks a lot
Willem
