LED ON and OFF with 2 Push button switches
Results 1 to 16 of 16
    Apr 2013
    Default LED ON and OFF with 2 Push button switches
    Hi Guys I am new to picbasic. I wrote a small program to control a LED with 2 pushbutton switches. The one to switch it on and the other one to switch it off. I can get it to switch it one but when I tried the 2nd button to switch it off it just dim.
    Please help
    My code:
    LED Con 0 ' Alias GPIO.0 to LED
    PB Var GPIO.3 ' Alias GPIO.3 to push button
    PB1 Var GPIO.4 ' Alias GPIO.4 to push button
    ANSEL = 0 ' Set all digital
    CMCON = 7 ' Analog comparators off
    ' Button press turns on LED (MCLRE must not be enabled)
    mainloop:
    If PB = 1 Then ' If button pressed...
    Low LED ' Turn on LED
    Else
    High LED ' Turn off LED
    Endif
    If PB1 = 0 Then ' If button pressed...
    Low LED ' Turn off LED
    Endif
    Goto mainloop ' Do it forever
    Default Re: LED ON and OFF with 2 Push button switches
    Read thru your mainloop, line by line, and try to figure out what's happening.
    You check if PB is pressed, if it is you turn on the LED - that's fine. But if PB isn't pressed you turn off the LED - that's not what you want, is it?
    Do you have the two switches wired the same way? I ask because you check PB for a logic 1 while you check PB1 for a logic 0 - that's all fine if it's the way you have it wired, don't forget pullup/pulldown resistors though.
    Finally, the comments are somewhat confusing because at one place you say that LOW LED turns the LED on while in another place you say that LOW LED turns the LED off - I don't know which is correct.....
    Dec 2011
    IO93ok
    LED CON 0 doesn't clearly map the LED to a pin.
    LED VAR GPIO.0 does. Just easier to understand.
    I like to put a pinout connection diagram for the chip as a reminder what is connected to what. It also helps when asking a question.
    Similar to this example
    ; Target Controller -      PIC16F628A
    ;                                  __________
    ;                       d6--RA2 |1       18| RA1--d5
    ;                       d7--RA3 |2       17| RA0--d4
    ;              LED-------RA4 |3       16| OSC1--------
    ;     +5V-----------!MCLR |4       15| OSC2--------
    ;     Ground----------Vss |5       14| VDD---------+5 V
    ;              gps in-----RB0 |6       13| RB7---------
    ;                         ---RB1 |7       12| RB6---------
    ;                         ---RB2 |8       11| RB5--e
    ;                   pbutt--RB3 |9       10| RB4--rs
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Apr 2013
    Hi Guys thanks for all the inputs.
    I actually need to use a pic like the 16f128 etc because the actual application has 4 inputs (in other words 4 inputs that will give me a 5v high signal independent from each other). Once any of these inputs are triggered a corresponding LED must then switch on.(in other words input 1 must switch on LED 1, input 2 must switch on LED 2, input 3 must switch on LED 3, input 4 must switch on LED 4) I then need to have 4 separate push button switches to cancel the corresponding LED's - one for each LED.
    So I was trying to use the 12f675 just to see if I can get it to work with one push button as an input to switch-on a LED and then another pushbutton to switch-off the LED but am battling to get it right.
    Any help will be appreciated
    Thanks a lot
    Willem
    In an effort help you understand what's wrong with your original code I tried to give you some advice in my previous response but apparently that didn't help, so....
    For two buttons and one LED:
      If PB1 = 1 THEN   ' Button 1 is pressed
        HIGH LED1   ' Turn on LED 1
      IF PB2 = 1 THEN    ' Button 2 is pressed
        LOW LED1    ' Turn off LED 1
    Goto Main
    That's it, rinse and repeat for as many buttons and LEDs as you want.
    Sep 2010
    Las Vegas, NV
    I don't comprestand why you're using a PIC. Transistors or relays will be easier than a PIC for just switching on and off LEDs.
    If you're stuck on using a PIC I'm betting you could use a 12F675 and I'm wondering if this will work. Why can't you make a voltage divider and set a pin at 1/2 of VDD which should be ambiguous with the port set to digital. Then you could monitor the same input pin for a high or low. This way you could use two pins for four inputs and have the other 4 outputs free for your LEDs. Well, you only need 3 ports to switch 6 LEDs but that's another thread.
    Caveat is I've never tried it and wonder if it will work. If I get time I'll throw it together today and see if it works.
    Have a look to Microchip DS 40040 ... ( tips and tricks for 8 pins ...)
    solutions are there !
    Sep 2010
    Las Vegas, NV
    Thanks for reminding me about that document. Tons of useful information.
    Sep 2015
    Hi Acetronics2 and AvionicsMaster1,
    Would either of you guys please post the .pdf for DS40040 from Microchip. It sounds like a must have document, but I cannot find it on Microchip's website.
    Thank you.
    mike
    Dec 2008
    Ploiesti, ROMANIA
    Sep 2015
    Hi fratello,
    Thanks for the link.
    mike
    Aug 2003
    It’s a flip-flop, so if you do it in software a flip-flop might as well be 1 bit of memory.
    You’re going to want to look a the LED in a real program and know if it’s on or off,
    so will usually want to store the LED state which would usually represent some program state.
    flipflop var bit ‘ 1 = LED is on 0 = LED is off
    debounce var byte ‘ button debounce counter
    flipflop = 0 ‘ start with LED off at power up, or on if you want to
    debounce = 0 ‘ reset debounce counter
    trisb.0 = 1’ button pin input
    trisb.7 = 0’ LED pin output
    cycle: 'program cycle
    if debounce > 199 then
    if portb.0 = 1 then
    flipflop = 1
    debounce = 0
    flipflop = 0
    debounce = 0
    if flipflop = 1 then ‘ set LED to flip flop state
    portb.7 = 1
    portb.7 = 0
    if debounce < 200 then ‘ increment button debounce counter
    debounce = debounce + 1
    goto cycle ‘ repeat loop forever
    But that's only using 1 button Art not 2 as in the title of the thread.....
    EN82fn
    Aug 2003
    Whoops!
    No need to accommodate contact bounce for the buttons then.
    trisb.0 = 1’ buttonA pin input ON
    trisb.1 = 1’ buttonB pin input OFF
    if portb.0 = 1 then
    flipflop = 1 ‘ set memory bit
    if portb.1 = 1 then
    flipflop = 0 ‘ reset memory bit
    portb.7 = flipflop ‘ set LED on or off
    Now, Thats nice and easy. The only thing I would change is not having a variable for the state of the output pin but reading the output state.
    EN82fn
    Aug 2003
    In the long run, for midrange pics that don’t have a port latch register,
    we should be using a byte port latch to avoid RWM error if time allows.
    So it would go, write single bit to port latch byte, write entire port latch byte to port, read back bit from port latch byte.
    Not that I can say I’ve ever encountered a problem I’d put down to RWM error.
  1. Push button on PIC16F887
    By menta in forum General
    Last Post: - 25th June 2008, 07:47
  2. 12f629 push button & LED
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 01:45
  3. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 10:06
  4. push button problem
    Last Post: - 2nd June 2005, 19:44
  5. Push Button 'Menu' to Choose Variable.
    Last Post: - 10th March 2005, 07:00
