Ibutton Protection Circuit (OneWire)
Results 1 to 4 of 4
    May 2012
    Merseyside, UK
    Default Ibutton Protection Circuit (OneWire)
    Thank you for reading this…..
    I a wondering about protection for the PIC port if I am using a Dallas iButton device. I have seen circuits using a 33R resistor in series and a FR107 Fast recover diode across the probe. And another up to the supply rail.
    My question is why the use (specific) of a fast recovery diode… Will a ordinary or even a Schottky diode be the same …..Is there a reason ?
    Sorry if posted in wrong place.
    Dec 2010
    Default Re: Ibutton Protection Circuit (OneWire)
    Anything is better than nothing - it's to protect from fast transients like lightning striking some distance away or ESD.
    There's a continuum here. Some energy source / device sensitivity combinations will do no damage with no diode at all, some combinations will leave a smoking hole where your circuit used to be. Faster protection is better, but the difference in protection from fast recovery vs. Schottky is pretty small. I use Schottky and have never seen a failure (touch wood). If the lead to the device is fairly short - say under a couple meters, you will be safer yet. YMMV.
    May 2012
    Merseyside, UK
    Thank you
    I guessed the any protection is better than nothing.....
    Now I guess I just need keep my operators away from man made fibres !
    Don't want smoking holes !
    BR
    Andy
    Hi, Andy
    may be it's a good idea ...
    as iButton devices are generally hand held by everyone ( understand people ignoring what is ESD ! ), the diodes inside the Pic may be somewhat weak ...
    so, a couple of fast diodes and a small series resistor are to consider.
    don't forget to read Maxim AN244 ... http://www.maximintegrated.com/app-n...dex.mvp/id/244
  1. RS232 and RS485 circuit protection
    By Luckyborg in forum Schematics
    Last Post: - 27th February 2013, 11:38
  2. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  3. DS2438 onewire code sample
    By Captain Stern in forum mel PIC BASIC Pro
    Last Post: - 21st January 2007, 02:47
  4. Overdischarge protection for a li-ion powered circuit
    By peu in forum mel PIC BASIC Pro
    Last Post: - 7th October 2006, 12:34
  5. Ds1820S & onewire.bas
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 8th May 2006, 21:37
