ADCIN Problems with PIC16F1783
Results 1 to 2 of 2
    Jan 2011
    Sydney, Australia
    Default ADCIN Problems with PIC16F1783
    Hi All,
    I am having no luck trying to configure AN0 on a PIC16F1783.
    My code is as follow:
    ' Test results displayed on a 4 x 20 LCD display.
    ' Connect LCD D4 to RC4 (Pin 15)
    ' Connect LCD D5 to RC5 (Pin 16)
    ' Connect LCD D6 to RC6 (Pin 17)
    ' Connect LCD D7 to RC7 (Pin 18)
    ' Connect LCD RS to RB2 (Pin 23)
    ' Connect LCD E  to RB1 (Pin 22)
    ' Connect ADC1 to AN0 (Pin 2)
    ' Pin 2 fed from the wiper of a 10k pot with the pot connected across Vdd & Vss
        __config _CONFIG1, _FOSC_INTOSC & _MCLRE_OFF & _CP_OFF & _CPD_OFF
        __config _CONFIG2, _PLLEN_ON & _LVP_OFF
    OSCCON = %11111000              ; Fosc = 32MHz
                                              ; Clock determined by Fosc<1:0> Config Word
    DEFINE OSC 32                   ; Define oscillator as 32MHz
    DEFINE	LCD_DREG	PORTC
    DEFINE	LCD_DBIT	4
    DEFINE	LCD_RSREG	PORTB
    DEFINE	LCD_RSBIT	2
    DEFINE	LCD_EREG	PORTB
    DEFINE	LCD_EBIT	1
    DEFINE	LCD_BITS	4
    DEFINE	LCD_LINES	4
    PAUSE 100                       ' Pause to initialise LCD Display
    ' Define ADCIN parameters
    DEFINE	ADC_BITS	10          ' Set number of bits in result
    DEFINE	ADC_CLOCK	3	        ' Set clock source (3=rc)
    DEFINE	ADC_SAMPLEUS 50	        ' Set sampling time in uS
    ' Set up Registers
    ANSELA = %00000001              ' Enable AN0
    ANSELB = 0                      ' Disable PORTB ADC
    DACCON0.7 = 0                   ' Disable DAC
    CM1CON0.7 = 0                   ' Disable comparator 1
    CM2CON0.7 = 0                   ' Disable comparator 2
    CM3CON0.7 = 0                   ' Disable comparator 3
    TRISA = %11111111               ' Set PORTA as digital inputs
    TRISB = %11111001               ' Set PORTB.1 and 2 as digital outputs
    TRISC = %00001111               ' Set PORTC.4 - 7 as digital outputs
    ADCON0 = %10000001              ' Select 10 Bit ADC, AN0  and Enable ADC
    ADCON1 = %11110000              ' 2's Complement Output Format
                                    ' Set A/D clock to FRC
                                    ' Set Vref = VDD
    ' Define program variables
    Adval1      var word            ' ADC variable
    Start:
        ADCIN 0, Adval1
        LCDOUT $FE, $01
        LCDOUT $FE, $80, DEC Adval1
        Pause 300
        Goto Start
    I measure the voltage at pin 2 and confirm it swings from 0 to +5V but the displayed values of the ADCIN result merely jiggles around 2-6.
    I can confirm that the LCD is working properly as I am able to display text without problem.
    The ADC module on the 16F1783 is somewhat different to anything I have used before. It does not have an option for Left or Right justified output, rather ADFM bit selects between sign-magnitude or 2's complement output formatting.
    I have selected the 2's complement option as it most closely resembles the right justified output that I am used to working with. I do not believe this is the cause of my problem but thought it pertinent to mention.
    Has anyone dealt with this device previously or had any luck setting up ADC on AN0?
    Can anyone see any glaring mistakes in my setup or code?
    All comments and suggestions would be greatly appreciated.
    Cheers
    Barry
    VK2XBP
    (PBP 3.0.5.4 + MCS Ver 5.0.0.0)
    Jan 2011
    Sydney, Australia
    Default Re: ADCIN Problems with PIC16F1783
    Hi All,
    I am pleased to report that I have resolved this problem
    I had omitted setting up the ADCON2 register
    ADCON2 = %00001111
    I also needed to set the output format to Sign-Magnitude and then shift the result six places to the right to achieve right justified result
    ADCIN 0, Adval1
    Adval1 = Adval1 >> 6
    Hopefully this post may help someone in the future.
    Cheers
    Barry
    VK2XBP
  1. Help with ADCin
    By RDavid60 in forum mel PIC BASIC Pro
    Last Post: - 18th May 2011, 02:56
  2. Adcin, can't get it right
    By atwoz in forum mel PIC BASIC Pro
    Last Post: - 4th January 2008, 20:38
  3. ADCIN problems with PIC16F73
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 11:38
  4. adcon problems with adcin
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 22:15
  5. help using adcin
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 31st January 2006, 07:46
