dummie joystick guide problem
Results 1 to 15 of 15
    Default dummie joystick guide problem
    • Hello gentlemen, im new to the forum and dont really know much about usb or PBP3 so sorry for the may-be dumb question since i use HITECH-C
      i did all off the dummies guide stuff but in the end, it asks me to compile, compile where? in MPLAB?
      ok so i compiled on mplab using the PBP3 compiler on the 15 trial version and it gives me the following:
      Executing: "C:\Program Files (x86)\PBP3\PBPX.EXE" -ampasmwin -k# -p18F2550 "C:\Users\Aramburo\Desktop\Nueva carpeta\HUB.pbp"
      PICBASIC PRO(TM) Compiler 3.0.7.1, (c) 1998, 2013 microEngineering Labs, Inc.
      All Rights Reserved.
      Trial version. 15 days left.
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 761 : Symbol not previously defined (USBDeviceInit)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 762 : Symbol not previously defined (USBDeviceInit)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 761 : Symbol not previously defined (USBDeviceTasks)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 762 : Symbol not previously defined (USBDeviceTasks)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 761 : Symbol not previously defined (GetUSB)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 762 : Symbol not previously defined (GetUSB)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 761 : Symbol not previously defined (PutUSB)
      Error[113] C:\PROGRAM FILES (X86)\PBP3\PBPPIC18.LIB 762 : Symbol not previously defined (PutUSB)
      Halting build on first failure as requested.
      BUILD FAILED: Tue Apr 22 22:54:59 2014
      apart from this, i would really like to know where do i configure my PIC18f2550??
      do i make a .c file?? (i.e MY_JOYSTICK.c)
      and work from there??
      how do i prevent/correct this compile errors??
      also, where can i find the circuit diagram for this "dummie" joystick, thanks a bunch guys and see you later
      i posted the same thing on another thread, but i am new to the forum and dont know if that was the appropriate way. let me know. thanks
    Default Re: dummie joystick guide problem
    PBP stands for PIC BASIC PRO and you are using C.
    Come on Robert :-)
    He says that he's compiled the program with PBP3 and the posted error messages supports that statement saying PBPX version 3.0.7.1.
    Unfortunately I don't know my way around the USB stuff so I'm not able to help with that except for suggesting to read thru the USB.TXT document in the \PBP3\USB18 folder and trying to compile the examples provided to start with.
    Regarding the i would really like to know where do i configure my PIC18f2550 statement I suspect you mean the configuration fuses and if that's the case look at the #CONFIG / #ENDCONFIG directives in the manual.
    I noticed that, but he didn't post any code. It could just as well be C for all we know.
    It would help posting all the code.
    Oh, you mean like trying to compile C source code with PBP? Yeah, that would most definitely produce "some" errors :-)
    That's just "so wrong" I didn't even think of it.....
    Clarifications and code needed.
    ok, this is what i got so far, all i really did was to turn TRISA into inputs and slightly modyfied the code to what i think would work with the 4 buttons but without the axis. and i get this errors.
    MY code;
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    include "DESCUSBTRYTRYJOY.asm"
    TRISA = 0
    USBBufferSizeMax con 1 ' maximum buffer size
    USBBufferSizeTX con 1 ' input
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit ' initialise USB...
    ProgramStart:
    USBBuffer.0(0) = porta.0
    USBBuffer.0(1) = porta.1
    USBBuffer.0(2) = porta.2
    USBBuffer.0(3) = porta.3
    gosub DoUSBOut
    goto ProgramStart
    MY ERRORS;
    thanks for any advice
    Darrel's usb routine:
    http://www.picbasic.co.uk/forum/show...0434#post80434
    Where did you get that include file? What are the contents?
    i got the file from EasyHID and added the descriptor from the Descriptor tool like the DUMMY guide said, here are its contents:
    #define EP0_BUFF_SIZE 64 ; 8, 16, 32, or 64
    #define MAX_NUM_INT 1 ; For tracking Alternate Setting
    #define MAX_EP_NUMBER 1 ; UEP1
    #define NUM_CONFIGURATIONS 1
    #define NUM_INTERFACES 1
    #define MODE_PP _PPBM0
    #define UCFG_VAL _PUEN|_TRINT|_FS|MODE_PP ; Full-speed
    ; DEVICE CLASS USAGE
    #define USB_USE_HID
    ; HID
    ; Endpoints Allocation
    #define HID_INTF_ID 0x00
    #define HID_UEP UEP1
    #define HID_BD_OUT ep1Bo
    #define HID_INT_OUT_EP_SIZE 64
    #define HID_BD_IN ep1Bi
    #define HID_INT_IN_EP_SIZE 64
    #define HID_NUM_OF_DSC 1
    ; This table is polled by the host immediately after USB Reset has been released.
    ; This table defines the maximum packet size EP0 can take.
    ; See section 9.6.1 of the Rev 1.0 USB specification.
    ; These fields are application DEPENDENT. Modify these to meet
    ; your specifications.
    DeviceDescriptor
    retlw (EndDeviceDescriptor-DeviceDescriptor)/2 ; bLength Length of this descriptor
    retlw DSC_DEV ; bDescType This is a DEVICE descriptor
    retlw 0x10 ; bcdUSBUSB Revision 1.10 (low byte)
    retlw 0x01 ; high byte
    retlw 0x00 ; bDeviceClass zero means each interface operates independently
    retlw 0x00 ; bDeviceSubClass
    retlw 0x00 ; bDeviceProtocol
    retlw EP0_BUFF_SIZE ; bMaxPacketSize for EP0
    ; idVendor (low byte, high byte)
    retlw 0x81
    retlw 0x17
    ; idProduct (low byte, high byte)
    retlw 0xD0
    retlw 0x07
    retlw 0x00 ; bcdDevice (low byte)
    retlw 0x00 ; (high byte)
    retlw 0x01 ; iManufacturer (string index)
    retlw 0x02 ; iProduct (string index)
    ; iSerialNumber (string index)
    retlw 0x00
    retlw NUM_CONFIGURATIONS ; bNumConfigurations
    EndDeviceDescriptor
    ; This table is retrieved by the host after the address has been set.
    ; This table defines the configurations available for the device.
    ; See section 9.6.2 of the Rev 1.0 USB specification (page 184).
    ; Modify these to meet your specifications.
    ; Configuration pointer table
    USB_CD_Ptr
    Configs
    db low Config1, high Config1
    ; Configuration Descriptor
    Config1
    retlw (Interface1-Config1)/2 ; bLength Length of this descriptor
    retlw DSC_CFG ; bDescType 2=CONFIGURATION
    Config1Len
    retlw low ((EndConfig1 - Config1)/2) ; Length of this configuration
    retlw high ((EndConfig1 - Config1)/2)
    retlw 0x01 ; bNumInterfaces Number of interfaces
    retlw 0x01 ; bConfigValue Configuration Value
    retlw 0x00 ; iConfig (string index)
    retlw 0xA0 ; bmAttributes attributes - bus powered
    ; Max power consumption (2X mA)
    retlw 0x32
    Interface1
    retlw (HIDDescriptor1-Interface1)/2 ; length of descriptor
    retlw DSC_INTF
    retlw 0x00 ; number of interface, 0 based array
    retlw 0x00 ; alternate setting
    retlw 0x02 ; number of endpoints used in this interface
    retlw 0x03 ; interface class - assigned by the USB
    retlw 0x00 ; boot device
    retlw 0x00 ; interface protocol - mouse
    retlw 0x00 ; index to string descriptor that describes this interface
    HIDDescriptor1
    retlw (Endpoint1In-HIDDescriptor1)/2 ; descriptor size (9 bytes)
    retlw 0x21 ; descriptor type (HID)
    retlw 0x00 ; HID class release number (1.00)
    retlw 0x01
    retlw 0x00 ; Localized country code (none)
    retlw 0x01 ; # of HID class descriptor to follow (1)
    retlw 0x22 ; Report descriptor type (HID)
    ReportDescriptor1Len
    retlw low ((EndReportDescriptor1-ReportDescriptor1)/2)
    retlw high ((EndReportDescriptor1-ReportDescriptor1)/2)
    Endpoint1In
    retlw (EndPoint1Out-Endpoint1In)/2 ; length of descriptor
    retlw DSC_EP
    retlw 0x81 ; EP1, In
    retlw 0x03 ; Interrupt
    retlw 0x40 ; This should be the size of the endpoint buffer
    retlw 0x00
    retlw 0x0A ; Polling interval
    EndPoint1Out
    retlw (EndConfig1-EndPoint1Out)/2 ; Length of this Endpoint Descriptor
    retlw DSC_EP ; bDescriptorType = 5 for Endpoint Descriptor
    retlw 0x01 ; Endpoint number & direction
    retlw 0x03 ; Transfer type supported by this Endpoint
    retlw 0x00
    EndConfig1
    ReportDescriptor1
    ; vendor defined usage page
    RETLW 0x05
    RETLW 0x01 ; USAGE_PAGE (Generic Desktop)
    RETLW 0x09
    RETLW 0x04 ; USAGE (Joystick)
    RETLW 0xa1
    RETLW 0x01 ; COLLECTION (Application)
    RETLW 0x09
    RETLW 0xa1
    RETLW 0x00 ; COLLECTION (Physical)
    RETLW 0x05
    RETLW 0x09 ; USAGE_PAGE (Button)
    RETLW 0x19
    RETLW 0x01 ; USAGE_MINIMUM (Button 1)
    RETLW 0x29
    RETLW 0x04 ; USAGE_MAXIMUM (Button 4)
    RETLW 0x15
    RETLW 0x00 ; LOGICAL_MINIMUM (0)
    RETLW 0x25
    RETLW 0x01 ; LOGICAL_MAXIMUM (1)
    RETLW 0x95
    RETLW 0x08 ; REPORT_COUNT (8)
    RETLW 0x75
    RETLW 0x01 ; REPORT_SIZE (1)
    RETLW 0x81
    RETLW 0x02 ; INPUT (Data Var Abs)
    RETLW 0xc0 ; END_COLLECTION
    ; String pointer table
    USB_SD_Ptr
    Strings
    db low String0, high String0
    db low String1, high String1
    db low String2, high String2
    db low String3, high String3
    String0
    retlw (String1-String0)/2 ; Length of string
    retlw DSC_STR ; Descriptor type 3
    retlw 0x09 ; Language ID (as defined by MS 0x0409)
    retlw 0x04
    ; company name
    String1
    retlw (String2-String1)/2
    retlw DSC_STR
    retlw 'M'
    retlw 0x00
    retlw 'y'
    retlw 0x00
    retlw 'C'
    retlw 0x00
    retlw 'o'
    retlw 0x00
    retlw 'm'
    retlw 0x00
    retlw 'p'
    retlw 0x00
    retlw 'a'
    retlw 0x00
    retlw 'n'
    retlw 0x00
    retlw 'y'
    retlw 0x00
    ; product name
    String2
    retlw (String3-String2)/2
    retlw DSC_STR
    retlw 'M'
    retlw 0x00
    retlw 'y'
    retlw 0x00
    retlw 'P'
    retlw 0x00
    retlw 'r'
    retlw 0x00
    retlw 'o'
    retlw 0x00
    retlw 'd'
    retlw 0x00
    retlw 'u'
    retlw 0x00
    retlw 'c'
    retlw 0x00
    retlw 't'
    retlw 0x00
    ; serial number
    String3
    retlw (String4-String3)/2
    retlw DSC_STR
    Someone has mentionned problems with Easyhid and PBP 3. Check out Darrel's usb routine.
    Hmmm apparently my last post on this thread didnt upload....
    ive spent the last few days trying to figure darrel USB routine (thanks by the way) but its only for PBP2.6
    where can i get PBP2.6??
    or
    What other "dummy joystick" alternatives do i have??
    Darn, hadn't noticed Darrel's comment about PBP 3.
    Hoping a senior will jump in, that thread was my GOTO for USB and my v2.6c.
    V2.6c no longer for sale as far as I know.
    Hey there Demon. I foud a solution.
    You must place your project files inside USB18 folder (no sub-folders) in order to compile. I know that it sucks. But at least it workss!!
    Awesome!
    Gonna link back to here in that thread.
    Quote Originally Posted by jsags1 View Post
    I bet there's a way to figure exactly which file is needed in that folder and copy that one in the project folder (along with all the other files).
    yes, ill try and make some time to figure out wich files are needed in the project folder after im done with my project. im on tiral version and only have 5 days left!!! XD
    thanks for the advice Demon
  1. USB HID Joystick for Dummies
    By Squibcakes in forum USB
    Last Post: - 2nd May 2014, 07:52
  2. PC joystick to (Servo or Stepper) STEP/DIRECTION
    Last Post: - 31st October 2010, 20:14
  3. Joystick or Game Controller Output Signals...
    By rxforspeed in forum General
    Last Post: - 19th January 2009, 08:01
  4. dummies guide to serin/serout by a dummie
    By earltyso in forum Code Examples
    Last Post: - 10th October 2008, 02:12
  5. USB joystick project
    By ZeroFusion in forum USB
    Last Post: - 18th November 2006, 18:21
