Serial command
Results 1 to 2 of 2
Thread: Serial command
    Default Serial command
    Can Hserin/out , Debugin/out and serialin/out work in the same code for example in a 16f877a?
    Like one pair does hserin/out, another pair goes for debug and third pair for serialin/out.
    I want to serially communicate with my bluetooth module+my PC and then another PIC.
    ___________________
    WHY things get boring when they work just fine?
    Default Re: Serial command
    Yes, but remember that they are all "blocking" commands, that is if you have a SERIN at one place in your program and it's wating for data to come in then your "other" SERIN/DEBUGIN/HSERIN etc is effectively not listening. If you need to be able to receive data from multiple sources simultanously then using interrupts on a PIC with multiple (E)USART is the way to go. On the other hand, if you can communicate with your devices sequentially (first one, then the next, then the next and so on) then you can do it with multiple SERIN/SEROUT.
  1. RETURN command?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 12th March 2022, 13:34
  2. Replies: 1
    Last Post: - 18th February 2012, 12:27
  3. How to do serial command with 2 stop bits?
    By Pimentel in forum mel PIC BASIC Pro
    Last Post: - 4th April 2011, 13:44
  4. Button command
    Last Post: - 29th January 2009, 02:23
  5. ANSEL command
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 9th January 2009, 15:33
