Self powered PIC, app note. How to do.
Results 1 to 5 of 5
    Dec 2011
    IO93ok
    Default Self powered PIC, app note. How to do.
    I found this app note from Microchip which may be of use to someone for battery operation.
    Vdd Self Starting Circuit
    Building on the previous topic, the same charge
    pump can be used by the MCU to supply its
    own Vdd. Before the switch is pressed, Vbat
    has power and the Vdd points are connected
    together but unpowered. When the button is
    pressed, power is supplied to Vdd and the
    MCUs CLKOUT (in external RC oscillator mode)
    begins toggle. The voltage generated by the
    charge pump turns on the FET allowing Vdd
    to remain powered. To power down the MCU,
    execute a Sleep instruction. This allows the
    MCU to switch off its power source via software.
    Advantages:
    • PIC MCU leakage current nearly 0
    • Low cost (uses n-channel FET)
    • Reliable
    • No additional I/O pins required
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Default Re: Self powered PIC, app note. How to do.
    Very interesting. Did you get the AN number?
    Dec 2011
    IO93ok
    Hi Demon,
    It came from the Hints n Tips pdf in the other post here. Lots of good stuff in it.
    Rob.
    Apr 2012
    Ptolemaida
    Indeed very interesting but could someone explain the circuit some more ?? i can't understand the "• PIC MCU leakage current nearly 0"
    Why is that happening ??
    One man's magic is ANOTHER man's engineering.
    Supernatural is a null word
    Apr 2012
    Ptolemaida
    Sorry for my hasty question. I studied the circuit some more and understood it. It's an electronic switch, indeeed very nice circuit !!
  1. Replies: 10
    Last Post: - 25th February 2014, 02:04
  2. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 10:44
  3. PIC powered by capacitor for 0,5 second
    Last Post: - 25th August 2007, 09:23
  4. PIC-Powered Timer Project
    By T.Jackson in forum Schematics
    Last Post: - 18th May 2007, 04:45
  5. Pic powered from USB?
    By Squibcakes in forum USB
    Last Post: - 26th June 2006, 00:03
