Record, storage and compare analog signals
Results 1 to 17 of 17
    Apr 2008
    Default Re: Record, storage and compare analog signals
    I have code for 10 Bit AD converter with array storage four samples.
    If I send results from array separately, I see all numbers of array results on LCD, (Example 1.)
    But If I send all results from array together, LCD show number 0. (Example 2.)
    My question is, what is wrong, how correct this code, how can I send all results from array to LCD?
    Kuba
    Example 1.
    Lcdout DEC array[0]," ", Dec array[1]," ", Dec array[2]," ", Dec array[3]
    Example 2.
    Lcdout DEC array[counter]
    This is my code:
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTC
    Define LCD_RSBIT 4
    Define LCD_EREG PORTC
    Define LCD_EBIT 5
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_SAMPLEUS 3 ' Set sampling time in uS
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = %00000000 ' Set PORTB to all output
    TRISC = %00000000 ' Set PORTC to all output
    ADCON1 = %10000010 ' Set PORTA analog and right justify result
    Pause 500 ' Wait .5 second
    array Var Word [4]
    counter VAR Byte
    Start_array VAR Byte
    Stop_array VAR Byte
    Start_array =0 : Stop_array = 3
    adc_runtime:
    for counter = Start_array to Stop_array
    ADCIN 0, array[counter] ' Read channel 0 to array[counter]
    next counter
    Pause 100 ' Wait .1 second
    Lcdout $fe, 1 ' Clear LCD
    Goto adc_runtime ' Do it forever
    Jun 2009
    Sc*nthorpe, UK
    Use example 1 as example 2 will only display array[4] or you could do something like this
    adc_runtime:
    Lcdout DEC array[counter]," "
    next counter
    Try it a see what happens
    You try to display only one array element and especially the array[4] element that does not exist. You have defined from 0 to 3 (4 elements) and the variable counter after the end of the For-Next loop ends up with the value of 4.
    So you try to display an non-existence variable, that could have a random value.
    Steve has given you an example to display the variable within the loop and should work as you expect.
    Apr 2008
    Hi loannis,
    I tried your metod, it does not work.
    Method of EarlyBird2 really works, Im surprise.
    Kuba
    Apr 2008
    Working, great
    Thanks EarlyBird2
    Kuba
    Jun 2009
    Sc*nthorpe, UK
    Kuba,
    You are welcome.
    What method? I explained what Steve has given you as an example.
    Apr 2008
    Hi loannis,
    now I understand you explanation.
    Exist other method, how to send all array elements to LCD, after the completion loop, except my 1. Example?
    Kuba
    Sorry for my english
    With arrays the STR modifier is used to send without FOR-NEXT loop.
    But in your case you need a second modifier and up to this moment this is not supported.
    This does work: STR my_array\16 ' sends the first 16 bytes of the array my_array
    This does not work: STR DEC my_array\16
    But I wish sometime in the next update/upgrade it will be supported!
  1. how to record sound into eeprom
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 20th November 2009, 22:16
  2. How to read analog signals?
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 06:00
  3. Using a PIC to record voice
    By weirdjim in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 21:21
  4. Replies: 6
    Last Post: - 20th August 2006, 23:00
  5. The best way to record non-volatile data
    By johnson in forum General
    Last Post: - 19th July 2004, 10:03
