BUTTON statement without repeat rate variable?
Results 1 to 2 of 2
    Default BUTTON statement without repeat rate variable?
    Hello.
    I have certain project, which uses 11 buttons. They have no repeat, but BUTTON statement requires separate BVAR variable (button variable) to be declared for all buttons. Is there a way to skip usage of this variable?
    I know that I can do without BUTTON statement at all, but I like they way it works (debounce and code stopped until you release button).
    Apr 2011
    Welches, Oregon
    Default Re: BUTTON statement without repeat rate variable?
    A quick check of the manual does not show the square brackets "[ ]" typically used to denote optional parameters; perhaps one might use the same variable on all buttons however- presuming it is initialized to zero before each use.
    If Button = pressed then
      pause 100 'debounce
      HOLDINGBUTTON: If Button = Pressed then  'still depressed
        pause 100 'wait for release of button
        Goto HOLDINGBUTTON
      Elseif Button = NotPressed
        Do something
      EndIf
    Endif
  1. HEX2 statement result to variable?
    Last Post: - 30th January 2014, 15:47
  2. Repeat .... UNTIL code
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2012, 01:11
  3. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  4. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 04:19
  5. Push Button 'Menu' to Choose Variable.
    Last Post: - 10th March 2005, 08:00
